Question about Python 4203P Responder Mini 2-Way Remote Start
Hook up cheap CXM-1500 sterio /cd/mp3 player into a 99 ford ranger
Dont know which color wires to hook to
Putting a diff. cd player in my 1996 ford ranger. i dont have the connection kit. whats the wiring diagram for my 96 ford rangers audio setup?
click on this link,, and scroll down to locate your year, Fords are all the same,, this has your plug in with color codes and what they are for !! http://www.installdr.com/Harnesses/Ford-Wiring.asp
Sep 12, 2011 | 1996 Ford Ranger SuperCab
I have 97 for ranger with tape deck with cd player
This should help you wire up your new stereo. 97 Ranger stereo wiring diagram. They do make a plug in harness for your truck. Metra part number 70-5600.
May 10, 2010 | 1997 Ford Ranger SuperCab
Cant get power to radio
You may find your answer here also: Crutchfield
The link is a PDF file, this is a wiring diagram example that matches my 99 Chevrolet Silverado Z71
Apr 06, 2009 | Pioneer DEH-P2900MP CD Receiver...
I need to know how to install a pionear sterio into a 99 ford focas i have the wire harness and kit i just need to know how to dismount the factory sterio and what wires go where
You need the factory car stero keys, its like a u bracket one slides in either side then you just pull it out with them.
as your wires there colour coded :)
Feb 21, 2009 | Pioneer DEH-P6800MP CD Player
Hi i have a question
you need to get a used one out of a junkyard and just reconnect the wires. alldata also has a great site for wiring
Sep 10, 2008 | 1992 Ford Ranger
Wires
red= accessories power on
yellow= power always on memmory
black= ground
blue white= amp switch this goes to amp
blue= power antenna
the other wires are speaker wires top is for the fronts
the bottom set is for the back speakers this is simple
suggestion if you dont know the wire hook up i suggest taken the wires and sterio to certified car sterio installer pay 5 bucks and have them splice the wires together for you so you dont screw up your vehicle wireing or your sterio this is crucial
Jul 07, 2008 | Clarion DXZ365MP CD Player
Sound from drivers door speaker in my truck.
check your speaker wire, sounds like the insulation is cut somewhere and thewire is grounding out. that is why the crackling and low sound. your speaker wire is grounding out or wire is broken, start at the speaker and follow wire to find the break
Jun 01, 2008 | Car Audio & Video
Buzzing sound and can't open stereo
Again RCA stereos **** for this factor, cheap transformers, replace the transformer and see if that helps as it seems to be the most problem with most RCA systems I've repaired in the past.
May 09, 2008 | RCA RS2656 Shelf System
Install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
Have you measured the 12v ignition and permanent supply?
Also check the earth.
You will need a tester for this.
Check the fuses
John w
Feb 13, 2008 | Pioneer DEH-P6400 CD Player
Hooking Up Problems
RUN YOUR OWN SPEAKER WIRES OR CHECK WITH A DEALER FOR COLOR CODES ,... WHICH ARE ALSO IN A REPAIR MANUAL
Nov 28, 2007 | Dual XDMR-7700 CD Player
Python 4203P Responder Mini 2-Way Remote Start Logo
20 people viewed this question
Top Python Home Security Experts
Are you a Python Home Security Expert? Answer questions, earn points and help others
