Question about Iris Office Equipment & Supplies
I can't get my red ERR light to clear so it doesn't scan at all. Batteries are new and I tried to recalibrate it but it wont let me. What are my options?
Camcorder wont turn on at all
Are the batteries fully charged ?
Jun 17, 2017 | Mitsuba DV777 Camcorder
My canon iR2016 has a system error E001
the e001 is error for temperature rise by main thermistor. If the termistor OK and doesn't need to be replaced you can clear the error in service mode. If clear doesnt helps, you need to change the fixing film assy.
Clearing error:
Press the User mode key, 2key, 8key,
User mode key sequentially
now you are in service mode, by arrow right, select #CLEAR, press OK, choose ERR and OK.
Also you can try with same procedure but instead ERR choose ALL. NOTE: under clear ALL, you delete all user data and restors the copier on factory settings.
Hope that helps!
Aug 25, 2011 | Canon Office Equipment & Supplies
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
CODE EROR E 216- 0000
try to clear error.
press *28* (2 and 8 press together) - Copier - ERR - CLR - OK - switch Off - (wait 5 second) - switch On.
if it doesn't changed. you must replace a new the scan lamp or motor scaner .
May 21, 2011 | Canon CLC 4000 Copier
My wii balance baord wont switch on, its had two lots of brand new batteries & a recharge plug in box from Argos. It appears to be charging (green light at the back of the recharge adapter) but then as...
Balance Board will only power on if balance board compatible game is running on the Wii and you may to recalibrate again. Also, try it with disposable batteries.
Apr 29, 2011 | Nintendo Video Game Consoles & Games
I have a kodak easyshare c533 camera and it won't turn on. I tried new batteries but all it does is flash the green light. Any ways to fix this?
Green light flashed, turned red, lens would not open. Put in new rechargeable batteries, still nothing. Someone here suggested to try regular AA cheapie batteries. IT WORKED!
Nov 09, 2010 | Kodak EasyShare C533 Digital Camera
I get a reading "Err 1" and it will not run at all.
Try recalibrating your machine. Use the owners manual for the steps. This might work. I had an L5 error and it wouldn't run either. Recalibrating fixed the problem.
Jul 09, 2009 | Bowflex Treadclimber
Cant get it to turn on or charge
Flashing red light 3 times and won't boot. I recently recalibrated the battery and again the 3 flashing red lights. Seem to be draining the battery fast. It's also a new battery...which work for about 2 weeks before the 3 flashing red lights first started. Now 2 batteries later. It won't boot.
Apr 26, 2009 | Gateway MT6840 Notebook
BATTERY LIGHT FLASHES ORANGE
hi,
if you have tried both batteries with the same laptop and they are giving you the same error code, then it could very well be a motherboard problem, both the batteries cannot be bad, what you can do is try these batteries on some other compatible laptop model to check if they work fine there. Also try swapping the AC adapter as in both case you might be using the same Ac adapter, try using some other good known AC adapter as well.
Further queries are welcome
If you find my solution helpfull please do rate me
Feb 20, 2009 | Dell Inspiron B130 Notebook
Scanner isn't scanning all the time
It doesn't sound like a power issue. Most likely it either needs cleaned, or it needs the laser recalibrated or replaced. Try cleaning the glass for starters, and then hold the scanner about two inches from a white piece of paper. You should get a solid, bright red line. If the line is distorted you need to recalibrate the laser. If it's dim, the laser unit is going out. The laser can be replaced, but I don't know if it's one of those things where the part plus labor costs more than replacing the scanner.
May 31, 2007 | Datalogic Gryphon D200 (901661076)...
Top Iris Office Equipment & Supplies Experts
Josh Whitehead
Josh Whitehead
Are you an Iris Office Equipment and Supply Expert? Answer questions, earn points and help others
