Question about Blue Hawk Tow-Behind Lawn Spreader 45-0215-062
BLue Hawk 85lb spreader - lever will open door
The control lever that opens the feed amount will not open the sliding door. The cable seems to be too long. are replacement parts available?
I need the lever that controls the opening of the feed gate. The only number on the spreader is 0195 ther is no explanation for this number
I would take the machine to a lawn mower shop and get advice as to what make it is and if there are any generic levers that could be adapted to do the job.
Apr 07, 2015 | Garden
My Scotts Deluxe Edgeguard has broken. The cable that pulls the fertilizer feed door open (when you suqeeze the lever) has sheared off where the cable meets the body. Is there some way to obtain the p
Try calling their helpline here.
Scotts Help Center experts are available toll-free at 1-888-270-3714
They will often send you small parts at no charge.
Oct 05, 2014 | Scotts 1237443 74434 Deluxe Edgeguard...
I need parts for scotts precision flow model pf1
My Scotts Deluxe Edgeguard has broken. The cable that pulls the fertilizer feed door open (when you sqeeze the lever) has sheared off where the cable meets the body. Is there some way to obtain the part(s) I need? What about a repair manual so I can figure out what part(s) are required?
Jun 08, 2014 | Scotts 73730 AccuGreen 3000 Deluxe Drop...
Assembly instruction manual for blue hawk spreader
That is a Lowes special item. I would go to Lowes customer service and see if the can copy one from another unit that they have.
Jul 07, 2013 | Blue Hawk 100 lb Capacity Tow-Behind Lawn...
Precise fit 85 lb tow broadcast spreader Can't find repair parts for precise fit spreader
repair parts can be found on amazon, click here and take a look: Amazon com Precise spreader parts. I hope this was helpful. Cheers
Apr 18, 2011 | Garden
Flow control lever doesn't open hopper door
your fertilizer is got clumps in it. I have experienced the same when using TSC fertilizer (cheap and wet).
Mar 22, 2009 | Agri-Fab 175lb Agri - Fab Tow Broadcast...
Panasonic - convection/microwave oven door is stuck shut spring will not open same -dinner in oven help
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be
removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can order Panasonic parts here.
I hope this picture shows up - it helps illustrate:
Aug 10, 2008 | Panasonic Microwave Ovens
Blue Hawk Tow-Behind Lawn Spreader 45-0215-062 Logo
79 people viewed this question
Top Blue Hawk Garden Experts
ray gallant
Jay Plesset
Are you a Blue Hawk Garden Expert? Answer questions, earn points and help others
