Question about Husqvarna Models 61-66, 266, 268, 272
What is correct husqvarna 268 chain file size
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Husqvarna Expert
  • 250 Answers
For the standard H80 or H81 style chain you will use a 7/32" (5.5mm) file
Posted on Feb 03, 2016
SOURCE: need true chain/bar size for my husqvarna Model 254 chainsaw
Maximum bar size of 20" but would recommend 18", if it is running sluggish, check compression, if low replace the piston, if it is 135psi or more then make sure the airfilter is clean and then tune the carb and make sure you get good revs and throttle response throughout the rev range, use the typical carb adjustments from the owners manual from the Husky web site. This is a 5hp saw and is capable of cutting some big lumps of hardwood so no excuses on the power front
Posted on Mar 16, 2009
dontbother10
  • 2220 Answers
SOURCE: What size file should I use ona Husqvarna 137
The question you ask is dependent on the chain in use not the saw that drives it. To determine what chain is installed we must see the chain. A local seller/mechanic should be willing to answer your question. Lowes will not know!!!
Excerpt from "How To Sharpen a Chain Saw" here follows:
http://www.grounds-mag.com/mag/grounds_maintenance_sharpen_chain_saw_2/
Use the right tools
If you're holding it correctly, a proper-diameter round file simultaneously restores the three different angles of a saw-chain cutter. Different-sized chains and different cutter styles call for different file diameters. It is vital to use the right size file.
In general, 1/4- and 3/8-inch-pitch, low-profile chains call for a 5/32-inch file; 0.325-inch-pitch chains require a 3/16-inch file; and standard 3/8-inch-pitch and 0.404-inch-pitch chains demand a 7/32-inch file. Beware, however, because many exceptions exist. For example, some brands of standard 3/8-inch-pitch chain require a 3/16-inch or 4.5-mm file. Check your chain-saw owner's manual or saw-chain instruction sheet to determine the correct file diameter. If you're not sure, ask your dealer. He also may have literature showing the proper filing angles and special procedures for your chain.
Getting the angles exactly right is not as important as removing all damage from the side plate and top plate and making sure the critical top corner is really sharp. However, for good results, you must consistently hold the file at the correct height and orientation within each cutter. This is difficult to do without some type of file guide.
Like most tools, simpler is better when it comes to file guides. The best guides are plates that drop over the chain. These keep the file at the right height and attitude and have witness marks to show proper top-plate angle alignment. The best thing about this type of guide is that you can see what you're doing. Guide plates that clamp to the file and rest on the cutter top plate also are good, but they tend to obscure your view of the cutter. Whichever guide you select, make sure you get the right model for your chain.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 15, 2010
Zim1308
  • 543 Answers
SOURCE: We have a model 137
all saw blades are sharpened to the same angle. 37° the file size you are going ot want is 1/4-3/16in.
Posted on Apr 18, 2011
  • 2239 Answers
SOURCE: Filing angle for Husqvarna chainsaw 450 --20 ' bar chain 72 links?
On .325 pitch chain the top plate angle should be 25 degrees, there is normaly a match mark on top of each cutter, the depth gauge should be set at 25 thousands of an inch.
Posted on Apr 02, 2013
SOURCE: oil leaks from the bar oiler when not inuse on Husqvarna 268
Try THICKER oil like straight 30 weight
Posted on Apr 10, 2013
What Size File for a Husqvarna 240 Chain?
The 240 runs standard a 3/8 " pitch H36 low profile chain. The proper size file is 5/32" (4.0 mm)
Jun 09, 2014 | Husqvarna Chain Saw 20" Bar
Husqvarna 51 file size
Several bar and chain combinations fit the 51 model saw. If your saw runs an H46 / H80 or H81 style chain you will need a 7/32" (5.5 mm)
If you are running a H21 style chain you will need 3/16" (4.8mm)
May 02, 2014 | Husqvarna Chain Saw Models 51, 55
I would find a lawn and garden shop that repairs chainsaws. Take your saw there and they should be able to get you the correct file.
Dec 02, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Help desk number
3/16
Click on the image by CHAIN TYPE to enlarge. All file sizes are shown.
Jun 28, 2013 | Husqvarna Garden
Chainsaw starts but will not tick over
Does the engine tick over if the chain brake is off...? If so, check the clutch springs.
If it doesn't tick over when the chain brake is off, try advancing the tick over screw.
May 03, 2013 | Husqvarna Models 61-66, 266, 268, 272
We have a model 137 chain saw. I need to know what size file to sharpen the chain and the correct angles for this model.
Apr 18, 2011 | Husqvarna Garden
What size file should I use ona Husqvarna 137 chain saw?
Use the right tools
Lou
Mar 15, 2010 | Husqvarna Garden
What size file to sharpen chain for 55 rancher
It depends on the chain you have installed on the chainsaw. You can look at the numbers stamped on the drive link side of the cutting chain and it should have a 2 digit number that correlates to the size.
The factory chain supplied with the #455 rancher was a .325" pitch 3/8" chain.
Here's a link to the specs for your saw with some useful info
http://www.husqvarna.com/us/homeowner/products/sawing/chainsaws/455-rancher/#specifications
Hope you found this very helpful and best regards!
Aug 06, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna Models 61-66, 266, 268, 272 Logo
169 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
