Car Audio & Video Logo
A
Anonymous Posted on Apr 13, 2014
Mtx x motos - MTX Car Audio & Video
What color light indicates power on the MTX 810D amplifier please?
It is too old for online manuals. Any colour light would show it has power and usually a red, green or blue LED. Red is sometimes reserved as a fault condition in conjunction with another power light.
https://www.google.com/search?q=mtx+810d+amplifier+manual
I have 2 different subs in one box, a 12" MTX thunder and a 12" Kicker CVR. the kicker is a dual voice coil while the MTX I dont believe is. Can I use one amp for this set up? And how would it be wired?
im guessing both speakers are 4 ohms ..mtx 4ohms and kicker dual 4ohms..now if your amp can go down to 1 ohm wiring the kicker dual coils in parallel (2ohms) and the mtx connected together (4ohms) should leave you with a final impedance between 1 and 2 ohms ...i suggest you use one or get another
My mtx ts5510 stopped working while driving. Was hooked to an mtx thunder 81000 class d and its still working. ????
Inspect speaker for loose wires/broken wires. Check inside box for loose connection. Blown fuse on amp. Ive literally pulled the wires out of the speaker. The little mesh ones from the terminal to the cone. Look for that. If you do find something broken or bad. remember you can call MTX and fix for a flat rate on most evrything they carry. Ive sent several amps there. normally around $100
I have a mtx thunder 421d. I've had it about 5 years,about a week ago it started going out from time to time. I checked my hot wire and fuses,they are ok.Now the amp stop working, and dont light up. Will...
If you have proof of purchase(invoice or receipt) showing the purchase date and you are still within the warranty period then yes it would be repaired by MTX under the warranty guidlines, and by the way MTX is great at customer service and they are great to work with(very fair)!!!!
Keep in mind that the seal on the bottom of the amp cannot be broken or that will void warranty coverage.
Give them a call, you will be glad you did!
800 225 5689 - MTX Customer Service & Amplifier Service Center
Good luck !
Has mtx stop selling the mtx ta81001?
Hello t3h_b,
The MTX web site shows the amp as a current product.
http://www.hifisoundconnection.com/ sells the amp and claims to have it in stock. However, MTX lists only 2 authorized online resellers:
www.crutchfield.com and www.sonicelectronix.com
Crutchfield doesn't list the amp at all and SonicElectronix shows it as "discontinued". I'd recommend going to MTX's contact page and ask them directly. They'll usually respond within a day or two.
Hope this helps.
MTX 1501 SCHEMATIC DIAGRAM
MTX never released any of their schematics.
What sort of problem are you having with it?
I LIKE TO HAVE SOME ONE TO FIX MY AMP.
you have to send it to mtx. Most repair shops wont touch it. You can call mtx i had the same amp. It cost about 85 bucks plus shipping. the 85 bucks covered return shipping also.go to there web site it has the info for tech support and repair issue there. hope this helps
3helpful
3answers
Mtx TC-6001 Amps Problem
I had same problem with a TC6001 and get solution from MTX, not send to MTX instead MTX kindly sent a quotation for parts to be replaced, I can tell you what parts need to be replaced if you still need a solution.
Amp works fine i think??? but Prsim efx not working at all
You need to contact MTX tech support before the warranty runs out. You'll probably have to get an RA number to send it back.
http://www.mtx.com/caraudio/contactMTX.cfm
Top MTX Car Audio & Video Experts
Jose Ramirez
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
