Question about John Deere 5420 Tractor
Where is the fuel pump from tank to fuel filter on 1996 John Deere 5420
2 Suggested Answers
SOURCE: John Deere 5420 has no fuel from tank to filter
John Deere and it's lack of engineers, located the fuel tank below the engine/filter assembly, so it won't gravity feed. The little pump in the top of the fuel filter is worthless. The easy fix is to install an inline diesel fuel pump with a overpressure line off a blank fitting from the fuel filter, which will allow excess pressured fuel to flow back to the tank. What I did was install a fitting with a fuel hose about 2 feet long that has a lawn mower fuel cut off, with a section of hose after it, that can be plugged, when not used. Anytime fuel prime is lost to the filter, then it's a major effort to get it back. This is the cheap way. If you disconnect your fuel line the fuel flows all the way back to the tank, however I believe there is a check valve located underneath the tractor, before the tank, which keeps it from going all the way back. Anyway, I use a large cc syringe to pull fuel up to the filter. After each pull, I close the lawn mower shut off to keep the progress. Empty the syringe and then open the valve and pull some more. Once you have plenty of fuel to the filter, then I close the red fuel shutoff on the back of the fuel filter (closes the line to the tank). Then I push some fuel with the syringe toward the injector pump, while cranking the engine. At this point you don't want it to start, because you will pull all the fuel from the filter, because the red shut off is closed on the back of the filter. After only one or two "pushes" , then close off the lawn mower shut off, open the red shut off on the back of the filter, and crank. Mine usually starts about 5-15 seconds from starting to crank. DON'T CRANK TOO LONG, THE BOOK WARNS ABOUT OVERHEATING THE STARTER. What stupid engineers designed this? Hope this helps. As a side note the fuel hose off the tank is one size, and then it goes through the check valve and changes to a smaller diameter, to go to the filter.
Posted on Sep 25, 2010
I have a 1996 John Deere 455 diesel It started running only 20 minutes before it dies for no apparent reason. After about 10 minutes it will pop right off again. The engine runs strong, no hesitation
The fuel injection pump has a fuel supply from the fuel filter and a fuel return line from the fuel injections to the fuel tank. This fuel return line is kinked or restricted in some way . Repair fuel return line and it will run. Check return line and fitting on injection pump also. If it is an electrical problem it is most likely the operator presense switch in the seat overheating and loosing connection then cooling off after a few minutes.. Check it out.
Jan 03, 2017 | John Deere Garden
John deer 175 riding mower won't pump gas to carberator. New fuel pump, can see gas in fuel filter7
could be a collapsed fuel fine from the tank. disconnect at filter and see if you can blow thru it to the tank .
Jul 10, 2016 | John Deere Garden
John deere 3140
cat converter plugged
Aug 06, 2014 | John Deere 5420 Tractor
2320 johne deere disiel tractor cranks over but won't start
check fuel filter first and that fuel pump works by openig at fuel pump and pushing fuel out just short of injection pump-- if no fuel pushes out prime fuel system by pushing air into fuel tank or using a in line hand fuel pump--- fill tank on tractor so that fuel is above injector pump also helps probably a prime problem
Mar 14, 2014 | John Deere 420,1020,2010,2020,2510,2520...
John deere 415 diesel fuel flow
If its a diesel, the fuel pump where the steel lines come down from top engine. Follow fuel line coming coming from tank to find filters.
Jan 16, 2014 | John Deere Garden
John deere la 105 is not getting gas to carburetor. changed pump and blew out lines
Take line off fuel filter and see if you fuel. Check the outlet in the tank and fuel cap vent.
Oct 22, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John deere 116 no fuel to carb
Blocke inline filter, or if it has a pump, then this is not working.
Feb 29, 2012 | John Deere Garden
Just changed the fuel filter on a John deere 1020, is there a way to prime the injector pump?
If the fuel filter is full when replaced it shouldn't be necessary. But if you have access to compressed air, put air to the fuel tank and that will do it. Hope that helps ya.
Dec 21, 2010 | John Deere Fuel Pump Fits 1020 Thru 4230
Sep 08, 2010 | John Deere 5420 Tractor
Tractor is not getting fuel pass the fuel fi;ter...new filter
Check the fuel lines,fuel pre-filter[screener] and check valve,all of these are ahead of the fuel filter.Also if the fuel filter is not the problem then the primer pump on top of the filter housing may have a leak or debris in the diaphragm so that you can not get the fuel to completely fill the filter.Once the filter is full,full fuel out of the bleed screw on the filter housing,then you need to turn on the key and keep on pumping the hand primer.If it still will not start then get a 11/16 wrench and crack two lines on the injection pump.Crank over the tractor until it sounds like it may go,tighten the lines,the crank again and it should start.
Jul 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 5420 Tractor Logo
19 people viewed this question
Top John Deere Toys Experts
Colin Stickland
Colin Stickland
J.D. Browning
J.D. Browning
john h
Are you a John Deere Toy Expert? Answer questions, earn points and help others
