Question about Husqvarna DMS 240 Core Drill
Drill won't turn on?
I drilled a hole 3" by 4" deep move to second hole and drill will not turn on
3 Suggested Answers
agent91
  • 2100 Answers
SOURCE: Where should I drill a fill hole for my MTD made
Why do you have to drill? No plug? Check out the back of that thing, the plug might be on the side, the back, the front, not necessarily on the top. The fill plug will be the level too, fill it up till it seeps out. Then plug it up. Hope this helps.
Posted on Jun 03, 2010
timwied
SOURCE: I have a Husqvarna 55
I have a blower that does the same thing, I purchased a new coil and the same thing, I disconnected all the wires to the coil also, has to be turned at about 100 rpm to spark?
Posted on Dec 07, 2016
How do I take out a 5/8 auger bit that is stuck in a railroad tie? The drill won't move it ahead or in reverse.
Hey Doreen,
First, remove the stuck drill bit from the drill... You can drill "relief" holes around the stuck drill bit in a circle (use a 3/8" bit) and drill about 6-8 holes deep and close to the stuck bit.. this will relieve the tension on it and you should be able to wiggle the stuck bit carefully (don't break it) until it pulls out.
Jun 26, 2017 | Drills
Starter
You will need a drill, drill bit and an easy out.Drill a hole in the center of the broken bolt about 1/2 to 3/4 inch deep then insert the easy out and turn in reverse direction.
Mar 30, 2014 | Chevrolet Chevy Cars & Trucks
How do you drain pool?
Best way & the most recommended is to use an auxiliary Submersible pump. If you don't have one, a rental yard, or even Home Depot / Lowes or a DIY Center in your area has one.
NOTE **** - Very Important - Do NOT drain all the way to the deep end. Drain in 3 parts. Place pump into shallow area about 1 foot lower than the shallow floor. Then drill a hole all the way to the earth below. Then move pump half way down and restart draining process. When water is exposed half way down, drill another hole. Then move the pump to the bottom of the pool shell. When empty, drill a 3rd hole. WHY, you may ask?
Take a look at this:
Because of Hydrostatic water pressure in the ground (Possible High water table) at the pressure will pop your pool right out of the ground.
Jan 27, 2014 | Jandy AQUALINK RS TELELINK KIT
Need the best bit for drilling through books without tearing internal pages
If you use a brad point bit or forstner bit or any bit that cuts around the circumference of the hole, you will create a disc of paper (several pages thick) that will spin at the bottom of the hole and impede your drilling, so those are out. If you use a standard twist drill you get a very rough hole and the pages tend to lift up. The simplest and cheapest is a standard twist drill but with scraps wood above and below the book, clamping the book tight. You might try a plug cutter that has an exit hole for the little discs of paper. Or, use a paper drill bit, these are about $40 and I have never tried one.
Jan 21, 2013 | Craftsman 3/8 in. Drill Press Bit,...
How to remove a screw with no head
Instructions 1 Use a center punch to put a deep hole right in the center of the screw shaft. This step is just so you have a starting place for the drill to begin. Tapping a thin nail into the center can sometimes work. 2 Start with a very small drill bit and drill a hole down into the shaft. Once that's complete, go to the next size of bit and drill a little larger opening in the screw shaft. Stop when the hole is big enough to use an easy-out tool in it. 3 Turn the tool gently. You never want to be rough in this step, lest you break the easy-out. Keep turning until the screw shaft is out. The tool is designed to grip the interior of the screw shaft and turn it as you turn the handle. 4 Remove the easy-out if the screw shaft is being stubborn and still won't come out. You definitely don't want to break the easy-out off in the hole. 5 Continue to use the drill, each time enlarging the hole until only the threads are left. 6 Peel away the threads of the screw with a large plastic headed pin. Pull them out of the threads of the opening.
Aug 05, 2012 | Cars & Trucks
Injector bolt sheered on no. 4 cyl
There's a couple of tools that make bolt extraction a little easier. The first one I would try is a reverse drill bit. A reverse drill bit looks just like a standard drill bit but it drills in a counterclockwise direction instead of clockwise. If you start drilling into the center of the bolt, it will drill partially into the bolt and at some point, the tip of the bit should grab onto the bolt and twist it out since it's going in the same direction you would twist it to loosen the bolt. Sometimes, if the bolt has been torqued down too tight, a reverse drill bit won't work. If that's the case, keep drilling the hole in the center of the bolt with the reverse drill bit until you've gone about 1/4 to 1/2 an inch deep. Then try using an easy out to extract the bolt. An easy out looks kind of like a tapered drill bit. I've shown a picture of one below. (You can buy a kit that has both easy outs and reverse drill bits) Choose the right size easy out for the size of hole you just drilled. The tip of the easy out should go partially into the hole, just enough to grab onto the bolt as you twist it counterclockwise. With the easy out in the hole, put a wrench or socket on the end of it, push down hard and twist counterclockwise. That should hopefully extract the bolt.
Good Luck!
~Brandon
May 31, 2011 | 2003 Jeep Grand Cherokee
Hi, I want to replace an old American Standard toilet bowl that is a 4 bolt tie down design to the floor. Can I replace this with a standard 2 bolt floor mount design? If not are 4 bolt tie down models...
If you go with the 2 bolt you will need (I presume) to drill 2 holes into the tile. put toilet in place where it will sit and mark the holes , take away toilet and drill the holes with a 7ml tile drill bit (masking tape put over the tile will help you to not slip when starting off the hole). Drill deep enough to insert 7ml rawl plugs. then place the toilet back and fix down with screws long enough to go through the toilet and 3/4 of the rawl plug. You will need; Electric percussion drill or descent battery drill. 7 ml tile drill bit 2 x rawl plug 7ml 2 x screw masking tape is handy hope this helps, Alex
May 18, 2011 | American Standard 2294.011.020 Afwall...
I have drilled a 1 inch hole in my concrete basement wall. I cannot release the bit from the drill. The chuck won't turn by hand to release the bit.
Good Afternoon, Ladooudep55:
I hope you have got your bit back, but if not, remount the drill chuch onto the bit, and drill in forward without pushing the bit. If it still won't move, You can gently wobble the drill to enlarge the hole and retrieve the bit.
The other method is alternating light hammer taps with compressed air. It will make lots of grit dust.
If the hole around the bit is wet, you may have drilled into an iron pipe, if it smells it was the sewer drain. You will have to decide if you want to replace the pipe section or run an epoxy patch once you have retrieved the bit.
Chr
May 01, 2011 | Makita BDF452HW 18V Cordless Lxt Lithium...
How do I bolt down Sentry Safe S3310 to the floor?
All of the instructions can also be found at www.SentrySafeShop.com
The link is:
http://www.sentrysafeshop.com//kb_results.asp?ID=7
Required Tools:
Drill, Wrench, 7/16" (11.0mm) bit, for wood anchoring: 9/32" (7.20mm) bit, for masonry
anchoring: 3/8" (9.5Omm) masonry drill bit.
The steps are as follows:
1. Tip the safe on its right side. (Door hinges horizontal with the floor)
2. Unlock the safe and open the door.
3. Look on the bottom (outside) of the safe for two indentations in opposite corners. Using a
7/16" (11.0mm) bit, drill a hole through each indentation perpendicular to the bottom of the
safe.
4. Close the door and tip the safe upright. Place it where desired and reopen the door.
5. Use a screw or drill bit to mark the floor through both holes.
6. Move the safe aside to clear both marked spots for drilling.
7. Drill into the floor:
a. For wood:
i. Using a 9/32" (7.2mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
b. For masonry:
i. Using a 3/8" (9.50 mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
ii. Install a masonry anchor in each hole.
8. Replace the safe in the desired position, with the holes in the safe aligned with those in
the floor.
9. Securing the safe:
a. For wood:
i. Pass each lag screw through a washer, then through the safe and into a hole. .
ii. Tighten with a wrench. ,
b. For masonry:
masonry anchor.
Jun 27, 2010 | Sentry FIRE-SAFE Combination Safe DS3431,...
Removing centre screw from chuck
Drill a hole in the top of the phillips head screw with a 3/16 th's bit. Don't drill the head of the screw off, just drill deep enough for a torx bit to hold. Take a T-30 torx bit and tap in into the hole you have drilled. Then turn the screw clockwise and it should come out fairly easily.
Mar 26, 2010 | Dewalt Drills
Husqvarna DMS 240 Core Drill Logo
Top Husqvarna Drills Experts
Are you a Husqvarna Drill Expert? Answer questions, earn points and help others
