Question about Kitchen Appliances - Others
Taylor 430-12 margarita machine doesnt turn on in auto mode. The mix out light blinks on even though its full of liquid.
I have a Taylor 430-12 margarita machine. I filled it with water to test it and it turns on in wash mode but when it is in auto mode the mix out light blinks on and it doenst turn on. I opened the panel in the back and if i press both switches in and hold them down it will turn on.
  • 139 Answers
SOURCE: Zanussi FJ1254 W - Machine does not fill
Yes if you remove your soap draw and take a look inside you will see that there is all residue built on the top part of the internal draw, Either you can jet wash it off or replace the soap draw,,
this should solve your problem.. if that does not work then one of your solinoid valves at the back is faulty...
Posted on Dec 02, 2007
SOURCE: Blinking red light
The blinking light is a warning that something is not right.
-It will blink when the espresso waste basket is full. sometimes they stack up funny and it appears full and light blinks.
-second the beans don't always fall into the grinder from the hopper. They just need a gentle nudge
-Third it may be low on water.
-Four if you don't push the door closed on the fromt and ensure the spout where the coffee comes out is pushed in to the reciever inside the door the light will come on.
For me it has always been on of these four things.
Once I got the hang of the little nuisance everything works great. I love my machine and would buy another.
I have one or two espresso's a day,
Posted on Dec 20, 2007
  • 185 Answers
SOURCE: simpson esprit washing machine
put a new pressure switch in it
Posted on Mar 26, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WT540 1400 spin Washing Machine stuck on cycle
Could be a sticking water level switch, which controls the water level, or a blockage in the hose to the switch, or a trapped or split hose to the switch. the hose in question is about 6mm in diam,and goes from the sump hose to the pressure switch,if u remove the hose from the preesure switch chamber, check for a blockage there, and blow down the hose to see if it is clear, u should hear the switch click if it is clear, if no click and hose is clear, then I wud say the switch is faulty.
Plz rate my comments.
Thanks
Posted on Jan 01, 2009
SOURCE: auto light wont turn off.
You need to press & hold the forward button on the right side of the watch for a few seconds. That will turn off the auto light
Posted on Jan 08, 2009
Taylor 8756-33. Which components operate in standby mode?
In standby mode, the machine just wants to keep the product refrigerated until it goes back into auto.
So, the mix cabinet needs to keep the product cool in the bottom of the machine, that requires the mix compressor and fans to run. The mix cabinet temperature is read by a thermistor probe and regulated by the (left side) logic board.
The product in the cylinders should go back to liquid form in standby, but we still have to maintain that safe food temperature, the motor and compressor will run periodically. If the machine is air-cooled a fan will run anytime the compressors run. If it is water cooled, water will flow through the machine when the compressor runs. The temperature in the freezing cylinders is read by a different thermistor probe and regulated by the logic boards.
Here is a link to all of the parts in a Taylor 8756.
http://www.softserveparts.com/c-1335911-parts-8756.html
Jul 20, 2015 | Taylor Ice Cream Makers
Standby keeps turning on when in standby but auto works turns itself on and off fine. Both sides of unit
I don't think you have a problem... I have a Taylor 8756p-27. In standby mode with my unit the beater motor turns on for about 15 seconds every 15 minutes and the compressor turns on as needed to keep the mix at a safe temperature. This is what standby mode is supposed to do. If you don't want it to turn on and off so much in standby mode, perhaps leave it in AUTO mode and it will turn off and on as it needs to to keep your product at the proper temperature.
May 06, 2015 | Taylor 754-33 Ice Cream Machine Soft Serve...
Mix is foaming in the hopper
I have a c712 and we have noticed that when i put it in sleep mode over night the hopper was getting to warm and making the ice cream foam ( we use non dairy) on the top but still liquid on the bottom. We had to turn the sleep mode temps down for over night. We haven't had a issue after that. Hope this helps.
Aug 09, 2013 | Taylor Ice Cream Makers
Taylor ice cream machine logic board will not turn on how can i fix this
what model is machine.Most of the taylor machines will freezer lock and jump to standby mode unless both sides are working.especially if it is a heat treat model.
May 03, 2012 | Kitchen Appliances - Others
Recently bought a used Taylor Shake/Slush Freezer Model 430 to be used for shakes. It was used for aheks in the past and no problems, however, we put it together and the ice cream is too hard. Even...
The Taylor 430 thermistor model has two adjustments a fine adjustment, which is made by turning the knob, and a coarse adjustment that is made by turning the screw in the center of the knob. I suspect you are trying the fine adjustment, which will change the product + or - 2 degrees F. The coarse adjustment will let you set the product temperature between 10 and 30 degrees F.
As far as the clunking, those machines clunk a little. It would do it more if the product was too hard.
You are correct the machine will leak drops into the drip tray, but if it is more than drops, you want to address it. Should be as simple as a new tune up kit.
X39969Tune up kit for most Taylor Slush Machine non Carbonated machines...
If this doesn't help, or if you have any other questions, you can reach me at
Soft Serve Parts Supplies
Mar 15, 2017 | Taylor Ice Cream Makers
I took apart a Taylor 430-12 Frozen Margarita machine and need help on trying to reassemble it...
Taylor 430, craziest issue. Liquid is not flowing in hopper all the way. It stops and starts bubbling at the top. Nothing is blocked, reassembled several times with/without face plate. The water will only go halfway in the hopper. No type of blockage. can someone offer any ideas, suggestions. Im lost
Oct 09, 2010 | Taylor Ice Cream Makers
I have an Ultra 2 bunn slush machine. One hopper
I have a 2 hopper bunn slush machine.One hopper freezes the second one does not
May 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
My chefmate breadmaker - The liquid and flour don't get mixed..
Even though you hear the paddle moving, the belt may be slipping so the paddle does not rotate at full force. Please check the tension of the belt. You can access the motor, belt, pulley assembly inside the base of the machine. Also, please check to make sure the kneading cycle is run fully. Check the manual to see length of cycle. Good Luck...Hank
Jan 22, 2010 | Chefmate TR 7000 Bread Maker
Taylor 8756 ice cream machine clogs at face
i need to know where i may go to get directions to put this taylor 8756-22 ice cream machaine back togeather if you can help please e-mail me at johnjohnson1967yahoo.com thanks
Jun 01, 2009 | Taylor 632-33 Ice Cream Maker
Kitchen Appliances - Others Logo
52 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
