Question about Epson Stylus Sx535wd
Sx 535 wd cartridge not recognised - Epson Stylus Sx535wd
I replaced a black cartdridge epson sx 510w, but the printer doesn't recognized it?
I would recommend the following:
  • Remove the cartridge from the printer.
  • Turn the printer off.
  • Wait 30-60 seconds.
  • Turn the printer back on.
  • Reinstall the ink cartridge.
If the printer still doesn't recognise the cartridge it is likely to be faulty. In which case I would recommend seeking a replacement from wherever it was purchased.
Feb 27, 2013 | Epson Office Equipment & Supplies
Epson stylus sx 435w does not recognise ink cartridge
my epson stylus photo sx 435 w doesn' t recognize the cartriges of a second brand so that I can't working .How can I reset, if possible, the software of the printer in order to bring it back to the initial conditions.
Feb 17, 2013 | Epson Stylus Sx435w
Epson stylus sx200 refuses to acknowledge black ink bought direct from epson
I believe the DX series and the SX use the same system
# Determine which ink cartridges are not recognised.
# With the ink cartridge holder in the ink cartridge replacement position, lift up the ink cartridge holder lid and take the cartridge or cartridges out.
# Check that the cartridge is a genuine Epson ink cartridge - look for the EPSON branding and T0xxx codes on the cartridge labels.
# Check that the cartridges are correct for your Epson product.
# Wipe the green Intellidge Chip on the cartridge that is not recognised.
# Check the chip contacts within the ink cartridge holder for any debris or dried ink and wipe with a lint-free cloth if necessary.
# Check that the plastic at the bottom of the cartridge has been pierced.
# Check that the cartridges are in the correct slots.
# Reinstall the cartridges into the ink cartridge holder in the correct order.
# Push the ink cartridge down firmly. It should click into place.
# Repeat this for any ink cartridges that were removed.
# Push the ink cartridge holder lid down. It should clip into place and be secure.
# Press the Stop button, this will return the ink cartridge holder to the right hand side of the unit.
# If the error light flashes after the print head returns to the home position, the ink cartridge may not be installed properly.
# If the red light is no longer displayed, but Status Monitor still reports a Non-Genuine Ink warning.
# If the red light is still on the printer, and Status Monitor indicates that an ink cartridge is not recognised, follow the steps below.
# If the problem remains, there may be a fault with the ink cartridge.
Dec 30, 2010 | Epson Office Equipment & Supplies
Epson nx400 doesn't recognize ink cartridges
First of all let cartridge in the printer.... Then press Start.. it will say cartridge not recognised... then remove all cartridge (do not turn off printer).. then wait for 15 minutes...then again put cartridges in head... then press start..start...start..It will recognise on 2 to 3 tries.. Works on Epson TX210,200,410...If u want to be recognised then do not turn off printer...
Aug 13, 2010 | Epson Stylus NX400 InkJet Printer
Dell 942 AIO printer won't recognise black cartridge:
I think you purchased a black cartridge with bad electronics. Basically your cartridge can't communicate with your printer and you should exchange it for a new one. There is no way to "fool" your printer into accepting refills with bad electronics. What you can do is when you get the message that you aren't using genuine cartridges and it won't be able to estimate ink levels is to check the box indicating to ignore the ink levels.
Nov 13, 2009 | Dell 942 All-In-One InkJet Printer
WD 1Tb Drive not recognised on my HP Media Centre a1550a
Probably the size nay be above the parameters the existing software is able to recognize
Did you receive a disc and if you did not. Simply go to the page of the manufacturer and down load the driver, then the Plug and play should recognize it..
Nov 01, 2009 | Western Digital Elements powered by WD 320...
I have a 'vintage' (70's) Pioneer sx 535. What is the simplest way to hook up an FM antenna?
Depends on the connection on the back. Most older receivers used unbalanced 300ohm connections. In short, any speaker wire will do. Newer models used a "F" type connection (Coax end) which you can still cheat and get a 75 to 300 adapter at radio shack or any other local electronics store. Hope this helps.
Oct 01, 2009 | Audio Players & Recorders
Intel Desktop Motherboard D850MV
Hi Funky Fish,
If you're WD is an IDE drive please re-check the pin setting on the drive. Please download. Data lifeguard diagnostic software from WD's web site. Use their bootable software to seup you're drive. http://support.wdc.com/download/index.asp?cxml=n
After which you're drive will show the correct size.
Enjoy!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 26, 2008 | Intel Motherboard
Epson stylus rx 425, just cahnged catridges and printer wont recognise this, catridge red light permanently on. help! printer wont recognise cartridge
Try to left up your new cartridge, and reinstall it. chances are your installation of the cartridge is just loosened. If your printer still won't recognise your print cartridge, there might be a problem with your printer motherboard in recognising your cartridge.
Apr 08, 2008 | Computers & Internet
Canon MP510 wont recognise cartridges
Using replacement cartridges that come without a chip seems to be the problem I had with the Canon Pixma 510 printer they are cheaper
but if they do not show the ink levels then its inconvienent so I have but Canon products with a chip and they work perfectly.
Nov 11, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Epson Stylus Sx535wd Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
