Question about Longines La Grande Classique L4.709.2.42.9 Watch
What battery is used in a longines qwr? I have batt. No.364. Is that correct?
How do i set an older longines automatic admiral watch to the correct date and day
You can get instructions from their web site but if your watch is really old, then it seems unlikely that any of the instructions there are for your watch.
However, since watches tend to have similar features (although not the modern electronic types), a basic modern watch probably operate in the same manner.
Go to "www.longines.com/watches/instructions" and have a look at the range of instructions there to see if they are any help.
If nothing useful is found look at the "official retailers" to see if there is a local shop that can help you.
Mar 08, 2010 | Watches
Battery is dead, needs to be replaced.
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
Feb 21, 2010 | Longines Oposition L3.117.4.78.6 Wrist...
Battery is good, but watch stopped.
You need to hold in reset and mode to make it go back on.
Dec 31, 2009 | Novelty Watches
Hello, i need a strap for my longines l2.671.4 brown. where can i get one please
Good day sir, here's the link below where you can buy your longines brown strap.
longines strap
have a nice day.
Nov 05, 2009 | Longines Evidenza L2.671.4.78.9 Watch for...
How do I change the quartz battery on a Longines La Grande Class
Just unscrew the screw at the back if your model have screw if not the other one snap to open.Use a pocket knife then open it look the number battery and replaced it with same number battery. Its you use Renata battery it is swiss 3years to last.
Hope it may helps;
Regards;
VOTIT
Jun 16, 2009 | Longines La Grande Classique L4.709.2.42.9...
Face almost unreadable;can only adjust winding back;stops intermittently.
Hi Murbilpov,
thank you for using fixya, you have a very fine piece of jewelry. it appears that your watch needs cleaning right on the knob and adjust mechanism. as per a service document from longines, a possible build-up or a broken first gear may cause this issue.
you may refer to their official statement when it comes to cleaning and having the watch repaired.
1) Where should I send a Longines watch that needs to be repaired, adjusted or serviced?If your Longines watch needs to be repaired, adjusted or serviced, werecommend that you bring or send it (well padded and by registereddelivery in the latter case) to your nearest Longines authorizedservice centre. You will find its address in your guarantee booklet oron our website in the Customer Service section.
2) Is the repair of a Longines watch that is more than 20 years old still possible?Yes, we still repair vintage watches at our head workshop in St-Imier.
However, without having the watch to hand, it is impossible for us tojudge its state and to know if all the necessary spare parts for therepair are still available.
Therefore, we kindly suggest that you send your watch via the nearest Longines authorized servicecentre to the Longines head office in Switzerland. Upon receipt andafter analysis of your watch, we will send you our comments and a priceestimate for the repair of your watch.
3) How often do you recommend having a maintenance service carried out on a Longines watch?We would like to draw your attention to the fact that a watch used daily is running 24 hours a day, 7 days a week non-stop.
The frequency of the maintenance service depends on the type of watch, the climate and the care taken by the watch wearer.
In general, it is necessary to have your watch controlled andserviced at least once every 4 - 5 years, just like any other precisemechanical device. This guarantees the reliability and rate precisionof your watch.
4) Which operations are included in a complete maintenance service?The following operations should be included in the price of a complete maintenance service:
– complete dismantling of the movement, cleaning, oiling, reassembling, regulating and the checking of functions;
– repair or replacement of movement components that are either worn or faulty;
–replacement of the following parts: glass, crown, push-pieces, sealsand battery if a quartz calibre (parts included in the price of theservice, with the exception of shaped mineral glasses and sapphirecrystals);
– restoration of the water-resistance (if a water-resistant model);
– refurbishing of the case or bracelet (two-tone, gold-plated and PVD-coated cases and bracelets, cleaning only);
The above service standards are only valid for the Longines head office in Switzerland.
5) Which operations are included in a partial maintenance service?The following operations should be included in the price of a partial maintenance service:
– during each partial basic repair, Longines undertakes to check theregulation of the movement and replace the glass (if necessary), thepipe, the crown, the push-pieces, the seals and the battery in the caseof a quartz movement (these parts are included in the price, with theexception of shaped mineral glasses, sapphire crystals, and restorationservices carried out on the dial, case and bracelet. Parts made out ofnoble metals will be invoiced separately);
– restoration of the water-resistance (if a water-resistant model) and cleaning of the case and bracelet;
Any repair that necessitates the replacement of a part, or any servicementioned in point 7 automatically involves a partial basic service.
Hope this helps, should you have other questions, please do not hesitate to let me know.
regards,
voodoo
Apr 22, 2009 | Longines Watches
Longines watch problem
Some longines watch has built-in battery gauge. When battery is low, the second hand jumps every four seconds. If you have new battery installed and the problem persists then there is a short circuit somewhere that drinks a lot of battery juice.
Mar 11, 2008 | Longines Watches
Fossil watch battery
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi SDMIKED
I suggest you consult your authorized Fossil Dealers for the correct battery replacement of your watch.
Thank you.
Nov 11, 2007 | Fossil AU4003 Wristwatch
Longines La Grande Classique L4.709.2.42.9 Watch Logo
79 people viewed this question
Top Longines Watches Experts
michaelrt616
Andrew Taylor
Andrew Taylor
Are you a Longines Watch Expert? Answer questions, earn points and help others
