Question about Jenn-Air PRG3000P Gas Kitchen Range
Oven heating up slow - Jenn-Air PRG3000P Gas Kitchen Range
Are there fuses for the oven on my flat top stove oven. it is very slow to heat up
Yes, there are fuses (or at least 1 fuse), but if they were bad, your oven wouldn't heat up at all. You may have a bad element. Does your oven have a visible (or hidden) bake element? Does it have a convection fan & element? One of those may be bad, causing slow heating.
Oct 07, 2014 | Kenmore Kitchen Ranges
Whats the difference between a slow cooker and a roaster oven?
a slow cooker just cooks slowly. a roaster oven however roasts food just like in a range oven. they can usually also bake and slow cook also. roasting cooks at a high heat while slow cookers are a lower heat for a longer time. roasters are great to use because the meat tastes really delicious and also the whole kitchen will not get boiling hot like with roasting in the oven.
Jan 24, 2013 | Kitchen Appliances - Others
Oven slow to heat. I had an appliance guy come and change the element, still slow. 1 hour to 300F. I can't find a service manual on this range.
This sounds like a problem with the oven thermostat. If a slow heating problem is reported the element can be the problem sometimes but generally it would be the thermostat which has complete control over the elements heating cycles. It sounds like you may need the thermostat replaced. I hope the the oven door seal it tight. This can cause problems if too much heat escapes through a faulty seal.
Feb 15, 2011 | Thermador RES30 Electric Kitchen Range
Oven slow to start heating (sometimes) not always. But once the gas burners ignite then the oven heats up quickly
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
May 11, 2010 | Jenn-Air JGS8750ADS Gas Kitchen Range
Oven slow to heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 10, 2010 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
GE microwave is slow to heat. Had popcorn in for
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
sdgthg
Feb 10, 2010 | Maytag MMC5000 Microwave Oven
My HBL452 double oven is slow to heat both upper
heatman101
Dec 01, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
heatman101
Nov 23, 2009 | GE Profile JTP18 Electric Single Oven
It is slow to heat up
The oven ignitor is slowly going out...it needs to be replaced!
Oct 25, 2009 | Jenn-Air JGR8855BDS Gas Kitchen Range
Oven slow to heat
In alot of ovens preheat will cause the both the broil and bake element to come on. You are most likely getting heat from the broil element. This means either the bake element is bad or the relay on the oven control is bad. If the element shows resistance with an ohm meter then replace the oven control board.
Sep 30, 2007 | Thermador REF30 Electric Kitchen Range
Jenn-Air PRG3000P Gas Kitchen Range Logo
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
