Question about APC Back-UPS CS 500VA UPS System
Dead appearing ups/inverter
My offline 500 VA home inverter (electric power generator-MOSFET based) does not show any (mains ) light indicator even when main supply is on. when switched to battery(mains off) it does no show battery indicator on . the ouput point of ups show 2 v AC on multimeter when mains supply is on . All fuses are ok. the ups appears dead as if just passing mains suplply. no sound from its transformer & no normal heating up signs etc.earlier the external battery connected to it had become defective and inverter used to jump btn main and battery option when switch buttons for both were 'on'(main supply present) and low battery indication when only battery switch is on(main supply of either kept off or no supply). pl help troubleshoot the problem.
  • amitbhatnaga Jun 24, 2009
    want more alternate solutions
  • Anonymous Mar 15, 2014
    My inverter was working fine however there was
    lighting stuck the electric pole since than
    its not charging the battery however its switching from mains to battery and battery to mains but not charging the battery . When lighting stuck the electric pole there was sound near my inverter as if something blew
    i opened my inverter and checked i did not find any circuit plate burned or damaged
    iam not able to understand why its not charging the battery ?
    Sergeant:
  • 321 Answers
Keep on your main switch. off all the lights fan and other electrical items, let that inverter get charge first
Posted on Jun 18, 2009
  • mohamed salim shaikh
    mohamed salim shaikh Jun 18, 2009
    keep on your main switch. off all the lights fan and other electrical items, let that inverter get charge first
Samsung PN51E530A3FXZA screen blank, loud buzzing from screen
Back - light inverter problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 25, 2016 | Samsung Series 5 51-inch PN51E530A3FXZA...
Tip
WHAT IS A POWER INVERTER?
A power inverter is an electronic device that converts electricityfrom one form to another. Power inverters have become more popularrecently as the technology has become more efficient and much moreaffordable.
The most popular use for a power inverter isconverting battery electricity into mains electricity. For exampleconverting your car batteries' 12 volts DC into mains electricity 240Volt AC (Australia) or 110 Volt AC (USA).
WHAT POWER INVERTERS WILL HELP YOU DO
  1. Power inverters enablemains operated electrical equipment to be used even where there is nomains outlets, like in your car, caravan or even on your boat!
  2. Powerinverters bring creature comforts from home when you go camping orcaravaning allowing you to use your TV, fridge or electric shaver infact most of the normal mains powered conveniences from the home.
  3. You can charge your laptop in the car even if it doesn't happen tohave a 12 volt adapter. In fact a power inverter can be a very handygadget just to have in your car for those times you need to use a mainspowered appliance while you're away from a power socket.
WHAT TO LOOK FOR WHEN BUYING A POWER INVERTER
Apartfrom looking for a good quality well priced product there are a coupleof important elements to consider when selecting your power inverter:
HOW MUCH POWER IS ENOUGH ?
Powerinverters come in a range of power capacities so selecting the rightone for you is very important. Your power inverter needs to be able toprovide sufficient power for the equipment you want to use it with.
Here is a brief check list:
  1. Check the power consumption for the device you want to power
  2. Allow an additional 20% free board
  3. Add the power for all the devices you want to run at the same time
Note also that devices with induction electric motors like an power saw mayrequire 3 to 7 times the operating power when they start.
Usingan under-powered power inverter may damage it or the appliance you aretrying to use, so be sure to check the specific wattage requirementsand operating instructions for appliances / tools to be used.
PURE SINE WAVE INVERTERS
Normal mains power is known as Alternating Current (AC) and is a sine wave shape like the black line in the drawing below
Pure sine wave (black) versus modified sine wave (red)
Atypical power inverter produces a 'modified sine wave output' like thered line in the drawing above. While this works for most appliances,light dimmers, variable speed drills, sewing machine speed controls,some laser printers etc. will not operate correctly with a modifiedsine wave power inverter.
Pure sine wave power inverters areespecially designed to provide a more accurate sine wave output and socan be used with these appliances, but unfortunately they are moreexpensive.
Check with your with appliance manufacturer or itsspecifications to confirm if you can use a conventional power inverteror will need a pure sine wave inverter.
WARRANTY
One of thegreat things about electronic equipment is there is no moving parts(although there is a fan in some models) so you can expect a longserviceable life from a power inverter.
STANDARDS
Powerinverters generate dangerous mains voltages so ensure the product youchoose is approved for use with your mains voltage and supplier.
Powerinverters can also generate electro-magnetic radiation that caninterfere with other electronic equipment such as radios transmittersetc. Check for compliance with relevant standards such as C-Tick etc
SAFETY
Powerinverters can generate potentially lethal voltages so the utmost ofcare should be exercised using them to avoid accidental electrocution.
SUMMARY
To select your power inverter carefully check the power requirements for the appliance(s) you intend to use it with.
  1. Start power - Allow up to seven times for an induction motor
  2. Operating power - Allow a 20% margin
  3. Pure or modified sine wave
on Mar 04, 2010 | Electronics - Others
Hi every one ... I have a UPS with 12V 7A battery .. i want to replace the battey with 12V 100AH battery with an external charger. The problem is i don't know how to cut out the built-in UPS charger?
Two issues must be noted in this case.
First of all working the UPS continuously on the battery for more than the stipulated time of the design could generate problems especially if the heat sinks for the MOSFETS are insufficient. Secondly the charging circuit is designed along with the drain circuit and so you need to get the battery charged externally in parallel with a proper cut off circuit.
My suggestion to you is that Instead of this modification, it is better to get an UPS/Inverter of 500 VA which will easily work on the 1000AH battery, new designs are compact and efficient. You keep aside this short period UPS for a specific purpose or even connect this to the main UPS/Inverter.
Apr 30, 2015 | Computers & Internet
Apc smart ups rt 10000 internal fault, what to look for?
you should check the inverter and the charger boards as well.
Mainly IGBTs and drivers (IGBT drivers).
better locate the fault and replace the defective board
Aug 21, 2014 | APC Smart-UPS RT 10000VA - UPS ( external...
My inverter (500 va) (battery based electric generator for power backup) keeps on charging batteries even when the charging light goes off making the inverter, wires and battery very hot.
This a possible failure of the voltage detection circuit in the inverter main board and requires the fault be identified by checking the voltage/current feed/limiter to the battery.
Once when the battery voltage has reached the threshold set up the charging should stop and then the circuit will analyse the voltage on the board to trigger the charging to be put ON.
This can be a failure of the detection circuit and if not checked can damage the battery.
Jun 20, 2011 | APC American Power Conversion Back Ups Es...
Wiring the 1750 watt eliminator direct to the main panel
DO NOT DO THIS! If I understand you correctly you want to have three ways to have 110 power in your motor home--- (1)Vehicle 12V to inverter to main panel. (2)Generator to main panel. (3)plug the main panel into 110V. If any two of these are connected at the same time and they are both live, somethings going to blow. That's because with AC, the two sources must be synchronized in their cycles very precisely. The utility company connects their power plants together on the grid only with the aid of precise controls. But the really serious problem is the same reason they invented transfers switches for home generators -- if you were connected to (3) and the power went out, and you connected (1) or (2) without disconnecting the dead (3), you will backfeed power to the line outside and you just might kill the lineman who is trying to fix the power outage.
May 20, 2010 | Eliminator MotoMaster Mobile Power...
Dc bus faulty
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. There maybe one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault.
These lower powered and cheaper KVA type UPS are switch over types, when the mains supply fail, the UPS switches over to the inverter in milli-seconds which then supplies mains power but the power waveform is a pseudo sine wave (ie not a true sinewave. A faulty inverter circuit won’t deliver power when the mains supply fails.
The true UPS types are usually the higher KVA units (over 1500 VA) that supplies uninterrupted mains power. The mains power is connected to a charger which charges the batteries and the inverter draws power from these batteries and converts it to true sine wave mains power therefore there is no switch over time lag from the mains to the battery.
Oct 22, 2009 | Powerware 9120 UPS System
Sir after changing the battery ups worked well one day and the next day onwards when i pressed the switch red and amber lights blinking and the upc trips with beep sound .kindly give the solution
Oct 16, 2009 | APC Computers & Internet
Low voltage output from inverter
I am thinking this a high impediance device problem and this is normal operation - the user manual of my inverter warns about use with high impediance devices - if not I am interested also...
Jan 23, 2009 | Electronics - Others
APC Back-UPS CS 500VA UPS System Logo
252 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
