Question about Tascam DP-24 Portastudio
DP24 wont turn on
Not able to power on checked power connection -ok outlet -ok
Why wont my Splendide washer/dryer wont turn on?
check outlet for power if ok bad switch or transformer make sure on 120 volts
Jun 13, 2014 | Splendide Washing Machines
My tv wont turn on. I have done nothing to it except to turn it off to go to bed. It turned back on and i turned it off and it wont turn on. what could be the problem?
Check the power outlet. Connect the TV to some other power outlet and see. If you find the same problem, the TV might be shown to a qualified service technician, as some fuse would have blown inside.
Aug 05, 2012 | Emerson 22" Class LED-LCD 720p 60Hz HDTV,...
Samsung j843 power
Check power outlet, try a different power outlet. Check for jammed power button on remote. If these are ok, this might need attention by a qualified service technician.
Jul 15, 2012 | Televison & Video
I pressed the power button, but the tv wont turn on
Please check if the power cord is connected properly in the wall outlet and in the TV. Check the wall outlet. Has it got power? Check if there is red light when the power is switched on at the wall outlet. If there is red light then press the power button. Does the TV turn on? If not then your power button is defective and requires replacement as it is not making contact. Also please try to start your TV WITH THE REMOTE CONTROL. At times it helps.
Feb 12, 2011 | Sanyo Televison & Video
Cannot turn on the printer even if connections are ok ?
The only thing that could stop you from turning the printer on other than a broke printer is the power/power cord is not connected. The printer should turn on without a USB or parallel printer cable attached.
If no lights are showing when you try to power the printer, check the power connection in the back of the printer to ensure it is plugged in, check the plug into the adapter is connected and that the power cord's plug is connected to the wall outlet - if you have a power strip make sure it is turned on and the circuit breaker is not popped. Make sure that there is power to the outlet by plugging in something else to show it has power. If all of those check out ok and you have a meter, check for voltage at the power connector at the printer (pull the plug out of the printer and check voltage from inside the plug to outside the plug. It should be 18 vac.
If all of this is ok, there is something wrong inside the printer. Probably time for a new one as cost to repair is probably too high.
Oct 11, 2010 | HP DeskJet 810c InkJet Printer
My laptop wont even turn on! how do i make it work?
OK! I'LL PLAY ALONG?
MAKE SURE POWER CABLE CONNECTED TO REAR OF LAPTOP/PLUG END IN SOCKET/TURN ON SOCKET/MAKE SURE POWER AT SOCKET?
OPEN LAPTOP/SHOULD SEE LED(S) SHOWING?
LOCATE SWITC/BUTTON/PRESS/SHOULD HEAR HDD STARTUP AND SCREEN ACTIVATE?
BATTERY MAKE NEED RENEWING IF NOT HOLDING CHARGE?
Nov 15, 2009 | Compaq Presario Notebook
Numark Axis 9's wont turn on
1. Check for internal fuse.
2. Check the power transformer.
3. Check the rest of the power supply.
Aug 11, 2009 | Audio Players & Recorders
Dell d600 wont turn on after shutdown
Try pressing firmly on the keyboard around the 6 and 7 keys and pressing the power button at the same time. Works with my D600 which has the same problem. Apparently it is a common problem with something looses or not soldered properly under there. Will eventually get around to pulling mine it apart to see if I can fix the problem permanently but this "fix" has been working for quite while now.
Jan 26, 2009 | Dell Latitude D600 Notebook
Puter wont turn on
try to unplug again then plug in switch-o the power if it won't work then your power supply is busted you need to replace the power supply. if you want to make sure dismantle the power supply that connects to the motherboard, the connector has 20pins, then plug the power supply connect pin green and pin grey if the fan will rotate then the power supply is still okay.. if your power supply is ok check your outlet voltage if there is power including the circuit breaker that supplies power from this outlet.
Dec 16, 2007 | E-Machines eMachines Desktop PC
Tascam DP-24 Portastudio Logo
63 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
