ESC specialist filter
Can some one tell me what this ESC specialist filter is?
i justfound it on my desk top.. i got this one after i installed AVIRAantivirus. I tried uninstalling the Task Filter ESC several times.. but it stillautomatically get installed.
Is it a virus?
  • Nazid Azeez Jun 18, 2009
    i tried uninstalling it in Add or remove programmes
  • Anonymous Mar 23, 2014
    THE ESC AND TRACKINO LIGHT IS OFF ON MY CAR
    Sergeant:
  • 321 Answers
See in add remove programme or contact me letter i will sent you a software
Posted on Jun 18, 2009
How do I get my HP computer to boot into windows when I turn it on
mine can boot to 7 things, not just the first hard disk.
usb mem, sd, hdd0,1,CD, and more..
no computer stated by you of th 10,000 models. 1984 to now.
what windows, 14 versions exist.
XP? what?
when you turn the PC the booting is a serial process. (ends at windows login screen)
first it runs BIOS< ROM,
the BIOS ROM, runs POST, (self tests and Plug and PLay)
then BIOS jumps to the first thing in the list (boot order)
and boots to the HDD #0 (default ) F9 key I can change that.' on the fly...
so first is what:?
  1. if a laptop get that bad main battery out first, now
  2. use AC power pack only, NOW. lap or desk top.
  3. does the PCs fan run? (my desk top has 4) if not, power is bad.
  4. does the CD eject? (button) if not power is bad.
  5. does the screen ever show text? like Hit ESC to enter SETUP?> as it did every day since new?
  6. if yes, good, no bad. (bad CCFL lamps>)?
  7. yes, then see if ESC works, F10 , F1 info page work in BIOS.
  8. yes, good, see , now you can boot to 7 things if want.
  9. but if the HDD is bad, you cant boot to that. if its bad.
  10. we run HDD test no as shown on the HP page on topic.
  11. then we try (2006 and newer) the F11 magic recover method.
if the PC is older than 2010, it can in fact have bad CCFL lamps
even PC that are desk tops , the eternal monitor same.
the flash light test. pre 2010 PCs
http://www.pcdied.com/monitors.html#flashlighttest
Sep 29, 2017 | HP Computers & Internet
My Dell E521 Desk Top Computer won't come out of stand by mode, what should I do?
Hi ,
When yo first start your computer , hit esc botton or f10 depending on what will take you to the start up mode and not the cmos settings , click on normal start up , if this does not work , take a bootable cd-rom and repair the system , dont reload windows ,..........Good Luck Roy
Nov 05, 2012 | Dell Computers & Internet
I can't get my desk top to connect to internet it tells me my ip address is not right but my lap top goes through my desk top and i don't have any problems getting on line.
your dell needs a network adapter card or wireless card installed is that the case(look in b ack)
if no wireless, then it needs an ethernet cable plugged into modem/router from cin bell and then in back of dell
please advise your network configuration
May 28, 2012 | Dell Dimension E310 PC Desktop
My Lap top HDD is not showing up when connected to my Desk top. my siemens lap top hinges broke. I tried working with it and damaged screen. Removed HDD drive and found a free case at home with the USB...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jul 12, 2011 | Silver Jeans MOBILE DISK HD-234-U2P...
Need to install my printer in my computer please.
if your trying to install this all in one with a disk try copying the disk to your desk top if from the web save it to your desktop diconnect from the web, disable your anti virus, then run the install from your desk top. this should help you out
Nov 02, 2009 | Lexmark X6170 All-In-One InkJet Printer
ECSpecialistTfilter
hi my window xp dotn getting '''c:\program filesa\ECSspecialisTfilter\shooter.exe'''
Jun 14, 2009 | Microsoft Windows XP Professional With...
Bios setting problem
This happens because Windows is corrupted.
You need to start the computer with a windows install disk, or a factory recovery disk inside to reinstall the system.
Get a windows install disk and reinstall the system.
Nov 17, 2008 | Computers & Internet
How do I change the boot sequence in a emachine model W3015 desk top pc?
You will need to enter the BIOS to change your boot sequence. Most likely you will need to press one of the following keys as soon as the computer begins to boot (this will occur a few seconds after you turn on the machine).
F2
F10
F11
F12
or Delete
More than likely one of these keys will be used to enter the BIOS. You should see some text that will tell you which key to press (if you see an e-machines logo when the machine first boots up, try pressing the ESC key to clear the logo).
Once you are in the BIOS you should be able to find the proper menu that will allow you to change the boot order. There will be instructions on the BIOS menu that will tell you how to make and save these changes.
Please let me know if you need further instructions.
Jul 29, 2008 | Computers & Internet
Computer won't boot up
you must hold down the F10 key( for system recovery) when you turn on computer. hold down as computer starts up,hopefully it will then repair itself and boot up. If not,start up computer holding down F12 for advanced diagnostics and run some test!! Good luck
Mar 06, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
Alun Cox
David Payne
David Payne
