Question about SP Systems Garden
Tsc countyline trailer sprayer
Having trouble maintaining pressure when the boom value or spray gun is used
SOURCE: sprayer wont spray or hold pressure
We use the both the 425 and 475 solo sprayers most days at work and when they start to lose pressure ( after 6 months of daily professional use) we purchase a complete seal kit and put it through them. The only part I can't work out how to remove is the inside cylinder, other than that everything else is easily removed and replaced.
Posted on Mar 27, 2009
jj505
  • 195 Answers
SOURCE: fimco atv sprayer troubleshooting
Are tips clogged??
Posted on Mar 31, 2009
  • 31 Answers
SOURCE: pressure no spray on 1 gal tank
try removing the tip and cleaning it. there maybe something stuck in it even if its new. if that dont work i would take it back to where i bought it. hope that helps
Posted on May 16, 2009
  • 202 Answers
SOURCE: not much pressure on fimco 15 gallon sprayer -
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Posted on Oct 26, 2009
  • 366 Answers
SOURCE: pressure is good, but very little spray is shooting out
you need to take your wand nozzle apart and clean it thoroughly. I would recommend taking it apart and making sure the entire unit is clean. Depending on what you spray through it, or how often you use it. May have to clean it more often.
Posted on Nov 07, 2009
Hozelock pressure sprayer , when I pump the sprayer the pressure release valve pops up loosing all my pressure
That's what it is designed to do when there is too much pressure, usually sprayers don't get used that much to ware out that part. You might be having trouble getting spray out the wand, in that situation it is probably clogged. You have to remove tip and see if you can clean out a little particle blocking it. I know it is easy to occur and it happens if some dirt falls into the tank while filling. Hope that helps.
Jun 09, 2016 | Hozelock Garden
Kobalt gravity spray gun and I have a little air that comes out constantly. Why is that and how do I stop it? Thanks
You must be using a "turbin" which is different and better than a compressor however a turbin runs all the time and air must escape from it unlike a compressor with an airtank the shuts off after the desired pressure is reached it shuts it self off then turns back on with tank pressure drops below what you have set it at- a turbin reaches the pressure you set the regulater at and maintains it constantly NEVER STOP THE AIR FROM PASSING THRU IT in fact a lot of times i do this to remove any dust i may have missed so evrything is working like it should on yr sprayrig..
perry tradesman
Oct 19, 2014 | Kobalt Large Gravity Feed HVLP Spray Gun...
Having trouble getting a good spray pattern when I use thick latex
You have two choices to fix this problem: First thin the paint and/or add a conditioner like Floetrol to make the paint flow properly. Second, use a tip with a bigger opening. On sprayer tips there is a three digit number (.ABC). The first number (A) is one half the spray pattern size when held 12 inches from the wall. A two will give you a four inch pattern, five will give you a ten inch pattern, etc. The last two numbers (BC) are the oriface size. For latex you should be using at least a .017 or .019 tip but if the paint has to be very thick you may need a .021 or larger.
Jan 05, 2011 | Campbell Hausfeld Airless Spray Guns &...
I have a gravity fed latex gun. It worked fine the first couple of uses, but now the spray is in consistent everytime. I,ve cleaned it out thoroughly numerous times and it will spray light followed by...
your air compressor is "cycling". you don't have a consistent pressure on the gun. I had the same thing happen with 2 different Husky paint sprayers....Turns out the sprayers were fine, I just had inconsistent air flow going to them....Turn your air compressor supply line down lower than the tank pressure and see if that does it for ya..........
Dec 17, 2010 | Garden
MY CAMPBELL HAUSFELD DH5300 PAINT SPRAYER WILL NOT SPRAY PAINT.
there are several issues that can cause this problem.
I will assume you have used the sprayer before so that will eliminate an incorrect air cap. The only other issues are paint viscosity, worn parts and the number one cause improper cleaning.
Be prepared for a complete disassemble of your gun. Depending on what you spray any residue can become hard as cement and it only takes a small amount to cause problems.
Below is a link to the manual that gives an exploded view of your gun.
Hope this helps but if not please let me know and I will trouble shoot further.
http://www.cpocampbellhausfeld.com/static/manual/www.cpocampbellhausfeld.com-dh5300.pdf
May 22, 2010 | Campbell Hausfeld Air Comp Basic Spray Gun...
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
LAWN SPRAYER PUMP WILL NOT SUCTION
Disconnect the sprayer boom hose from Y splitter, and dd another Y splitter, then reconnect the boom hose to one side of the added splitter. Add a washing machine supply (female/female) to the other side of new Y. now attach garden hose to washing machine line and turn on the water faucet with pump running. This will charge and/or backwash the pump. Once pressure is achieved, turn on the boom and check for fluid movement, then turn the washer supply valve on Y to off, and disconnect. The pump should be primed and be cycling fluid from tank and back to tank. Ready to shift to boom for use. I leave the washer hose and assembly zip-tied onto sprayer for easy future priming, and pump wash between uses.
May 02, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Garden Logo
Top SP Systems Garden Experts
Dennis Key
Dennis Key
john h
Are you a SP Systems Garden Expert? Answer questions, earn points and help others
