Question about Black Diamond Equipment Spot Led Headlamp BD620586
Change batteries black diamond headlamp - Black Diamond Equipment Spot Led Headlamp BD620586
No. Where can I order a battery pack?
from a battery shop
from the manufacturer on line
from e-bay
Oct 06, 2015 | Black Diamond Apollo Lantern
Battery Packs available? Where.
where di you buy the lantern? that is where I would look first .
HOW DO I CHANGE THE BATTERY
Any idea what model of headlamp you have?
http://blackdiamondequipment.com/en/faqs.html
Call: (800) 775-5552
Monday - Friday 8am-5pm, Mountain Time
Email: orders@bdel.com
Fax: (801) 278-5533
If you're in Europe and have a question, you can reach us at Black Diamond Europe by sending an email to climb@blackdiamond.eu. You can also reach our European office via phone or letter:
Black Diamond Equipment AG
Christoph Merian Ring 7
4153 Reinach, Switzerland
p: +41/61 564 33 33
f: +41/61 564 33 34
Oct 22, 2014 | Black Diamond Sport & Outdoor - Others
Can't open up to replace battery on headlamp
aspen643-
Look for a slot on the top. There will be a gray tab in it that must be pushed in while gently prying apart the two halves of the headlamp.
Hope this helps.
Regards,
DIYpro
May 05, 2011 | Black Diamond Equipment 620593 CHILI...
Where can I purchase replacement Black Diamond Bright Bulbs?
GearX.com sells them for $6.50. Hope this helps ! Matthew
Jan 20, 2011 | Black Diamond Bright Bulb
How do I change the battery?
There are two ways to charge the battery on this model spotlight. However, if you do not have the wall charger or cigarette lighter plug you will need to contact Black & Decker to see if they have replacement parts. In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
Aug 05, 2010 | Vector 2M Pwr Rch Spotlight
Watches CSX Diamond: how do I change the battery...
good day,
hope this link below will solve your problem.
watches
May 16, 2010 | Michele CSX Diamond watch
Low beam of one headlamp not working. Do I need new bulb or other possible cause? 50cc chinese scooter. thx!
With all bulbs on this lamp being LED the fault has to be the individual bulb. Unfortunately these are not repairable or replacable. Is the lamp still within warranty? If so I'd get it back to BD.
Hope this helps..
Aug 14, 2009 | Black Diamond Icon Headlamp
I need to change the headlamp bulb.
  1. Disconnect and isolate the battery negative cable.
  2. Remove screws attaching headlamp module to upper crossmember.
  3. Remove headlamp module from vehicle.
  4. Disconnect wire connector from back of headlamp.
  5. Remove bulb from headlamp unit.
INSTALLATION
CAUTION: Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
  1. Connect wire connectors to the back of headlamp module.
  2. Place headlamp module in position.
  3. Install screws attaching headlamp module to upper crossmember.
  4. Connect battery negative cable.
Mar 21, 2009 | 2003 Dodge SRT-4
Battery charging
I assume that your charger work fain and suggest to change your battery cause its seem that its gone.
Jul 19, 2008 | Black & Decker 50 Watt Electromate with...
Black Diamond Equipment Spot Led Headlamp BD620586 Logo
46 people viewed this question
Top Black Diamond Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Black Diamond Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
