Question about Jenn-Air Dishwashers
Jenn air dishwasher making lound noise when washing
aborcass
  • 2651 Answers
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Posted on Jan 25, 2009
  • 37 Answers
SOURCE: kitchenaid dishwashes makes wining noise during wash
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
Posted on Mar 16, 2009
SOURCE: Loud Humming noise every time we run the dishwasher
Hi, I had this exact same problem. In my situation it turned out to be the pump that pumps out all of the used water. It was rubbing up against the floor so that every time it turned on it made a loud vibrating sound. I just reached under the washer and put a piece of rubber between it and the floor and it solved the problem.
good luck!
I saw this post because I am considering buying the same model you have. Other than the noise problem you have, what do you think of it?
Posted on Apr 06, 2009
vortash
  • 431 Answers
SOURCE: jenn air dishwasher- making loud noise in operating cycle
Hi I am Vortash by the sound of what you are descibing your pump bearings seem to be shot , although it is making this sound is it still washing properly if so it confirms it is the bearing and not the impeller catching and making the noise the pump gets to quite a high pressure to wash the dishes .. sort of an enclosed hot jet wash the force of which drives the spray arms .. so I am afraid it looks like you will soon need a replacement pump.. sorry to bare bad news .. Regards Vortash
Posted on May 22, 2009
  • 22 Answers
SOURCE: Jenn Air dishwasher leaking
the emptying valve is underneath in the middle normally and it is what the drain hose connects to on the dishwasher. The drain hose itself is connecting with either a c clamp or hose clamp, check to make sure it is tightened all the way. Also do you have an idea of what part of the dishwasher the leak is coming from? If it is not the drain valve, then check to make sure it is not leaking from the door itself, as the door just has a rubber gasket that seals it and it might be that the gasket is bad. If it's not the door and not the drain valve, it could then be coming from the drainage pump or the motor for the dishwasher, which means the seal is broken and the motor or pump would need replaced. If you are unsure of how to do so then i would contact a repair technician to fix it for you.
Posted on Jul 19, 2009
Why has my dishwasher begun to make a whining noise when washing dishes.?
Clogged holes in spray arms or something blocking moving parts like silverware
Sep 15, 2012 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
2 year old stainless steel dishwasher making weird sounds
are u hearing any metal grinding sounds or is it making a noise like something is breaking theres a pump located down the bottom of the unit and depending on how you wash your dishes for example if you wash them before you insert them into the dishwasher or if you put them in with food on them would consitute your next course of action if you do insert them with food on them then you would need to check the pump and the chopper area you might want to call a technician if the problem persists. hope this helps try running it through the full cycle if tere is something wrong you will get an error code
Jul 13, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
High pitched squeel
Squealing is a bad wash motor- it will need replacing. Nothing is blocked here.
Jun 05, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
My dishwasher is just 6 months old and started making a humming sound while washing in th wash cycle.
If you hear unusual noises during dishwasher operation, check to see if a dish or cup is loose and being knocked around during the wash cycle. If you hear grinding, grating, crunching or a buzzing sound, chances are a hard object has gone into the wash module. Once the object is ground up, the noises should cease.
Apr 03, 2010 | Jenn-Air JDB6510 Built-in Dishwasher
Hi i have a jenn-air dishwasher JDB8910AWW about 10 yrs oldand started to have problems that it wouldn't drain now I can't get it to turn on..any advice??
I have a Jenn air dishwasher JDB8910AWW It fills with water but will not wash also i hear a clicking sound and the control panel blinks
Nov 18, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
Jenn air dishwasher- making loud noise in operating cycle
May 22, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Dishwashers Logo
19 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
