Question about American Pro Car Audio & Video
My american pro amp is 400w what type of fuse does it require? the bus fuse that goes on the amp
2 Suggested Answers
  • 631 Answers
SOURCE: American Pro Amp 1406
The best solution would be to replace the fuse holder.
If the fuse holder is for the push-in fuses, you can tighten the clips. Remove the amplifier from the power source (<VERY important). Use a small flat-bladed screwdriver to push the rounded part of the clip toward the flat part of the clip (these will be visible when you look into the fuse holder).
If that dosen't work, there may be broken connections on the circuit board.
Posted on Dec 21, 2007
How to attach 6 red wires on 1998 ford contour
The biggest diameter wire goes to biggest fuse. All the wires to the fuse box are the same. Doesn't matter which goes where. The alternator wire goes to the side of the panel. 175 amp fuse.
Feb 27, 2016 | 1998 Ford Contour
What is the fuse name/type
those are Red Dot Lamps. people most comonly know them as red dot fuses, ( whatever ) it just goes on the crossover to protect your hfd. if it blew you might want to take time to check your Tweeter.
Jun 03, 2011 | Peavey PR15 400w PA Speakers
Need a wiring diagram for a american pro 1406
Very simple :
12V+ = Red 8 Gauge Wire to positive battery terminal with a 30 Amp fuse
Ground = Black 8 Gauge wire to non painted surface on chassis of car.
Remote Turn on = Blue / white thin wire from radio's blue/white , this will turn on your amp.
A set of RCA cables which are self explanatory. Out to In or In to Out
Radio to Amp under carpet to back of vehicle along with your blue wire.
Then you have your speaker wires, you hook these up to your subwoofers.
Hope this helps, good luck.
Lex..
May 21, 2010 | American Pro VS1406 Car Audio Amplifier
It wont get power
Check the primary fuse on the positive amp wire usually located near the + battery post. Also check any onboard fuses. If these check OK, make sure the remote lead has 12V+ on it when the head unit is turned on. If these all check out, the amp is most likely defective.
May 16, 2010 | American Pro VS1405 Car Audio Amplifier
400W Black & Decker Power Inverter Doesn't Power My LCD TV
The problem of your inverter is from
your battery .your laptop and dvd
player requires little current to
operate.But you tv requires more power
to run, if your battery is low you it will
not last for 3 minutes. If your battery
has a low current rating, it will also be a
cause, for example, if it is below
100ampere hour. Lastly if your battery
is bad i.e. if it reads below the
stipulated dc voltage Require by your
inverter to operate.
May 09, 2010 | Black & Decker Power Inverter PI400AB
Video Card question...
It can support the card although the bus speed of the board could limit video thru-put. Another issue to consider is the wattage of the power supply which is at the low end of what is required. I would recommend a 400W minimum.
Apr 25, 2009 | IBM ThinkCentre M51 PC Desktop
American Pro VS1405
Sounds like the thermal protection on your amp is doing its job. You can put an external fan in to help in cooling, like the crossflow type shown here, or a couple of muffin fans like these (look familiar?). You may have fashion a bracket to mount the fan(s), but that shouldn't be too much of a problem. Many fans are shipped with mounting tabs attached.
Jan 27, 2009 | American Pro VS1405 Car Audio Amplifier
Dec 21, 2007 | Car Audio & Video
How to fix my amer.pro1000watt amp which has a burnt fuse an doesnt put out music
You blew the output transistors. They all need to be replaced. Check this for more info: http://www.techlore.com/article/14696/
Aug 14, 2006 | American Pro VS-2043 Car Audio Amplifier
Car Audio & Video Logo
Top American Pro Car Audio & Video Experts
xxxxxx xxx
Are you an American Pro Car Audio and Video Expert? Answer questions, earn points and help others
