Question about Westinghouse 24" Class 1080p 60hz LED LCD HDTV - Black LD-2480
Westinghouse ld2480 ,19", suddenly, i have no sound. I have tried the mute button, turning on and off, still no fix
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: I have a 42" Westinghouse
Let verify first to narrow down to where the problem can be, attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find. You may be better off if the sound does work through the PC speakers, to get the TV repaired; it will be more than $100 and up.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Aug 17, 2010
I have no sound on my westinghouse tv
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electro-medical.blogspot.com/
Dec 31, 2016 | Westinghouse Televison & Video
My audio is out on my Westinghouse Tv VK-42F240S. How do I fix it?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Spare parts are available at most of the electronic spare part selling shops.
Nov 10, 2014 | Westinghouse Televison & Video
Westinghouse 40" TV Model VR-4085DF goes on MUTE
Does the tv have soft touch buttons...If they do...They contain a gell which can harden over time and interfere with normal operation...either replace or disconnect soft touch control on TV and work with remote only...
Sep 08, 2014 | Televison & Video
Westinghouse problems
it could be the signal or the cables try connecting a working dvd player into another input and chec operations..
Aug 01, 2014 | LG 42PC3RA 42 in. HD-Ready Plasma TV
The sound on my TV went out all of the sudden. I was watching TV then all the sudden it was like the mute button was hit. The first thing I did was press the mute button a few time, still no sound. Second...
You should take the TV back to Bestbuy when you get the chance... Tv could of came defective from the factory. They should be able to exchange for a new one if you explain the problem to them.
Jun 30, 2011 | Dynex DX-LCD37 TV
Hi there, our amp is giving us very low sound output even when volume is turned up to maximum volume. We have been unable to find the remote and are wondering if the remote was turned right down would that...
I'd look at the front panel for the Mute Button and the Mute Indicator, but turn the volume down for any further investigations. If you can't hera the sound at 1/2 volume, it ain't there. No sense risking a sudden volume surge that will kill your speakers when you finally find the problem.
http://www.retrevo.com/support/Harman-Kardon-HK3270-Receivers-manual/id/386bh430/t/2/
Also check the T-Mon Indicator. If it;s on you have the Tape selcted for listening instead of a source.
Volume/Mute Indicator: This
indicator will glow green when the
HK3270 is turned on. Its position
will enable you to judge the relative
volume of the unit even when the
speakers are muted or turned off.
When the indicator is pointing
towards the left, at an "8 o'clock"
position, the volume is low; when
it is pointing to the right, as in a
"3 o'clock" position, the volume is
loud. When the unit has been muted,
pressing the Mute button ïâthe
indicator will flash
Dec 26, 2010 | Harman Kardon HK 3270
SPEAKERS WERE WORKING FINE AND SUDDENLY THEY STOPPED..I HAD THEM TESTED AND THEY WORK FINE . WHERE DO I GO ON THE PC TO FIX THE SOUND IF ACCIDENTELY WERE TURNED OFF??
Control Panel, Sounds (Or sounds and audio devices) look to see if the volume controls are muted and make sure your sound card is the default playback device
Mar 29, 2010 | Audio Players & Recorders
No sound to TV when MUTE button is turned off.
eeprom ic after you replace it you will have to have service menu to reset hori sink .
Dec 12, 2008 | RCA F32665 32" TV
Westinghouse 29" lcd stopped working all of a sudden. no picture, no sound. nothing.
The inverter provides power for the backlight for the screen, I would have thought you would have sound for a short while if it were that. I would go for power supply capacitors.
Apr 09, 2017 | Westinghouse LTV-20V4 20 in. EDTV-Ready...
Westinghouse 24" Class 1080p 60hz LED LCD HDTV - Black LD-2480 Logo
51 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
