Question about Kenmore 700 6972 Dryer
How to replace thermo fuse - Kenmore 700 6972 Dryer
I need to replace my Krups 453 Thermo fuse (ms-0061607). Where can I find one or is there a replacement?
Many times the Thermal (not Thermo) fuse is soldered in line with silver solder and unless you have the ability to cut the old one out and replace it, the cost would be greater than a replacement coffee maker.
Jan 05, 2015 | Krups ProAroma 453-71 Coffee Maker
Dont dry
thermo fuse is out replace it... if you dont see heat\flame\or flame bar get red, then your thermo fuse is out. cheap and easy to fix.
May 14, 2014 | Whirlpool Dryers
Te magna thermatic switch not kicking in
Drain the coolent, fan switch is usually on the radiator 2 wire switch disconnect wire coupler unscrew and replace.
Thermo usually on the head/ barrels or the thermostat if its exturnal (one wire switch) unscrew and replace.
Jan 27, 2012 | 2006 Honda VTwin Magna
Dryer does not start. I can hear the hummof it receiving power and have changed the motor and door switch.
Hi, I would check the white thermo fuse to see if it's blown. If the thermo fuse it bad it will keep the motor from running. Without a model number it's hard to give much detail, but here is a video that should be similar to your whirlpool dryer that shows you how to replace a thermo fuse. Most all Whirlpool Dryer thermo fuses are white in color. They show the most common one in the video, but your could be a little different shape too.
Aug 07, 2011 | Whirlpool Dryers
Volkswagon POLO 2001 Manual Problem: thermo fan not working. Hi all, I have since ordered and replaced the fan with a another fan and the fan still does not work!! Could it be the fuse? Initial...
CHECK TO SEE IF POWER GOING TO COOLANT FAN AND COOLANT FAN THERMO SWITCH.THERMO SWITCH LOCATED BOTTOM OF RADIATOR ON THE LEFT HAND SIDE.IF POWER GOING TO THERMO SWITCH THEN SWITCH IS FAULTY.IF NO POWER GOING TO THERMO SWITCH OR COOLING FAN.CHECK LARGE FAN FUSE IN THE ENGINE COMPARTMENT AND YOU HAVE FUSE 16 IN FUSE HOLDER.IF FUSES GOOD YOU HAVE SHORT IN THE FAN WIRE OR FAULTY FAN CONTROL MODULE.SHAKE FAN WIRES IF FAN WORKS PROBLEM IN THE FAN WIRES YOU HAVE A SHORT IN THE WIRES..
Jan 12, 2011 | 1996 Volkswagen Golf
Fault 14 on rinnai energysaver 556ftr
Hi.
Error code 14 is Overheating error.
The error can be caused by the high limit sensing overheating and cutting off. In that case the thermal fuse may not blow. The high limit can be reset tripping circuit breaker and allowing the unit to cool down with power off.
If that does not work , then the thermo fuse has blown
In fact tis unit has a thermo fuse. (refer to manual).The thermal fuse can be tested reading continuity. If thermal fuse has blown, then replace the the thermo fuse. If the thermo fuse blows again, then there is a condition causing overheating. b260351.gif
Here Full service manual.
Unless you are a trained technician call Rinnai support ringing the number in the manual. Some of testing and repair operations described are not suitable for the home user.
Regards.
Ginko.
May 31, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Whirlpool Dryer Does not dry
Its the thermal fuse. when you jump or, by-pass the cycle thermostat, you are basically by-passing the fuse as well. replacing the thermal fuse will fix thsi issue.
The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore undercounter dishwasher quiet guard
Presuming that your circuit breaker is not tripped and you have power to the dishwasher, it appears that your thermo fuse is blown. You can replace it for around $20. It comes in a kit form or you can replace the thermo fuse for around $1. The part number is NTE 8096 Thermo Fuse 98 degrees Celsius and solder it in yourself. It is located on the circuit board that contains all the relays and the main computer chip. It clips on and off.
Sep 14, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kettle lights but doesn't boil
Most likely the thermo fuse is blown.
You have to take the kettle apart and see the spec for the thermo fuse. You can get these at most any electronics parts supplier for appliances.
To change the thermo fuse you will need the proper crimp type connectors and the crimp tool. This is not able to be soldered. It runs too hot, and soldering in a circuit close to a heating element is not able to be used.
Before changing the thermo fuse, you can test it with an ohm meter. It should typicaly read about 0.1 to 0.2 ohms. The heating element resistance should typicaly read about 8 to 12 ohms.
If the heating element reads below 6 to 7 ohms on a well calibrated ohm meter, or above 15 ohms, it is defective.
If the thermo fuse is blown, the kettle may have been left running when boiled out and over heated, or there is a short in the heating element.
If you feel that you are not comfortable to do this type of repair, it would be best to give the kettle out to an appliance service centre to have it serviced.
When you change the thermo fuse, and if it blows again the heating element is probably damaged. It must be replaced if possible, or if worth the cost.
On the other hand, if the kettle is more than a few years old and you don't want to go to all this trouble, you may want to consider to simply get a new one.
Jerry G.
Apr 29, 2008 | Kitchen Appliances - Others
Goldstar Microwave
Could be the relay, an internal fuse. With the power off, open up the key panel and search for a fuse. Also, there are thermo sensors black, diameter of a dime and 3/8 inch thick with two wires. Check the fuse and replace if necessary. The thermo can be jumped out to test. Remove the wires, use a paper clip between them and tape it up. Briefly turn the unit on. Replace if it works now. The thermo is generally clamped to the wall of the oven behind the key panel. Never run without the thermo sensor.
Dec 18, 2007 | Goldstar MV-1501 Microwave Oven
Kenmore 700 6972 Dryer Logo
95 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
