Question about Sony Video Game Consoles & Games
PART NUMBER: 51101A230200R
OUTER GLASS BROKEN. TV still works fine. Need replacement glass. e-mail melmaniam@cox.net
  • 2976 Answers
SOURCE: broken glass on plasma tv
The glass is part of the screen. It will probably cost more to buy the part than a new TV would cost.
Posted on Mar 05, 2009
SOURCE: smeg se336ss 5 some so and so has broken the outer glass door!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Posted on Aug 08, 2009
  • 4 Answers
SOURCE: Remove Outer Glass Of Oven Door
On my Zanussi ZDF 866 it goes like this:-
Rest the door with its top edge on your work surface. Once the bottom two screws are removed, pull the outer glass away from the bottom edge of the door just enough so that the brackets fixed to the outer glass (into which those two screws went) clear the bottom edge of the door. Then pull the outer glass up towards you parallel to the door (there are now screws hoplding the top edge on this model).
It may need one side to be pulled and then the other to release it from the metal slot at the bottom.
I would recommend great care with this given that a) your door may be different, b) it could be held more tightly and c) you are dealing with glass. Recommend taking all precautions including eye protection and suitable gloves. Proceed slowly and carefully (this did not need much force on my door). If you're not sure at any stage, choose discretion and either give up or pay someone to do the job to avoid paying for a new glass or hurting yourself.
Hope this may help someone.
Posted on Jan 16, 2010
SOURCE: The glass has shattered in my electrolux eou6330x door
It will be difficult to find just the glass, have it shipped and fumble with getting it into those factory sealed doors. The entire door can be purchased for right about $50. Click here to see. There is not a picture associated with this item, but it is the correct part number.
GOOD LUCK AND PLS RATE THIS POST!!!!
Posted on Feb 22, 2010
Testimonial: "thanks"
  • 2501 Answers
SOURCE: emporio armani AR0203 face glass broken need to replace
If you have no joy anywhere else, you could try the Aramani service center. Below is an extract from their web site.
"If you have questions about Warranty or Repair please contact us at:
800-277-4013 Available M-F between 8:00am – 6:00pm CST
customerservice@emporioarmaniwatches.com"
Posted on Mar 06, 2010
Broken outer door glass
Hi, I don't know where you live, I live in France and here you can simply go to a DIY store and they will cut you a piece of tempered glass to size. Not cheap but may be cheaper than going to the manufactures. I have replaced my woodburner fire glass and that gets alot hotter than your oven outer glass. Hope that is useful
Steve
Jan 06, 2014 | GE Profile Spectra JBP95 Electric Kitchen...
Broken outer glass
Please can you help to find a part number for outer door
glass or is any other outer door glass suitable for
AEG MCC3880EM I can fit in? Many thanks
glass , how much it would cost or is any other outer door glass suitable for
Dec 07, 2012 | AEG Ovens
Outer glas of the dor broken its a QA make built
I will give you summary instructions on how to repair the door outer glass on a built in kitchen.
Prepare a space on a table, where to work on the door. Cover the taple with newspaper.
Remove the door. On some model you may just need to lift and pull, on others you need to free the hinges, usually undoing few screws.
Put the door on the table. Remove fragments of splintered glass if the glass is falling apart, otherwise leave it all in one piece.
On the table remove the set of screws that are holding the external frame and glass.
Remove external glass and replace it. You can use pliers and a cloth if needed.
Do operations in revers order to refit new glass.
You can find parts here:
Appliance Parts -Research, Repair & Replace.
Oct 14, 2009 | Ovens
Line in queens new york- have a panasonic plasma th-50pz800u craked front glass- still shows- looking to replace- anyone with contact numbers or web sites to replace glass. Thanks
try auction or surplus electronic sites buy a broken plasma screen tv unit ask the seller if the outer glass is good most like they only sell it if the inner plasma glass is broken try that sometimes this is the easiest way unless you want to pay full price and parts site..i do have a 42" front glass thats good but i dont know if this fits the 50". hope this help
Jun 24, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
Broken glass on front of plasma tv
Some, but not many have the front glass as a replacement, give me the model number so I can check. Oh, pioneer is getting out of the tv business this year ( soon ) if it turns out that the glass cannot be replaced or even ordered you might not feel to bad. They are one of the best at car audio, they decided to go back to the core of there business---------great idea!!!
Jun 04, 2009 | Televison & Video
Broken ts
yes you can take the glass out but leave the plastic that protects the screen. but remember your touch screen wont work if the glass is not replaced which can be a bit expensive
Dec 23, 2008 | HP Pavilion TX1000Z 12.1" Touch Screen...
Broken glass on plasma tv
Dec 08, 2008 | Daewoo DSP4210GM 42 in. Plasma Television
Scratch
hello, if there is a scratch on your reflective outer glass panel screen, it can be replaced if you are handy with tools or diy i happen to have the screen removal manual for this tv model th42pz700u you dont have to dissasemble the tv just the outer front housing remove the back panel and theres some screws that hold the front casing on those come of and the front refelctive glass can be removed without any trouble or dissasembly of the internals just the front casing
you may need to find a selling as is plasma tv with a broken internal screen usually they are this way that outer screen dosent break easily so unless you want to pay 489 for this reflective glass part i would try and find a 'for parts or repair 42 inch pany' they will fit if they are the same size make sure the outer screen is not broken or scratched. hope this help
Nov 29, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
I need to replace the outer glass on my Advantium oven
contact GE; they should have replacement glass in stock.
Apr 28, 2008 | GE ZSC2001FSS Advantium Electric Single...
Broken plasma tv screen.....nec model
SoCalRugger,
The plasma usually has 2 sheets of glass, the outer one sounds ok which is not good news as these can be replaced.
The inner panel is the actual plasma layer and if it is craked or broken it usually requires a swapout for a new panel.
Jan 25, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Video Game Consoles & Games Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
