Question about Microsoft Internet Explorer 7
I am a LAN user and i am using proxy setting for internet access
I am using LAN proxy setting for internet access and when i disable my LAN bcs i want to use my aircard data card for internet then the proxy setting by defacult it is not removing after the tick mark is off on that and make Ok but after that the Proxy setting is not removing. bcs of this his datacard is not working any sites pls provide solution for this
  • 4 Answers
The reason for proxy setting not to change is that there is some security software that is blocking the changes that is done on the computer
if you want to permanently set the proxy, tr to boot to safe mode and then set the proxy unchecked and rebooot to normal mode..
If this still does not solve the problem then there is a registry fix for it
Posted on Jun 19, 2009
De select. Use proxy server for your LAN
When asking for help you really need to tell us what you want and some description of your equipment. I presume you are asking how to disable your proxy for addresses on the LAN.
If you are using MS Windows go to the control panel and find Internet Options under Network and Internet.
Having opened it select the tab at the top labelled connections.
At the bottom press the button labelled Lan Settings. In here is the check box to turn the proxy on or off for LANs. Clear the check box to disable it.
If you are on a Mac (or iPhone) I can only tell you that its in settings under network somewhere.
May 21, 2014 | Computers & Internet
How do you disable automatic configuration ?
Hi Timothy,
You may want to try this steps:
If Google Chrome seems to take a long time to load a website or search, it may be configured to access pages through a web proxy. Check whether the "Resolving proxy" message appears in the lower-left corner of the browser window.
Follow these steps to change your proxy setting (for Windows):
  1. Click the Chrome menu snp_9721c573e41777fba43e1498ad084e3b160c_2696434_en_v2 on the browser toolbar.
  2. Select Settings.
  3. Click Show advanced settings.
  4. In the "Network" section, click Change proxy settings. This will open the Internet Properties dialog.
  5. Click LAN settings .
  6. Deselect the "Automatically detect settings" checkbox.
You can also visit this link for other solution for this issue. Hope it helps.
Feng Chia University Library
How To Configure Or Disable Google Chrome Proxy Server Settings...
Sep 21, 2013 | Google Chrome
Error 102 (net::ERR_CONNECTION_REFUSED): Unknown error.
Try this,
Go in control panel>internet properties->connections->lan settings->proxy server and uncheck use proxy server for your 'lan setting'
Hope it helps.
Aug 12, 2010 | Google Chrome
Error 102 (net::ERR_CONNECTION_REFUSED): Unknown error. means what and hw to cure?
Reference:
http://www.google.com/support/forum/p/Chrome/thread?tid=2307e04010c645c6&hl=en
Generally, in this case, you won't be able to access the internet at all, is this your symptom?
Go to start or windows logo,>settings in windows xp and/or control panel>internet options>connections>LAN settings> and uncheck use proxy server for your LAN.
Apply, and okay.
Close your internet browser and reopen it.
Jul 27, 2010 | Google Chrome
Error 102 (net::err_connection_refused): Unknown error. - This Shows up everytime i try to open Google chrome. - I tried running spyware bot and re-installing google chrome but it still doesn't...
A sudden "error 102" from Chrome while Firefox continues to work is a very common sign of a hijacked system.
Some solutions to an "error 102" from the Chrome website include:
checking for malware clearing your Google Chrome cookies making sure Chrome is excepted in the firewall settings ensuring correct proxy settings
Because FF works and Chrome doesn't, I would think that some malware has adjusted your proxy settings in Chrome. This is relatively common.
Go to Control Panel, click Internet Options. Under the Connections Tab, click the button "LAN Settings". Make sure the "Automatically Detect Settings" box is checked. Make sure the "Use a proxy server for your LAN" is UNCHECKED. Hit "OK" and all that jazz to make sure your settings stick.
If you still have a problem, make sure your computer is completely clean, clear all your cookies and stuff, and check for any programs that might be blocking Chrome's access (firewalls and antispyware). Hope this helps somebody!
Jul 02, 2010 | Google Chrome
Aircel gprs settings for sony ericsson w810i
GO TO MAIN MENU
TOOLS->SETTINGS->CONNECTIVITY->INTERNET SETTINGS ->INTERNET PROFIL->NEW PROFILE:
Homepage :http://google.com
User Name :Blank
Password :Blank
Use preferred Access Point :No
Open Access Point Setting
Proxy:Enabled
Proxy address :blank
port :8081
Then Disabled the proxy again
Data Bearer : Packet Data
Bearer Settings
Access point Name
aircelgprs.po (Postpaid)
aircelgprs.pr (Prepaid) don't give space between letters
Switch off and on
now u can use GPRS
Please check and revert
Feb 15, 2010 | Sony Ericsson Walkman W810i Cellular Phone
How to fix error HTTP 403 Forbiden i can't log on bitsoup i keep getting 403 forbiden ....thanx for help
This error message means :-
403 - Forbidden - You can't access the page. You may not have access (it may require a password), or it may be blocked from your domain.
or your Internet site parent controlled site blocker.
Oct 28, 2009 | Dell Inspiron 1525 Laptop
Error code 80048820
MSN Message error 80048820, unable to signin
Problems:
- While you try to Sign in MSN Messenger you getting an error message with the no. 80048820
- Unable to Sing in
Probably reasons-
- Your system time/date incorrect
- Internet Proxy setting incorrect
- softpub.dll disable/missing
- Firewall does not allow to access, etc.
Solution-
Step#1
- Remove Internet Explorer proxy server settings and check the 'Automatically detect settings'.
- Launch Internet Explorer, click "Tools" and then click Internet Options. From the Internet Options dialog box, go to the Connections tab. Click LAN Setting. Uncheck the Use a proxy server for your LAN checkbox. Finally tick/check: 'Automatically detect settings'.
Step#2
- Correct the computer system's Time/Day as current (if required).
Step#3
- Click Start (Button), and then click Run, type regsvr32 softpub.dll click ok.
Step#4
- Turn off the firewall. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
Reference from:
http://www.trulybangladesh.com/itnews.php
Aug 12, 2008 | Computers & Internet
Microsoft Internet Explorer 7 Logo
219 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
