Question about Mach Speed Trio Stealth Pro 9.7C 4.0 9.7" Tablet PC
Trio stealth-8 MST8-21 9.7" freezes at "@9 dual core" screen.
Starts to load, then freezes at 2nd screen. Have done a reset and did not resolve the problem.
My trio stealth 10.1 is getting stuck on the@9 dual core load up screen. what do I need to do to get it to finish loading??
HI Naomi.
I do alot of TRIO fixes. Here is a great youtube walk thru. If it does not work I can try some other fixes but they can wipe out all your settings and data.
Good luck
Chadman TRIO 10 1 g2 Stealth Elite Android Tablet Update 2 Testing Recovery Mode...
Nov 24, 2014 | Tablets & eReaders
My trio stealth -9 shows first screen with that on it next screen shows@dual core then it want do anything else what and how can I fix this
Hi, try to connect it to your computor, and try to access....if nothing, then you will have to do a software redo.....
Jun 21, 2014 | Tablets & eReaders
I have a Trio-Stealth G2-8 and turn on but the screen said @9 Dual Core and don't do anything else can somebody tell me how to fixed?
Its a common problem with tablets and not easy to fix.
Your tablet has a corrupt os and is caught in a boot loop.
There are fixes but not easy for a beginner.
Boot into recovery mode by pressing the power button and holding the down volume button in then select restore tablet from the recovery menu.
Jun 12, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
My trio stealth g2 hype 4gb tablet will not go pass the trio stealth g2 logo it just freezes up what can i do
Have you tried my old trick of pressing the on/off button and at the same time, press the volume+ button. Sounds like you have a screen freeze. hope it helps.
LindaSView
Apr 24, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
FREZZES ON THE 9 DUAL CORE
Hi:
Try my generic fix for tablets. Press the on/off button and at the same time, press Volume+ button. Seems to have worked for many people. If it doesn't you may have a virus or you may have to try and reset it back to when you first got it. Hope my generic "freeze" fix, works.
LindaSView
Apr 02, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Trio stealth-8
I fixed this triple screen issue by opening the unit (2 screws, then slide fingernail around the edge), then reseat the video connector (it's the largest connector), flip up the locking tab, then reseat the connector & flip the tab back down. Test it, then close it up.
Jan 19, 2014 | Tablets & eReaders
How to restart a trio stealth G2
all that shows is trio stealth G2 when turned on it freezes I tried the reset button
Jan 07, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
Mach Speed Trio Stealth Pro 9.7C 4.0 9.7" Tablet PC Logo
361 people viewed this question
Top Mach Speed Trio Tablets & eReaders Experts
Brett Duxbury
Brett Duxbury
Lawrence Oravetz
 Grubhead
Grubhead
Are you a Mach Speed Trio Tablet and eReader Expert? Answer questions, earn points and help others
