Question about Sport & Outdoor - Others
Disadvantages of an airport watch tower - Sport & Outdoor - Others
Is it common that small local airports don't have radars?
It is very common for small airports not to have a control tower, radar, or communications equipment. There are very well developed procedures for "uncontrolled airports". There is a standard traffic pattern that aircraft fly at almost all airports (consisting of a downwind, base, final, and upwind leg) and there are specific radio calls that are supposed to be made at certain points in the pattern. Most airports have a fixed base operator to supply fuel and services. They often monitor the common traffic frequency and supply some info to pilots about wind direction and runway in use. There's also a specific way to enter the pattern - usually at a 45 degree of the downwind leg, Yes it's possible for aircraft to collide and it happens several times a year - usually when a low wing airplane is above a high wing airplane in the pattern. Neither can see the other so occasionally that can happen.
Jan 04, 2017 | Aircrafts
How is a pilot supposed to find out their distance in miles from an airport they're landing at?
Using the old (pre GPS) method you would use the sectional and plotter (aviation ruler) and measure the distance. Using a GPS you can usually turn on distance rings on the screen or if you have the airport selected as destination you can read it right off the screen. If it's your home base you should learn the landmarks and their distances from the airport. In the Miami area, there are so many airports and landmarks, if you're flying there, during your preflight preps you should measure out distances to some landmarks that you plan to pass over and mark them on the chart or flight log.
What are advantange and disadvantange of a watchtower
Think about it, if the farmer is up a watch tower he can see further. That's definitely an advantage.
But if he is up the watch tower and something happens to his sheep he will have to run all the way down to the bottom before he can deal with the situation. that has to be a disadvantage.
Mar 11, 2015 | Ambir Technology Office Equipment &...
How to view date in Sonata super fibre watch model ND7965PP04J?
Ask them:
www.sonatawatches.in
Corporate Address:
Golden Enclave Tower A, 4th Floor,
HAL Airport Road, Bangalore - 560017
Karnataka.
Toll Free No.:
1800 266 0123
Phone:
+91-80-66609000
Email:
helpdesk@titan.co.in
Jul 06, 2014 | Watches
Disadvantages of foreigner in south africa
It can be a dangerous place. Current warnings are
- high level of crime generally. Always lock car doors if driving. Be alert. Do not stop for strangers, objects on the road, people apparently in distress, or drive in remote areas.
- theft from hotel rooms is common
- targeting by criminals occurs at the airports. They follow you.
- plastic wrap your luggage
- certain areas no-go for visitors. Check first
- high level of HIV-AIDS, so extreme caution advised if having liasons
- large gatherings can turn violent. Avoid these
- going to bars can be risky. Never accept drinks from strangers, or even mixed drinks from a barman
- only go on trains, buses, or tourist spots in a group
- don't use public ATMs
- don't display valuables, phones, watches. A large gun is OK
All in all, don't even go there.
Mar 14, 2014 | Sport & Outdoor - Others
I want to know aigor watches website
Hi sunny
As of now there is no such website.
Let me tell you that the Aigor watches are sold primarily by AVA Merchandising company through their outlets at major airports across India. You can email them at shoplite@avamerchandising.co.in
For any further information you can visit your nearest airport and the AVA outlet there.
Regards TDCL
Nov 11, 2010 | Watches
Aigor watch showroom at bhopal
Hi
You can try at Bhopal airport. Go to Bhopal Airport. Check for AVA merchandising outlet. That's the only place to get your Aigor watch.
Regards
TDCL
Oct 27, 2010 | Watches
I was presented with an Aigor wrist watch, I need to know where it is manufactured, how much is it worth? And what are the differnt models of this watch.
Hi ghoshsuchari
The watch company claims english background and AVA is promoting it through its collaboration with different airlines.
Hence it comes at a discounted rate. For any further information you can visit your nearest airport and the AVA outlet there. Show them the model and get to know the worth. Hope now you have more visibility.
Regards TDCL
Oct 25, 2010 | Watches
Hello, i recently bought an airport card off of ebay and installed it in my G4 tower (mirrored drive doors). the OS has been upgraded to Leopard. I cannot get it to turn on. When I try to configure...
Hi Kathy
What message do you get? does it say anything like "Not airport card found" or something similar.
A couple of things to check. First make sue that the card itself is fully home in the socket. Second, make sure that the arial lead is properly connected. It is really easy to think that the arial is connected when it isn't. The plug is a very close fit. it should click into place and you should not be able to get a finger-nail between the plug body and the card - if you can it's not connected.
Failing that, the card may well be faulty - sometimes happens with eBay.
Oct 28, 2009 | Apple iMac G4 Desktop
Install an Airport card in a G4 Tower
There are six models of Power Mac G4 computers: AGP Graphics, PCI Graphics, Gigabit Ethernet, Digital Audio, QuickSilver, and QuickSilver 2002. You cannot install an AirPort card in the Power Mac G4 (PCI Graphics); the rest accept original version 1 Apple Airport cards. The card is simply inserted through an opening in the PCI card guide and seats itself into a socket on the logic board. Then you attach the loose antenna cable to the hole on the end of the Airport Card. You're done.
Oct 16, 2009 | Apple iMac G4 Desktop
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
