Swan SW3020W my Swan SW3020W washing machine is displaying error code e2 and e9
IrishDruid
  • 2712 Answers
SOURCE: NEC NW-491 washing machine. I
This usually indicates a problem with the water pressure sensor or the water level switch. A defect--or an obstruction--in the water-level switch may cause this issue. Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open
Posted on Sep 28, 2008
SOURCE: dwd f1011 washing machine, error codes E2&E9, machine not working
the E9 error code problem could be with door switch wiring, the door switch or the control board.but E2 problem occurs when a button is pressed for more than 30 seconds.Check for any such button else the problem is surely with the control board.
Posted on Jan 11, 2009
SOURCE: NEC washing machine displays E9
fault code e9 relates to pressure sensor.
check connections or replce pressure sensor
Posted on Jan 23, 2009
SOURCE: E2 error on homemaker washing machine.
I have an E2 error on the display of a homemaker washing machine model no HMWM8000. It will not pump out. The PCB does not have any visibly damaged components, which part is faulty, and how do i test a water level sensor.
Posted on Nov 08, 2009
SOURCE: my AW-1170S toshiba washing machine
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Posted on Aug 28, 2011
What does E2 error mean
Generic pump error
Error Code-control panel display "Err2" (Error 2, Error2) ' question ...
www.haier.com/za/help.../washing_machine/.../question/.../t20140313_209219.shtml
  1. Cached
  2. Similar
Mar 13, 2014 - Error message:Drain error, water can be not drained fully within the required drain time (controlled by PCB software). Reason 1. Pump filter is blocked. Solution 1. Please open and clean the pump filter. (Filter access door is on the bottom right, at floor level of the washing machine). Step 1.Push a flat blade ...
How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front ...
9k=? 5:23 https://www.youtube.com/watch?v=by94vOVmmhQ
  1. Similar
Mar 18, 2017 - Uploaded by Nancy Gurish How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front Load Washer Stopped, Repair Of ...
Washing Machine Error Codes - Front Load and Top Load Washers ...
https://removeandreplace.com/.../washing-machine-error-codes-front-and-top-load/
  1. Cached
  2. Similar
May 5, 2015 - F9 followed by E1 - (drain pump system error) F5 followed by E2 - (door will not lock) F7 followed by E1 - (motor drive error) "rL" - (remove load) Washer making error beeps - Door has not been opened and closed for at least 3 cycles. Washer beeps when HOLD TO START is touched - Door not closed
Mar 22, 2018 | Washing Machines
E9 DISPLAYED IN WASHING MACHINE DAEOO MODEL DWF320LR WHAT IS THE PROBLEM
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
Jun 01, 2017 | Washing Machines
Hi ive got a swan premier sw3020w washing machine there is water pumpingout of a circle at bac of washer when rinsing/spinning what could be wrong with it x
Go to www.repairclinic.com and add your model number. Sounds like a ripped hose inside. They have great videos that will help you
Nov 01, 2016 | Washing Machines
E9 E2 ERROR
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
Nov 13, 2010 | Washing Machines
Dwd f1011 washing machine, error codes E2&E9, machine not working
Jan 11, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washe machine problem
The sound become beet? We need a little more detail. Look in the owner's manual and tell us what is error e9.
Feb 26, 2007 | Daewoo DW500M Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
