Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Water dispenser only works part of the time
I will try to fill up a glass of water, and it will work and then making a clicking noise and stop. You can wait a minute and try again and it will do the same thing. Any ideas on how to fix this would be great. Thanks in advance
  • jackiestadle Jun 20, 2009
    Thank you so much. That is exactly what is making the noise and we are ordering the part to fix it. I really appreciate your help.
    Jackie
  • Kenmore Master
  • 4,655 Answers
Sears has a different and confusing model number. Look on the bottom of fridge with fresh food door and look for a number like 213.254879 That is how they code their model numbers. I think you will need to have a look a replacing the water control val. That is on the back of the refrigerator. If the solenoid weakens it begins to vibrate/buzz because it dones not have the strength to open the water valve. Let me know, Thanks, Sea Breeze
Posted on Jun 18, 2009
  • John Tripp
    John Tripp Jun 20, 2009
    You are welcome, please rate me..Thank You, Sea Breeze
Samsung refrigerator dispenser makes noise after filling water glass
You may need to have the water filter replaced. This sounds like it is starving for water as it refills.
Feb 03, 2013 | Samsung RFG297AA (285 cu ft) Bottom...
Water dribbling out of dispencer whirlpool american fridgefreezer
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser is not working
Does it make ice? If it makes Ice, then you have water to unit. If No Ice and No Water, check water supply. Otherwise, you could have a bad water valve. Remove valve and the line coming off of valve to water reservoir try to dispense water and if valve is good you should have water coming from valve. (have a bucket or bowl handy to catch water).
Mar 28, 2010 | GE Refrigerators
Ice maker is not making ice. Water dispenser is working. It sounds like it is trying to make ice (clicking noise).
the first thing to check is the fill tube and make sure there is no frozen water blocking the tube.if there is no water blocking the tube then make sure you water fill valve is good you might have to replace the ice maker itself.
Feb 24, 2010 | Frigidaire PLHS237ZD Stainless Steel Side...
Our fridge is a little over 6 years old and everything has worked fine until now. Earlier in the day I was able to fill up a glass of water no problem but now no water is coming out of the dispenser. The...
Usually that is from the water line freezing up. Behind your refrigerator drawers there is either a plastic tank or a coil of plastic tube........That is where the water runs so your dispenser puts out chilled water. If your fridge gets too cold that will form ice inside and stop the water from flowing. You can defrost it with a hair dryer or just let the fridge sit open for a few hours. Another thing could be the water valve. When you press the water lever on the dispenser do you hear a noise? Kind of a humming noise. Well, that is your water valve, so if you hear it then it is probably working.
Sep 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge side by side refrigerator
what is your serial #
Jan 06, 2008 | Refrigerators
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
79 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
