Question about American Standard Home
Hydromassage 1063 is it normal that the two jets on your back don't push as hard as the four on the sides????
3 Suggested Answers
  • 659 Answers
SOURCE: several jet vents have hardly any flow coming out
These tubs often have an adjutment on them that control how hard the jet blows. You may have to adjust them. There isn't anything that can get into the lines that will clog them so I can't think of anything else it could be.
Posted on Apr 02, 2009
uspartscente
  • 717 Answers
SOURCE: I bought a house with a american standard jet tub
yes. You will find a replacement pump at the following stores:
US Parts Center
Bath Parts Plus
Posted on Jan 25, 2011
Jets not working in spa on one side
the other jets work off a 2nd pump make sure it is on
Aug 26, 2014 | Pool & Spa
Hydromassage 1063
Not normal for that to happen but the jet faces on the two back jets may be turned off or down.
Try turning the face of the jet clockwise and see if you get more water flow out of each jet.
Rod
US Parts Center
Apr 13, 2014 | American Standard Home
Do a 2007 suzuki four wheeler LT-A400/F have a fuel pump?
make sure the carbeurator's low jet is working properly and not clogged
Nov 11, 2017 | Suzuki GT 380 Motorcycles
One of the jet assemblies on my Jacuzzi 325 hot tub popped out and I can't get it to stay back in. i've been pushing it in as hard as I can but when I turn the pumps on it pops back out. Should I be...
once a jet face has fallen out of a hot tub that means the insert has failed and is broken. you will need to locate a new jet insert. Jet inserts have little tabs on them that hold them in place and when they get worn out the jet face will fall out into the tub.
Jan 29, 2011 | Jacuzzi Home
Wont stay running
under neath the carby is a single brass bolt, undo it
that one bolt is a multi jet, find four holes use a fine pin and carby cleaner ,hint one is at the top were the thread starts , one is in the inside center and two in the sides put it back in and prim and start, hope it helps
Jun 15, 2010 | Mtd 22" Yard Machine Push Mower
Whirlpool Jacuzzi with 10 jets one stopped working.
either one of ur hoses has come off or is stopped up get to the sides and see if one has come off
Feb 24, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Honda shadow 1100 will not idel unless choke is all the way on
Okay, let me see if I can help you out...it may not be the jets in the carburetor. Hondas, like most other street bikes, have an idle adjust screw on the carburetor. Most times, you can adjust that screw to get your idle at 1000rpm, which is the norm for idle speed.
The screw is not hard to identify; the easiest way is to first, take the air cleaner and intake off. Then watch the carburetor throttle linkage while you twist the throttle. You will see where the throttle cable connects to the carb and there will be a spring-loaded screw right there. Turning that screw adjusts the static (idle) position of the throttle plate; turn the screw so the plate moves in the same direction the throttle cable pulls it.
I'm willing to bet that adjusting this screw will get your idle back to normal. If it doesn't, come back here and let me know; I will then lead you through a procedure to fix the carburetor. Cheers!
Jan 29, 2010 | 1998 Honda VT 1100 C3 Shadow Aero
Back fireing
make sure you have your firing order correct check the gap settings on your plugs adjust jets down aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Apr 24, 2009 | 1993 Chevrolet C/K 3500
Help me please
hi
try your settings
menu
settings
select settings
change the lanuage to english
select
try now see if any better.
riz.
Jun 19, 2008 | Samsung SGH-E900 Cellular Phone
Home Logo
26 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
