Elite 940 series washing machine, on starting the machine it is not filling with water but starts working immediatly,the solnoid is ok but no power is getting to it to let the water in. the same happens at spray rinse.
  • 15,935 Answers
It appears your dual inlet water valve or timer (CCU) has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
Will not fill with water
check hose is not kinked and tap is turn on. if both ok turn off water remove hose check filter that is inserted into the fill adapter where the hose fits to the machine is not blocked, if all ok to this point fault could be fill level detector, fill solenoid valve or programmer out put
Apr 09, 2014 | Washing Machines
Kenmore Elite 665.17053400. Powers up ok, fills up with water ok, but wash cycle won't start. I can hear the motor trying to turn but sounds like its seized up. If I cancel the wash, the machine drains...
This dishwasher has a very sophisticated wash system. In order to improve the wash efficiency it uses a chopper and a soil sensor. It is very likely the chopper assembly is clogged which is blocking the water from circulation and straining the wash motor.
See this diagram. Item 6 is the chopper. Worst case is the pump motor needs replacement. This is item 10.
Good luck
May 27, 2011 | Kenmore Dishwashers
I have a series 90 washer and it just stopped and is full of water. It will not power up. where should I start?
must be overload trip. drain water first. reduce load. restart. if doesn't work, check CB or fuse inside the machine
Mar 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Wmd 940 wont fill,, water pressure ok,hose ok,f01
Solanoid. does it fill on any other programe. try hot wash, then rinse
Feb 01, 2010 | Hotpoint Washing Machines
IT wont start washing
if it fills with water or has filled and wont go any further then suspect the door switch< latch assembly has switch> if it doesn't fill then possibly water valve not working,if neither of these seem accurate then please give more info
Apr 20, 2009 | Kenmore 42822 Front Load Washer
Kenmore Elite washing machine won't complete a full cycle
its a error code for not enough water fast enoght or no water. check fill bibs are on and screens inside fill valve are clean if ok . make sure you do not have steel branded flow retrickers fill hoses it if so replace hoses. washer has to get a amount of water fast or it will code out
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Over flowing washer
If the water valve not getting 120 volts and its start filling that means its bad water valve if its getting 120 volts bad timer
Nov 03, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washing Machine will not start washing
turn it to drain spin if it works there change the pressure switch
Jun 02, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
