Question about VuPoint Solutions VuPoint Photo Cube IP-P10-VP
Won't print Put my iphone as I always do and it doesn't seem to connect. It's states waiting... & then reconnect demand!
Apple i phone 4s sim unlock code telus
Hi, You can unlock an iPhone 4S locked to Telus network using remote unlocking service. This method of unlocking is safe, simple,. affordable and quick. you can get the remote unlocking for an iPhone 4S from www.prounlocking.com/apple-iphone-4s/rs16wp9/ at affordable cost with easy instructions on unlocking. This method of unlocking also doesn't require a Jailbreak too.
UNLOCKING STEPS FOR AN iPhone 4S
1. Wait for us to send you an email saying your phone has been activated or remotely unlocked.
2. Install the latest version of iTunes.
3. Make sure your Apple iPhone 4S phone software is updated to the latest version using the iTunes software.
4. Connect your Apple iPhone 4S to iTunes with a NOT ACCEPTED SIM card.
5. Wait until iTunes detects your Apple iPhone 4S.
6. Disconnect your Apple iPhone 4S and reconnect it after 10 seconds.
7. Your Apple iPhone 4S is now unlocked.
Oct 31, 2012 | Cell Phones
Tip
Apple iPhone hard reset If iPhone won?t turn on, or if the display freezes or...
If iPhone won’t turn on, or if the display freezes or doesn’t respond
•Press and hold the Home button below the screen for at least six seconds, until the application you were using quits.
•If that doesn’t work, turn iPhone off and turn it on again. Press and hold the Sleep/ Wake button on top of iPhone for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
•If that doesn’t work, reset iPhone. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
Updating and Restoring iPhone Software
You can use iTunes to update or restore iPhone software. You should always update iPhone to use the latest software. You can also restore the software, which returns iPhone to its original state.
If you restore, all data is erased from iPhone, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone settings are restored to their original state.
1.Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes.
2.Connect iPhone to your computer.
3.In iTunes, select iPhone in the Source pane and click the Summary tab.
4.Click “Check for Update.” iTunes tells you if there’s a newer version of the iPhone software available.
5.Click Update to install the latest version of the software. Or click Restore to restore iPhone to its original settings and erase all data on iPhone. Follow the onscreen instructions to complete the restore process.
Resetting iPhone Settings
Reset all settings
Choose General > Reset and tap Reset All Settings.
•All your preferences and settings are reset. Information, such as your contacts and calendars, and media, such as your songs and videos, are not deleted.
Erase all content and settings
Choose General > Reset and tap “Erase All Content and Settings.”
•All your information and media are deleted. You must sync iPhone with your computer to restore contacts, songs, videos, and other information and media.
Reset the keyboard dictionary
Choose General > Reset and tap Reset Keyboard Dictionary.
•You add words to the keyboard dictionary by rejecting words iPhone suggests as you type. Tap a word to reject the correction and add the word to the keyboard dictionary. Resetting the keyboard dictionary erases all words you’ve added.
Reset Network Settings
Choose General > Reset and tap Reset Network Settings.
on Mar 10, 2010 | Cell Phones
Lexmark x7550 won't communicate with computer to scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/ngaKcu. Select your operating system, download and execute the file.
Oct 19, 2011 | Lexmark X7550 InkJet Printer
I dropped my iphone and it said no sim, i put it back in but now the home button doesn't work and it won't charge a and my computer is not registering it when I plug it into the usb port, is there...
Hi
its seems like you have loose connection inside of phone. because home button and charger port have same pin connection.
My advice is you have to take your phone to technician.
thank you.
Sep 07, 2011 | Apple iPhone Smartphone
Lexmark X4650 prints fine & used to scan to computer, now when press scan>scan to computer>downloading application list & seems to freeze.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
Aug 31, 2011 | Lexmark X4650 InkJet Printer
Scanner stating cannot retrive application list for my lexmark x5470
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/dbCiI6. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 25, 2011 | Lexmark X5470 All-In-One InkJet Printer
Why won't my printer print after I installed the software? It says its ready but nothing will print
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 18, 2011 | Lexmark PhotoJet Z705 InkJet Printer
WHEN I TRY TO SEE RECENT CALL HISTORY THE I PHONE 3 GS REVERTS TO THE HOME SCREEN. IS THERE ANY WAY OF RESOLVING THIS?
hello,ensure you are not clicking on the key wrongly,i would advice you put the phone off and on back to see if the problem stops.if it doesn't i would also advice you ensure you close any application you are not making use of.it could also be as a result of accumulated opening of applications. if that does not stop the problem,i would suggest you get the phone flashed by a mobile phone authorized repair engineer around you.
wish you good luck,
take care.
Jun 30, 2011 | Apple iPhone 3G
Ink cartridge (not) installed properly
unplug machine from power outlet. take all carts out. wait 5 min. plug machine to power. wait until machine demands carts. reinsert carts and make sure they are secured. answer display when asked if you have changed.
If you still have the error message use a original brother cart.
Dec 16, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-215C
unplug machine from power. remove all carts. close cover. reconnect machine to power. wait until machine demands carts. reinsert cart as demanded by machine and secure them by pressing them into position and fixing the clip above the cart cover. give correct answer as display asks. Set date and time again.
btw: always print until printer stopps printing! Never change cart befor that
because printer logic will be fooled ;-)
Nov 11, 2007 | Office Equipment & Supplies
VuPoint Solutions VuPoint Photo Cube IP-P10-VP Logo
71 people viewed this question
Top VuPoint Solutions Office Equipment & Supplies Experts
jasbo
jasbo
Are you a VuPoint Solutions Office Equipment and Supply Expert? Answer questions, earn points and help others
