Question about OKI C5100n Laser Printer
Printing problem - crinkled paper
Printed page comes out with crinkles in paper
flopez
  • 161 Answers
SOURCE: Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Posted on Sep 22, 2007
samkong
  • 106 Answers
SOURCE: Top print margin shrinks.
It's a software problem, you have to uninstall the printer and reinstall it then it will be ok.
Posted on Oct 13, 2007
eagle338
  • 4889 Answers
SOURCE: Skipping Pages
You can check out this software it is possibly the easiest way to solve this problem..Works gr8 for me..
http://www.graphicshighway.com/
Posted on Oct 24, 2007
sir fixalot
  • 146 Answers
SOURCE: oki c5200 prints double on page
Sounds like the fusing unit needs to be replaced.
Posted on Nov 18, 2008
Ranjanraj
  • 15 Answers
SOURCE: Prints the papers shifted up
hi,
check the Teflon sheet in printer. may be it broken off
Posted on Dec 22, 2008
When printing paper comes out all "crinkled" maybe roller problem?
It the paper comes out crinkled or accordion looking then it is your fuser. Check where your the paper comes out of. There might be a piece of paper jammed in there that is causing this. If no obstuctions then it might be the roller on the fuser cracking and cause it to crinkle the paper. The fuser is the last thing the paper goes through before coming out. It "fuses" the toner to the paper.
Apr 26, 2010 | Brother MFC-8660DN 5-in-1 Laser...
Only on Quicken to 3210 all-in-one printer. Paper starts to feed then indicates paper jam, wait long enough and paper feeds with crinkle and no print.
I would check the paper path on the printer where it is crinkling the paper. More than likely there is some small piece of paper or something that is causing it. Does it only do this out of quicken? I wouldn't think so if the paper comes out damaged....
Feb 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
Paper is coming out wrinkled in one spot
Most of the crinkled paper issues I deal with have to do with the fuser roller lining going bad. If this is your issue the crinkle will be a vertical line from the leading edge to the trailing edge. You will need a new fuser.
Jan 30, 2009 | HP LaserJet 2840 All-In-One Printer
Crinkled paper
Pop open door to make sure nothing is stuck near rollers. Could be paper, staple, paperclip, etc. Clean out and try again.
Is it the same paper you always used?
Feb 26, 2008 | Brother MFC-8460N All-In-One Printer
PAPER CRINKLING
First check the paper path for something in the paper path. Staple, paper clip, etc, causing the paper to twist. Reseat the imaging unit and see if the transfer unit is seated properly.
But, What sounds most likely is that the fuser needs to be replaced. The rollers are most likely getting pretty bad inside that unit.
If I recall correctly, it is in the $200 range to replace.
Feb 16, 2008 | Xerox Phaser 6250DP Laser Printer
Paper crinkles for fax or copies
either your feed rollers are bad or there is a piece of paper stuck
Dec 05, 2007 | HP LaserJet 3030 All-In-One Printer
Crinkled paper
It sounds like a fuser problem. You may have something stuck in it, or the lower roller could be defective. You may have to replace the fuser.
Nov 01, 2007 | Lexmark E320 Laser Printer
OKI C5100n Laser Printer Logo
37 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
