Question about Xerox Phaser 6360 Laser Printer
WANT TO FIX ERROR CODE 6000 PRIXMA 6360 WITH MAC
My copier rich mac 6000 has a sc 484 error what I can do
Look it up online "error code sc484 + make and model". You should get hits.
Jul 24, 2015 | Office Equipment & Supplies
Canon image RUNNER 6000 Copier error E 000001-0000
there is a problem in fixing unit. You can try to reser error code in service mode, but if the error persist after clear, you need to rectify the problem and replace fault component is fixing assy. The problem can be in thermistor, sub thermistor or dc controller pcb, or ... call service!
To reset error code:
while ready to copy/showing the error code:
1) Press the user mode key ( * ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( * ).
Choose: COPIER>FUNCTION>CLEAR>ERR
Turn off and back on the copier.
Aug 22, 2011 | Canon imageRUNNER 6000 Copier
My canon ir 6000 is showing an error codes E000001-0000 How it will solve?
Your error code is for the fixing unit solve by checking the follwoing:-
1. Fixing lamp.
2. thermistor
3. Fixing assembly if receiving PD
5. if no Potential difference received they the power supply is not okey.
Jul 13, 2011 | Canon imageRUNNER 6000 Copier
Phaser 6360 printer as a error code 07
Unplug the printer from power for at least half an hour. Overnight would be better.
Jul 07, 2011 | Xerox Phaser 6360 Laser Printer
Xerox phaser 6360 laser failure code 07
The most likely cause here is the laser unit, check all connections to the laser unit and cycle the power (turn the machine off and on) if error continues replace the laser unit. You can buy a replacement for $350 new or $225 refurb. Part# 062K17233. Installation isn't very simple, so if you aren't a technician you may want to bring it to one. Good luck
Apr 22, 2011 | Xerox Phaser 6360 Laser Printer
I have been getting error code -6000; -83. What
Might I suggest going to the Getsatisfaction website. I have provided a link that will direct you there.
http://bit.ly/7ebRo
You can use OpenID, Windows Live/Bing, or create a new username.
Hope they can help you out.
Jun 05, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Phaser 6360 laser failure code 07
Yeah I had a look at the website there too, try powering down again and plugging it out for a longer period of time. You need to get the whole machine to reset and loose all saved info in the bios. Also cleaning it out of all loose toner on any contacts might help!
Niallbt
Feb 25, 2009 | Xerox Phaser 6360 Laser Printer
Xerox Phaser  6360 Laser Printer Logo
13 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
