Question about Pelican International Pelican Castaway 100 Kayak
Leak have a hole at back
Oil leaking from voltage regulator conector and bike will not start on 2003 dyna wide glide
The oil leaking from the voltage regulator connection has nothing to do with the bike not starting. To stop the leak, you'll have to go into the primary and pull the stator out. Pull the plug out of the hole from the inside, clean the oil off the plug and out of the hole. Then, put a good coat of RTV on the plug and push it back into the hole. Put the bike back together.
As for the no start problem, since I don't know anything about the ECM equipped bikes, I cannot help you there. Sorry.
Good Luck
Steve
Jun 15, 2011 | Harley Davidson FXDWG Dyna Wide Glide...
Leaking anti freeze from water pump
the water pump has 1 or 2 weep holes on it when the seals go out the antifreeze will leak from them holes replace it and no leak. get back to me with a make and model and year for replacement info.
Dec 16, 2010 | Chevrolet Lumina Cars & Trucks
It's leaking
Mine was leaking from the front left freezer side. I removed the tray at the bottom and saw that there is a drain hole in the back. I removed the sheet of ice that was covering the drain hole and poured vinegar and hot water to unclog it. That was the problem all along! The drain hole was clogged causing the water to drip out of the front. Whew!
Jul 02, 2010 | Hotpoint HSS25GFP Side by Side...
I have antifreeze leeking out a pin hole under the water pump
It is very likely the water pump seal. It is always a good idea to replace the bearing while you have it opened up.
Jan 13, 2010 | 2002 Honda CRF 450 R
Fridge that is leaking
Remove the back panel of the freezer . Use a hairdryer on the drain (aluminum enclosure) to defrost the ice .Once you see the drain hole , keep defrosting hole until only water in the hole . Use a small hose and blow into the hole to blow out any debris . Using an aluminum fence post holder about 6" long , put into hole and wrap about 1" around the calrod heater . This will transfer heat to the hole to keep it from freezing up .
Jul 06, 2009 | Refrigerators
Rear end is leaking fluid
If it is leaking out the front then it is the drive train seal. It is a gasket problem if it is leaking from the back unless you do have a rust hole in it. It could have a hole but I would suspect a gasket first.
Jul 06, 2009 | 1997 GMC Jimmy
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Pelican International Pelican Castaway 100 Kayak Logo
65 people viewed this question
Top Pelican International Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Pelican International Boating Expert? Answer questions, earn points and help others
