Question about NetGear WNR2000 Wireless Router
Connect to router - NetGear WNR2000 Wireless Router
  • NetGear Master
  • 7,733 Answers
Uickly and painlessly. Ad
Method 1 of 3: Connect the Router
    Connect the router to the modem. The router sends the modem's internet connection to any computer connected to its network. Ensure that both the modem and the router have their power cables plugged in. Plug one end of a network cable into your modem. Plug the other end into the port on your router labeled "Internet," "WAN," or "WLAN." The labels will vary depending on the type of router you have. Ad
  2. 2
    Install the software. Depending on the router brand and model, you may or may not receive software to install on the computer. This software is typically an interface to connect to the router and adjust the settings, though it is not required.
  3. 3
    Connect your computer to the router. You can do this either through an Ethernet cable or over Wi-Fi. If this is your first time setting the router up, then connect your computer via Ethernet so that you can configure the wireless network.
    • Typically, the Ethernet ports on the Router are labeled 1, 2, 3, 4, etc. but any port not labeled "WAN," "WLAN," or "Internet" will work. Connect the other end of the cable to the Ethernet port on your computer.
Method 2 of 3: Accessing the Router
  1. 1
    Open the web browser on your computer. In the address bar, type in the address of your router and hit "Enter." This will give you access to the router's settings. The address of your router will depend on the brand of router you have. Common brands and their default address include:
    • Linksys - http://192.168.1.1
    • 3Com - http://192.168.1.1
    • D-Link - http://192.168.0.1
    • Belkin - http://192.168.2.1
    • Netgear - http://192.168.0.1.
  2. 2Find the address through other means. Sometimes the router will have the default address and default password printed on the router. Check the labels for reference. If your router's IP address cannot be found, search for your router's address on the Internet by visiting the "Support" section on the router manufacturer's website.
    • If none of these options work, your router may have been configured by someone else to use a custom IP address. Press and hold the Reset button on your router to restore it to factory defaults. All settings and configurations will be erased. The Reset button is usually recessed and needs to be pushed using a paper clip.
  3. 670px-access-a-router-step-5.jpg 3
    Input the default username and password for your router. You will be asked for this in a pop-up window after you enter the router address. You can find this in the router's product documentation. Generally, the default username is "admin" and the default password is either "admin" or "password."
    • If the user name or password has been changed from the default and you don't have access to it, you can reset the settings using the Reset button on the router.
Method 3 of 3: Configure Your Router's Settings
  1. 1Configure your internet connection. Most routers will automatically detect your internet settings from the modem's connection. Adjusting any internet related settings, such as DHCP or DNS, without specific instructions from your telecom company may result in the loss of connection.
  2. 670px-access-a-router-step-6bullet1.jpg 2
    Set up the wireless network. If you have a Wi-Fi enable router, you can setup a Wireless network with that can be accessed by other Wi-Fi enabled devices. Open the Wireless section of the router's configuration screen. This is usually listed under Basic Setup, or Wireless Settings.
    • Locate the input box labeled "SSID." This is the name of your network and what people see when they attempt to connect to a network. Name your SSID something unique so that you'll recognize the network when you need to connect. Make sure the box labeled "Enable SSID Broadcast" is checked in order to broadcast the signal.
    • Most settings, such as Channel and Mode can be left at defaults unless you are troubleshooting specific issues.
  3. 3
    Secure your wireless network. Most modern routers support multiple kinds of wireless encryption. Use WPA or WPA2 to ensure that your network key will remain uncrackable. Pick a combination of letters and numbers to make the password strong. Users will need to enter this password on their devices or computers when connecting wirelessly to the network.
  4. 4
    Assign your router a new username and password. You will use this the next time you access the router. The default name and password for your router is very unsecure, as anyone that is connected to your network can easily enter the settings and compromise the security of your network.
Posted on Jan 10, 2015
How to connect wrt120n to dlink router
Are you trying to connect a Linksys router to another router.
Follow this link to connect Linksys router to another router. You need to connect both the routers to each other with the Ethernet cable.
Jun 14, 2011 | Linksys Wireless-N WRT150N Router
I have a LinkSys WRT54G2, Vers 1.0 router with the latest firmware installed and basically default configuration. I usually have 3-4 PCs connected to the router. I frequently loose connection to the...
Sometimes, you might face a situation where your wireless icon shows that you are connected to the Internet but you just can't access any websites. What do you do when you face this problem?
This article will show you how you can repair Internet connection when wireless icon shows connected, but unable to go online.
To connect to your wireless network with Wireless Zero Configuration, please click here.
In checking if you're computer is properly connected to the Linksys Router, you will need to perform four steps:
i. Checking the Physical Connection to the Router
ii. Checking the LEDs
iii. Checking the IP Address of the PC
iv. Pinging the Router
NOTE: To check the computer's connection to the router using Mac, click here. If you are using Windows Vista, click here. For Windows 7 users, learn more here. For Windows 7 users, learn more here.
Make sure that the computer is connected to one of the four Ethernet ports of the router and the modem should be connected to the Internet port. For more instructions, click here.
Checking the LEDs
The Linksys router's LED lights will indicate the status of the connection. After connecting the broadband modem and the computer to the router, make sure that the LED lights are lit up. For more instructions, click here.
The IP address of the computer is another indication that the computer is properly connected to the router. For instructions, click here.
Pinging the Router
Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is "192.168.1.1."
Dec 06, 2010 | Linksys WRT54G2 Wireless Router
Wont connect to the computer or internet
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 30, 2010 | Belkin (F5D7230-4) Router (587009)
Cannot connect to internet using wgr614 router. connection is good without router. with router connected, internet lite blinks.
To use a router with a DSL modem or cable modem, you need to connect the modem to the router at the WAN port and then connect the PC to one of the router ports. If the cable you have been using between the modem and PC is lableled as a cross-over cable, it is the wrong type of cable for the router connection. Use a straight through cable to connect the modem to the router.
If you do not have a manual for the router, here is a link to the router manual online: http://kbserver.netgear.com/pdf/wireless_router_setupmanual.pdf
The cross-over cable could be the problem (typically yellow cable).
Jan 20, 2010 | NetGear WGR614 Wireless Router
DL 524 router with a mac
When you connect the MAC to the router with the CAT 5 cable it works , that means the wired connection of the router is working but the wireless is not working.
You will need to check the wireless settings of the router.
Is there any computer connected to the router with the cable ?
If not then you will need to connect the computer to the router and open the set up page of the router.
Click Here for step by step instructions
Dec 02, 2009 | D-Link AirPlus DI-524 Wireless Router
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
Nov 09, 2008 | Linksys EtherFast Cable/DSL Router
How to connect Nortel BSR222 (Business Secure Router 222) with tplink
rj11 are connectors used to deliver signals to a device. Mostly, modems will be able to support this type of connection. Make use of a modem, bridge it and connect the router to it.
Aug 17, 2008 | Nortel NETWORKS CONTIVITY 1100 T1 WAN BNDL...
NetGear WNR2000 Wireless Router Logo
69 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
