Question about Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range
Blown fuse I think a fuse has blown, ignition button does not work, something went pop.
Went to start my 99 ford escort and lights came on and chimes as normal went to turn key and heard a little pop sound. Then no lights no start nothing. Please help I'm stranded
if it did this when the starter motor was engaged when this happened then it would be that that is a fault and it has blown the main fuse in the engine bay fuse box. could also of damaged the ignition relay in main fuse box.
Oct 13, 2013 | 2001 Ford Taurus
Would my windscreen water pump have a dedicated fuse that may have blown?
sorry to hear about your back, back problems and working on cars are never a great combo. This is a simple fix, if you can purchase a simple voltage meter it will help even more. if there is 12v going to the pump then its The Pump. since you say there are no noises coming from the washer jug then that eliminates a broken/disconnected tube. If you think your fuse is blown, well thats an easy fix. But something caused it. So if the fuse is blown look for a "ground fault". Explenation; everything inand on your car must be grounded to the chasis, when you loose that connetion this Will Not blow your fuse, only a corroded/poor connection. This causes heat and heat will pop fuses and sometimes take out the component you are working on. recap: 1. buy a 12v meter - this is your diagnostics tool. 2. check the fuse - if blown/popped do not replace until you check the connection on the motor. if there is no corrosion your good to put the fuse in. 3. if the fuse isnt popped, your meter can test for power to the motor. if power is there the motor is bad. replace it and then check your tubing.
Good luck
Sep 20, 2012 | Cars & Trucks
1999 Crown turned ignition switch to start - heard pop - no electrical power
If nothing works including the lights, something happened between the battery and the fuse box.
There are some fuseable links between the battery and the starter solenoid or between the solenoid and the fuse box.
I'd start with the battery cables and look for those fuseable link wires.
Jul 09, 2012 | 1999 Ford Crown Victoria
Trunk release button on 2001 ford focus will not work
So your trunk release button on the dash dpesn't seem to open the trunk.
Does your key fob button open the trunk? yes....then could be problem with switch but read on.
no......are your power door locks not working as well. not working.....check
fuse, on 2001 Focus the fuse is a 20amp number 63 on the back of the fuse panel under the dash. Pop cover off and undue the rwo screws. hold plastic retainers and pull off the fuse panel from metal frame. pull fuse panel down toand turn over so you can see the fuse.check fuse. blown? yes.......replace fuse with good one. test all door locks open/close then check fuse...if its blown the problem is something to do with the door lock circuits. if the fuse is still ok...try pushing the trunk open button. fuse still ok? then I am a loss toas to whats the problem but if the fiuse blew when trying the trunk button your problem is the trunk latch circuit.
Now if the trunk latch button is popping the fuse then disconnect wiring to
trunk latch (in trunk) and try the button again. Still blowing the it is the electrical before the trunk latch unit. If it did now blow the problem is something to do with the part of the circuit you disconnected.
How to go farther and find the problem exactly is not covered in this answer. You have to take it from here. JAG
Mar 17, 2012 | 2001 Ford Focus
Windshield wipers stopped working heavy snow stopped them now i think the cover directly below the wipers has to have an arm under it that has a clip or something that has popped off how do i remove the...
Can you hear the wiper motor running when you switch them on? If so then the plastic ball and socket link arm has popped off, You might get away with popping it back on but its unlikely and you will need a new link arm. Other than that if you cant hear the motor running (you need the ignition on) I would check for a blown fuse before going deeper into any other possibilities.
Feb 02, 2011 | 2005 Honda CRF 100 F
My washer was displaying 06 (I think). I tried to reset it and then there was a loud pop and all the lights went off. Now it seems there is no power going to it but at the same time the door is locked and...
Open the back panel and look for the main fuse. Check the main fuse, if blown replace w/ the same value of amp.
The fuse just blown off, means there is something wrong w/ the electrical system, the capacitor might have been overheating. Call a technician so that he could pinpoint the main cause of a BLOWN FUSE!
Nov 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I was driving car,went to push clutch in to stop
this has to be the main STARTER FUSE ,,IN ENGINE,,look in engine bay ,look for a box with relays and fuses,,open lid of that box and look for the main starter fuse should be a big fuse ,,this must be blown,replace this ,very cheap,job done
Jun 19, 2010 | 1993 Saturn SC2
Window problems/fuse
First of all I believe in the 3 series this procedure works. put the key in the door with the doors closed- turn key and hold it there while you watch the windows roll up automatically. If this does not work you probably have a fuse problem. If it does work then your window switch might just be bad. As to which fuse it is, just look for a blown fuse in the glove box. Apparently these fuse boxes on the 3 series are hard to read? on my sisters 325i it is under the hood and the cover has the information on the back
May 11, 2009 | BMW 325 Cars & Trucks
Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
