Question about Saeco INCANTO DELUXE Espresso Machine
Coffee leaking onto counter and tray
It is coffee leaking onto counter not clear water
SOURCE: Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Posted on Nov 07, 2007
SOURCE: Saeco leaking... Please HELP!#@&(!
This may just be a cleaning issue. I have had this alot. If you open the machine and take the contraption out of the inside (the hopper thing). You should clean this of course but the problem is behind that on the back wall of the machine. There is a diagonal slot. at the bottom of the slot is a drainage port that is supposed to take the water and send it to the tray. but you will probably find that this is all clogged up with coffee. You need to clean the coffee out, I recommend pipe cleaners and Qtips and patience to get it out. You will know it is clean when you can squirt water into the bottom of the diagonal slot and it will flow out of a little port just below it (where it goes to the tray).
How to keep this from happening again. Most likely given the description of the beans (too wet), your grinder is set too fine. You can adjust the grinder when it is running and you should adust it to a higher number. Its recommended to be on 8 and you may need to go to 10 or 11, ( you have to experiment with it). I only recently realized that my own grinder was set at too low of a number and it was causing a recurrence of this leakage issue.
Posted on Jan 18, 2009
  • 1089 Answers
SOURCE: brewed coffee leaking into spill tray underneath
HI
You have a stripped thumb screw. It needs to be replaced. It holds the filter screen in.
Posted on Dec 11, 2009
  • 1089 Answers
SOURCE: leaking coffee grounds and water
HI
There should be a small amount of coffee residue and about an oz. of water going into the drip tray. This is the pressure relief process, when the machine finishes the coffee making. If it didn't release the pressure thhis way you could have an explosion of coffee when it cycles back.
Posted on Jan 06, 2010
SOURCE: estro magic delux (now saeco i think) water leaks below brew unit
There is a small metal plate with holes below the square funnel shape on the brew unit. This plate has a pink rubber seal and a stem that goes up into the brew unit. The stem is knurled with ridges and is attached to a screw on the plate. The screw has become loose and the plate is not held tight against the seal. Turn the knurled knob clockwise until it tightes the plate against the bottom of the unit. Make sure the plate is centered as I believe there is a slight lip that it recesses into. Should stop the water in the grounds collector. Of course the seal must be in good condition. Paul
Posted on Mar 25, 2010
I am not able to get any coffee through the coffee dispenser. It just fills the overfill tray and leaks from under the machine onto the counter. Any idea what the cause is and how it can be resolved?
Try running a mixture of 1/4 cup Apple cider vinegar in a pot of water then flush with pots of cold water until no more vinegar odor. This immediately breaks through hard water scale buildup. You may also have a bad seal if it is leaking. You can get a repair kit from Mr. Coffee or if you have a Bunn, they have lifetime guarantee. You can return for repair, or request repair kit by contacting them
Jan 23, 2015 | Coffee Makers & Espresso Machines
Super automatic espresso machine leaks water into drip tray and onto counter when I use the frother
The stream valve is leaking and probably needs to be replaced. If you remove the top cover it is visible.
Sep 12, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
KitchenAid Pro Line espresso machine leaking water onto counter after repeated shots
I keep hearing how this machine makes great crema but I'm about ready to toss my machine in the dump. It seems like the water comes out way too fast no matter how I work the grinds or tamp it. Can someone contact me about what might be wrong?
Dec 26, 2012 | KitchenAid PRO LINE KPES100PM Espresso...
Water overflow
outlet behind the brew unit could be plugged. This will cause water to spill on counter from behind the tray. Clean out this small hole with a q tip or squirt water from a syringe into it and from above it through the plunger window. It should run clean. This is where the excess water is supposed to go into the tray
Nov 26, 2012 | Solis Master 5000 Espresso Machine
Saeco Vienna machine...after brewing a couple of cups of coffee, water leaks from somewhere and comes out underneath the front grilled tray and onto the counter. Can I do the repair with the proper parts?
Depending on your ability to do some technical and minutious manual work, unmounting and remounting the machine is feasable.
Concerning the leaking, what I've seen most is a leak from the seal under the water tank. Any leaks coming form there would occur even though no coffee would be dispensed. (i.e: Idle mode)
If leak is ONLY occurring when brewing cofee, I would check the following:
1- Check if the water inlet on the back of the brew unit is filled with residue (the inlet looks like the end of a smoke pipe)
2-Open the machine, take out the interior, and verify the water tubes coming in and out of the boiler. They both should be sealed with 2 small o-rings. After time, o-ring tend to expand under heat and may start to leak.
Hope this helps
Feb 27, 2011 | Saeco Vienna De Luxe Espresso Machine
Water is leaking internally onto the countertop and none going into the cup on solis master 5000
Hi
You boiler is leaking and needs to be replaced. Check partsguru.com or ebay for replacements.
Dec 11, 2009 | Solis Master 5000 Espresso Machine
Water leak
your machine needs repair. could be a leaky valve, clogged release chute, or a boiler gone bad.
90% of the time is a bad boiler.
Boiler work is going to cost ya on average 200 and up.
May 06, 2008 | Saeco Magic De Luxe Espresso Machine
Leaking Water shorts out machine
I had the same problem. What may be the problem is the tiny water drip hole that feeds the drip tray is blocked with coffee sludge. Open the machine and remove the dump bucket, drip tray, and the brew group. Behind the brew group is a flat plastic piece which has a small drip hole at the bottom of it. This may be blocked which causes the water that should go into the drip tray to build up and overflow inside the machine running onto the countertop. Clean out the area behind the little drip hole and the hole itself. This should cure it.
Nov 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Oct 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco INCANTO DELUXE Espresso Machine Logo
48 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
