Question about Video Game Consoles & Games
Wire schematic snakebyte sb00566
Chord wire came off
Tip
Air compressor will not start
An electric air compressor motor may start up fine on an empty tank but not when the tank has air in it. Additional torque and power is required to start when not empty. The electric wires may be too small or their length too long and represent electric resistance in the circuit. Larger gage wire will have less resistance and provide more power at motor start up under load.
A motor uses 6 times the amps when starting, a normall size and length wire is capable to deliver this power momentarily. The problem is when the wire is lengthened without using a larger gage wire. Resistance consumes power and the wire resistance will consume power causing a voltage drop to the motor. A motor, as most electric loads needs plus or minus 10% of its rated voltage to operate. What I'm saying is that a larger gage wire must be used, 1 gauge size to 25 feet, 2 gage sizes to 50 feet, or more size larger when using extension chords depending on length. I keep some romex of heavy gage with chord ends on it to use as temporaty long extension chord for compressor or welder use.
on Feb 12, 2015 | Air Tools & Compressors
Used it last year.This year the chord to the extension chord frayed in two places.From the handle.And where the outside extension chord connects
I take the old wires out and replace them An electrical shop should have the cord you need. The switch on the handle should come apart and go back together again Just becareful you put it back together the same as you took it apart.
May 01, 2015 | Garden
Where can I purchase a plug in outlet chord (power chord) for the osim medic 380 massage chair
If you are looking for the male end that plugs into the wall, you can use any 3 prong plug made for 120VAc. Just cut off the old one and connect wires to the new one. Black wire to brass terminal (if not brass or color coded, the smaller blade), white wire to silver terminal (no coding, larger blade) Green wire to green ground terminal. Secure in plug and you're goo to go. If you need to replace the plug on the unit itself if it has one or if its hard wired (usually is) you may need to disassemble that part to replace or reattach the cord.
Jan 23, 2015 | Furniture
Have a mity mite ps 120 a automotive jump starter but no chord to charge it. can i just use any chord or do i need to buy a replacement chord? And if so where can i purchase?
What Cord?
Your asking about plugging it into the homes
electrical outlet ?
Can't use just any cord,not a two prong lamp cord
type extension,no
You use a three prong grounded extension wire
Does it not have several feet of wire on it & a three
prong plug?
You use a standard outdoor extension, like you
would for a vacuum cleaner outside
If you use it a lot, buy a short 6 foot one,just to
use with it
How about the owners manual ?
Nov 25, 2014 | Cars & Trucks
My snakebyte controller for the ps3 just stopped working is there a way to fix it?
Hi Brandy,
On the back of the controller is a small hole just above the label to the right, this is the reset button, so use a pen or something thin to reset it and then re-sync it as usual.....hopefully that'll work
Thanks
Mar 15, 2014 | Snakebyte PlayStation3 Premium Wired...
Rice cooker retractable cord
Either go to the manufacturers web site and locate the particular model of your rice cooker- check for a schematic and/or parts list. Or call them and ask if they have replacement parts for the particular model of the rice cooker you own.
Nov 24, 2013 | Kitchen Appliances - Others
Blumote wont stop scrolling
Not to sound daft, but have you replaced the batteries in it? Dying batteries cause all sorts of problems in remotes.
Mar 29, 2013 | Snakebyte PlayStation3 Blu-Mote Remote
Blu mote trouble
How to program it to my new playstation3.
Oct 27, 2012 | Snakebyte Sb000276 Playstation 3 Blu-Mote...
Video Game Consoles & Games Logo
57 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
