Question about Saeco INCANTO DELUXE Espresso Machine
Leaking coffee into tray and on counter
The machine only puts about 40% of the coffee into the cup. balance goes into tray and on the counter
WaltK
SOURCE: Leaking Water shorts out machine
I had the same problem. What may be the problem is the tiny water drip hole that feeds the drip tray is blocked with coffee sludge. Open the machine and remove the dump bucket, drip tray, and the brew group. Behind the brew group is a flat plastic piece which has a small drip hole at the bottom of it. This may be blocked which causes the water that should go into the drip tray to build up and overflow inside the machine running onto the countertop. Clean out the area behind the little drip hole and the hole itself. This should cure it.
Posted on Dec 08, 2007
SOURCE: Problem getting a Full Cup of Coffee
besides descaling you need to lube the brew group, especially the bit that accepts the group nozzle. You might have a leaking boiler too, 6 years is pretty good for a vienna.
Remove the brew group and look for the two red o-rings on teh brass bit, smear some lube on it, they might need replacing by now, but luckily they aren't too expensive and readily available albeit a bit tricky to install, a good light and some patience is very important.
Posted on Dec 16, 2007
SOURCE: Saeco leaking... Please HELP!#@&(!
This may just be a cleaning issue. I have had this alot. If you open the machine and take the contraption out of the inside (the hopper thing). You should clean this of course but the problem is behind that on the back wall of the machine. There is a diagonal slot. at the bottom of the slot is a drainage port that is supposed to take the water and send it to the tray. but you will probably find that this is all clogged up with coffee. You need to clean the coffee out, I recommend pipe cleaners and Qtips and patience to get it out. You will know it is clean when you can squirt water into the bottom of the diagonal slot and it will flow out of a little port just below it (where it goes to the tray).
How to keep this from happening again. Most likely given the description of the beans (too wet), your grinder is set too fine. You can adjust the grinder when it is running and you should adust it to a higher number. Its recommended to be on 8 and you may need to go to 10 or 11, ( you have to experiment with it). I only recently realized that my own grinder was set at too low of a number and it was causing a recurrence of this leakage issue.
Posted on Jan 18, 2009
  • 1089 Answers
SOURCE: saeco stratos coffee maker started to leak inside
HI
There are a lot of things that can cause the machine to leak.
You could have a fitting or tube that is broken.
You boiler could be leaking and needs to be replaced.
You could have a hose connection that has come loose.
You could have a bad seal at a connection.
Until you get inside you will not know? You might want to have someone look at it for you.
Scale is one of the major causes for machines to start leaking. Make sure that your water hardness is set on 4, so you descale more often than not enough, to prevent leakage in the boiler.
Posted on Nov 07, 2009
  • 1089 Answers
SOURCE: leaking coffee grounds and water
HI
There should be a small amount of coffee residue and about an oz. of water going into the drip tray. This is the pressure relief process, when the machine finishes the coffee making. If it didn't release the pressure thhis way you could have an explosion of coffee when it cycles back.
Posted on Jan 06, 2010
Gaggia accademia
Most likely a connecting pipe might have come loose or leaked, boiler leaking might also be possible
Jul 17, 2014 | Gaggia Coffee Makers & Espresso Machines
Coffee winds up on the counter
Replace seal MS621749 above the filter handle
Sep 16, 2013 | Krups XP1020 Espresso Machine
Coffee doesnt flow but water gathers in the drip pan instead.
Hi Your problem is probably the boiler leaking. Its located just above the drip tray in the center of the machine. When it starts leaking it goes into the drip tray or on the counter top. If you can remove the top, you can see if the boiler is leaking. There will be a white line between the 2 halves of the boiler.
Feb 09, 2010 | Saeco Magic De Luxe Espresso Machine
Water is leaking internally onto the countertop and none going into the cup on solis master 5000
Hi
You boiler is leaking and needs to be replaced. Check partsguru.com or ebay for replacements.
Dec 11, 2009 | Solis Master 5000 Espresso Machine
Brewed coffee leaking into spill tray underneath
HI
You have a stripped thumb screw. It needs to be replaced. It holds the filter screen in.
Dec 06, 2009 | Saeco Magic Comfort Plus Espresso Machine
The machine leaks water all over the counter when starting brew
My keurig did the same thing, the rubber grommet around the part that punctures the cup gets grounds on it and prevents a complete seal. Pop of the grommet and clean it and it will be good as new.
Mar 14, 2009 | Keurig B70 Coffee Maker
Leaks everywhere
Make sure the lid is on the caraffe and just try to run plain water through. Although, it sounds like you might actually have a crack/leak. Return to store if possible or call Cuisianrt if it really is leaking.
Dec 25, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Machine stopped working
This machine is piece of s... I replaced two of them so far and experienced same problem.:
Machine works fine couple days
...than it start dispensing less water into the cup.
...than it stop dispensing water into cup completely and instead all water goes into the tray.
..The pump also starts occasionaly to make interrupted repetative sound.
Did anybody get it fixed?
Jan 05, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Saeco INCANTO DELUXE Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
