Question about Magellan RoadMate 700 GPS Receiver
Reset myguide how to enter boot menu
HP Centario running Lenux I reset the CMOS battery and the blue screen still comes on says password required what am I doing wrong?
if you are running linux ubuntu
http://www.howtogeek.com/howto/linux/reset-your-forgotten-ubuntu-password-in-2-minutes-or-less/ Click "Applications" and then click "Accessories" on the top taskbar in the Ubuntu desktop. Click "Terminal" to open a terminal window. Type the following command at the Linux prompt and press the "Enter" key: sudo passwd To change the Administrator account password, the password of "root" is changed. The "sudo" command gives the current user temporary Administrator access, in this instance, to change the password of "root." First, the user will see a Unix prompt asking for the current user's password. Type the user password for the current user account. Press the "Enter" key. Next, Unix will prompt the user for the new password for "root." Type the new password for "root." Press "Enter." Finally, a Unix prompt will require a confirmation of the password. Retype the new password for root, and press "Enter." The Administrator (root) account password for Ubuntu is now reset or Boot computer into recovery mode. Reset your computer and as it is booting, hold down the "Shift" key on your keyboard. You will be presented with the boot menu. Select "Recovery Mode" from the boot menu. It is usually the the second boot option. Wait for computer to boot up. You will be presented with the Recovery Menu. Select "Drop to Root Shell Prompt." Type "ls /home" and press "Enter." Note: The command starts with a lower case L, not a capital i. You will be presented with a list of usernames of accounts installed on the computer. Type "passwd username" where username is replaced by the name of the account you want to reset. For example, if the username of your account was "jeff" you would type "passwd jeff" and press "Enter." You will be prompted to create a new password. Enter a new password of your choosing. Note: You will see no visual response when you type in your newly selected password; however, the computer still will register the input. Press "Enter." You will be asked to retype your password. Re-enter the same password and press "Enter." Your password is now reset. Type "Exit" to return to the boot menu and select "Resume Normal Boot" to restart Ubuntu.
Feb 24, 2013 | Computers & Internet
Ubuntu adm password reset
sudo passwd
or
hope this helps
Oct 02, 2012 | ValuSoft Ubuntu Linux for PC, Mac, Linux
My computer has been locked from the boot menu i put my password in or so i think it is and it will not accept password it tells me to enter password then press (ctrl and enter) to disable system lock not...
U can reset boot menu password through removing BIOS battery and than switch on the system it will clear or some boards are with jumpers u can check CMOS clear from 1 to 2 for clear 2 to 3.try it.
Sep 13, 2010 | Computers & Internet
Myguide 3100 frozen at startup screen. pc connection not working. how do you cause interupt/boot from sd card to flash etc.pressing start buttons/reset does nothing
Yes becouse it not a function on myguide.
You need to reflash the rom. Its costs. But i know the solution for it. If you intrested you can contact me.
Oct 27, 2009 | MyGuide 3100 GPS Receiver
Myguide 3100 stuck in start screen, it all happened when I restarted my GPS after 2 months. I charged it completely and then tried resetting but it does not help. Even I cannot switch off the device !.....
Use the map cd you should have got in the box with the myguide. Put it into your computer and attach the myguide to your computer with a usb cable. An option should appear to reinstall original software do this and that shoud work
Apr 21, 2009 | MyGuide 3100 GPS Receiver
Lack of instructions for system.
I can send you a manual for a myguide 3100 if thats any use. The 'm' should stand for menu. Date and time will update automatically as it connects to satellites
Mar 04, 2009 | MyGuide 3000 Portable Sat Nav Car GPS...
Won't let me go to main menu
You should have had a map backup cd in the box. Put the cd in your computer and connect the myguide to the computer by usm this will allow you to add/remove maps
Nov 17, 2008 | MyGuide 3240 GO GPS Receiver
My Guide 3000 GPS System
it's the same menu but the pna thinks the sd isn't in, so it hides those buttons. u should get to sd card to your computer and look at addons.txt. that contains information about the menus, and if that looks alright(
[modules]
Games = "icons/games.bmp", "", 0
Navigate = "", "\\Flash Disk\\myguide\\myguide.exe"), then u should go to windows explorer. when it boots, after u hear the noise, notice a black square appearing in the left corner, "click" and hold until u see the a menu close to that when u right click your computer's desktop(if it's windows). click new folder and keep touching the desktop for the next ten seconds, so the "main menu" won't appear. then enter the new folder and windows explorer will launch, click the address bar and erase what's there and type \ then press enter. it will go to my computer. go to flash disk (which is the internal rom) and click igo launch. that should launch the navigation software.
Jul 08, 2008 | GPS
Magellan RoadMate 700 GPS Receiver Logo
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
