Question about LG LH-D6230 System
Multi channel output - LG LH-D6230 System
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Yamaha rx-v663 is there a firmware update to get hdmi 1.4a support ?
Unfortunatly there is not any firmware to upgrade your unit to a higher HDMI format. There is a firmware though that corrects the following symptoms.
1. In case of playback of some DTS-HD Master Audio stream, pop noise may be generated.
2. Test tone may not be output under specific YPAO condition.
3. When test tone is output from presence channel, surround R channel is simultaneously output when speaker settings are PRESENCE SP "EXIST" and SWFR "NONE".
4. Multi channel input setting will be reset after power off the unit, in case of setting "INPUT CH" to "8CH" and "FRONT" to "VCR" or "V-AUX".
Apr 10, 2012 | Yamaha RX-V663 Receiver
How do you balance sound between two speakers. Where is the balance control? JVC RX5000v
On the front panel ONLY:
1. Press ADJUST so that the MULTI
CURSOR up/down buttons work for
adjusting the sound.
2. Press MULTI CURSOR up/down
repeatedly until "BALANCE"
appears on the display.
3. Press MULTI CURSOR left/right to
adjust the balance.
• Pressing left decreases the right channel
output.
• Pressing right decreases the left channel
output.
please rate my solution.
Jul 04, 2011 | JVC RX-5000V 5.1 Channels Receiver
I have a parasound 5250 5 channel amp. Channel one is not working. Is there a fuse?
hi, there is no fuse on amplifier output only power supply, the problem is some parts of electronic that drives into audio output of the amplifier maybe are shorted like transistors, diode or amplifier Ic's. bring it to a nearest service center to check it. or if you have a knowledge in technical yo can used multi tester to check it. Note: unplugged it first before you open the cover to check it. thanks
Mar 28, 2011 | Parasound 5250 5-Channel Amplifier
Multi room will not play any digital input, just analog. I.e. Video 1 when analog connection plays in multi room, but optical 1, when set as input for vid 1 will not play in multi; works fine in main...
I have a Marantz 7.1 AV receiver (sr5500) and I run a 5.1 set up for home theatre and use the 2 extra channels to run a pair of outdoor stereo speakers... When I first set it up I also found I could not get a digital signal output, only analog, after reading the manual(!) I discovered that it can only output an analog signal...so I have used the phono outputs on my blu-ray player into the CD input of the AV amp and play CDs outside through this and it also outputs the optical digital signal into the AV amp through the DVD input...my iPod also plays through a dock and it's analog output to the speakers outside through another (CD-R) anolog input on the amp... Hope this helps
Dec 24, 2010 | Harman Kardon AVR 335 Receiver
HOW TO HOOK UP ALL MY X-530 LOGITECH SPEAKER ON MY PC
You'll only be able to get true surround sound utilizing all the speakers if you have a sound card with multiple outputs (usually color coded as Green, Black, and Orange). Plug the satellite speakers into the subwoofer and run the three input wires (Green, Black, Orange) to your multi-source output.
If you only have one output on your PC (common), you should just connect the green wire and press the "matrix" button on the system. This will just duplicate the sound output into the other channels but is not "real" surround sound.
Hope that helps.
Feb 07, 2010 | Logitech X-530 5.1 Channel Speaker System...
I cannot find the specs or user manual on the JVC archived items list. A few sites want to charge $10.00 for the user guide info, but I think that is too much to charge.
Defiantely not 200 watts
KS-A82
  • 2 Channel Amplifier
  • Bridgeable 2 channel amplifier
  • Output power: 25W x 2, 20 - 40,000 hz at .08 THD
  • 2 ohm stable
  • Adjustable gain (.1 - 2v)
  • MOS-FET DC-DC converter
  • Multi phase connection
  • 1 Pair of line input terminals
  • Remote relay turn on system
  • MSRP: $159.95
http://www.admtechusa.com/JVC.html#KS-A82
May 22, 2009 | Car Audio & Video
Pioneer DEH-P3000IB... Hook up RCA cables to 2, 2 channel amps for front and rear control. Supposed to be able to set rear to either rear full or sub... can't find how and all I'm getting is sub response.
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
SW CONTROL.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
setting.
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
REAR SP:SUB W(subwoofer)—REAR SP:FULL
(full-range speaker)
When PREOUT (RCA output setting) is selected.
PREOUT:SUB W (subwoofer)—PREOUT:REAR
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
Oct 13, 2008 | Pioneer Audio Players & Recorders
Subwoofer playing in stereo sound
i think uyou have to got to stereo mode and turn ion the subwoofer option. i have a h/k thats wart i had to do in evvery mode is designate the s/w. rating please
Jan 24, 2008 | Denon AVR-1907 Receiver
LG LH-D6230 System Logo
18 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
