Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
Hyper board 46h84 toshiba projection tv
A repairman said the hyper board was out and my tv couldn't be repaired because the board was no longer made.
  • 1694 Answers
SOURCE: TOSHIBA 50HDX82 - hyper board failure
Toshiba likes to solder shields / covers in place.......check..
Small boards have a side clip = release with screwdriver while
releasing end clips = hard to describe, best to visually inspect.
I will let you know about service literature = CD ROM.........T.
Posted on Nov 14, 2007
  • 1694 Answers
SOURCE: toshiba, 57h82
Hire a skilled,senior tech willing to rebuild your board....
replace all bad caps.......good as new.................T.
Posted on Dec 22, 2007
ctf1800
  • 4402 Answers
SOURCE: toshiba 57h82 model tv
can you post a picture?
Posted on Feb 07, 2008
MikeMaierTV
  • 206 Answers
SOURCE: toshiba 57h81 location of hyper board and remove procedure
Hyper board is located directly behind the input board, this is where all the tv conections are, then they are two tabs soldered from the bottom of the board then it simply unplugs, But replacing all those capacitors on that board can be a little tricky, replace all 10up @16volt caps and that usaly repairs the board
Posted on Feb 13, 2008
SOURCE: Toshiba 42H81 Hyper Module replacement
MVPU14 and MVPU13 do cross.
Posted on Jan 02, 2009
Vertical lines when I turn on my Toshiba 51HX84
Thats a common issue caused by bad capacitors on the hyper module
Feb 10, 2013 | Toshiba 46H84 46" Rear Projection...
There are wigley lines top to bottom inthe video in tunner and video in
The model listed here has a HYPER board that processes all signal in the set from all inputs and usually in these sets it will begin with the problem being there when first turned on and after several minutes it goes away--gradually it takes longer and longer until it will not go away----Is this what happened to you?
Dec 17, 2012 | Toshiba 46H84 46" Rear Projection...
Touch focus error blue
The tv HYPER board it is dead aslo known as a tv convergence board.Tv have a convergence problems,it is dead.Tv Magic Focus button no longer response give error messages.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?Yes,than the tv HYPER board it is dead also known as a tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of resistors too.To fixed the tv HYPER also known as a tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 12, 2011 | Toshiba 42H82 42" Rear Projection...
I have vertical lines on my screen. They appear to
This a common problem in many of the Toshiba sets----set has a "HYPER" circuit board that processes all the signal for the set--surface mounted caps all start to dry out--always starts out where it will have the problem and then when on for a while it gets better and goes away--eventually when enough of the caps are gone--it never gets better.
Board is now only available by removing it and sending it out for rebuild/repair---company doining this is Pts electronics--part number is:
23148103Cost is about 180 dollars plus shipping and this may mean considering the labor to get the board out that the set is not worth repairing.
Sorry to give you bad news but I am certain this is what your trouble is.
I do this here for free so if this information helped you to decide what to do--take a minute and give me a vote here.
If you have questions or need advice reply to this posting here.
SD TECH
Sep 15, 2009 | Toshiba 46H84 46" Rear Projection...
When I first turn on my TV, I get horizonal faded lines
it probably has leaky capacitors in the hyper board or the video process board, this repair requires a qualified tv repairman, you can't do it yourself, alot of actual repairman can't handle this repair. it will get progressively worse as time goes on the more leaky the capacitors become.
Sep 07, 2009 | Toshiba 42H81 42" Rear Projection...
Green CRT Bulb is shorting out on 46H84 Toshiba. Repairman says no replacement bulbs are available.
Thanks I ordered the part # required to solve the problem through the links you provided.
Sep 07, 2009 | Toshiba 46H84 46" Rear Projection...
Toshiba 57h81 location of hyper board and remove procedure
Feb 12, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba model 57H81
hyper board is nat made anymoore just replaced 10 10uf caps inside.
Apr 02, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba model 57H81
If you have zagged lines there are 10 small surface mounted capacitors you will need to change on the HYper Board. This is not an easy repair so alot of folks simply replace the hyper board. You will need a service manual to take this set apart and to get the proper part number. If you have no TV repair experience or do not know how to solder, as the hyper board has sheild arounfd it, you should play it safe and call out a pro to assist you in this repair. Good Luck
Mar 19, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
