Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
Repair code LE and bottom is flooded - LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
  • 423 Answers
If you are saying that the water is under the dishwasher and you are getting an LE error, you have a dishwasher with a hole in it and it needs to inspected and repaired.
But first carefully inspect the drain hose, starting at the lower front on the LG dishwasher. If it is damaged or has a loose connection, it would give you an LE error.
Posted on Jul 15, 2009
Had the same LE code problem after the d/w filled on a 2 yr old d/w the repair man just opened up the front and 3 wires were melted through their insulation and broken throu, serious electrocution + fire hazard! worked once these were fixed it worked also LG life not-so-good never again
Posted on Jun 23, 2009
  • 109 Answers
I don't know if this thread will help, but you can have a look here: http://www.howtomendit.com/answers.php?id=28214
If not try the LG website which has support and fault codes to assist you.
Posted on Jun 18, 2009
My 1995 Toyota Camry le when motor gets hot it skips and floods
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Dec 19, 2016 | Toyota Cars & Trucks
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
Samsung dishwasher error code LE what does this mean
LEak! You have some water that leaked down into the base and triggered the flood sensor.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Feb 18, 2015 | Samsung Dishwashers
Le error code
The error code "LE" appears after an unsuccessful attempt to fill the drum with water that results in the water level being too low to safely begin cleaning. The product manual suggests calling for service, but there are several steps you can take to try to resolve the issue at home.
Read more: http://www.ehow.com/info_8696564_maytag-washer-repair-code-le.html#ixzz2zXrmqUO5
Apr 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
We have a 23" Fisher&Paykel dishwasher and got
The F1 error coming on top drawer when operating bottom drawer is due to the thermal fuse blowing up on the bottom drawer and shutting controller power.
The thermal fuse could have blown either as a normal component failure or heater over heated due to thermostat failure. In any case this can be repaired by replacing the whole heater assembly as all the parts are integrated.
This is at the underside of the drawer and will need a technician to replace unless you are very familiar with repairing electronic dishwashers. The part look like this.
The way you have described the onset of the F1 error is not due to flood switch. You can confirm that the lights on the bottom drawer are out even though the top drawer is showing F1 and beeping.
If problem was flood switch then both drawers would show F1.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
LG DISH WASHER LE CODE 4th.TIME
Have your service tech remove the door cover and check the wiring harness completely. Especially where it flexes at the bottom. LG had a problem on some of these models with the insulation degrading on the wirw. Replace the wiring harness and the motor again.
Oct 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
I'm getting an "LE" code also, and the dishwasher will not drain.
LE is a Motor error
Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked.
Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB
Sep 07, 2009 | LG LDF6810ST Stainless Steel Built-in...
Top Drawer light is out-display eratic powers on and off at will.
Below is the service manual link and a web site that I found. refer to the lower section where a person writes in that the fixed the flooding with a hairdryer. I hope this helps, they seem like fantastic dishwashers.
http://www.scribd.com/doc/6462163/DD601V2-Manual
http://fixitnow.com/wp/2004/10/25/appliance-repair-revelation-fisher-paykel-dd602-dishdrawer-f1-code/
Mat
Please rate me
Nov 30, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
LE ERROR CODE
This new....just call out LG to repair under warenty!!
Jul 22, 2007 | LG LDF6810 Built-in Dishwasher
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
476 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
