Question about Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract
How to drain oil - Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract
What is the right oil and filter to use on the range2007 hse?
How To Change Oil and Oil Filter on Range Rover Sport or Land Rover LR3
  • Place an oil drain pan below the oil filter and drain plug and unscrew the oil filter.
  • Lubricate the rubber seal with clean oil and install the new filter. Tighten to 13 foot-pound torque.
  • Remove drain plug in the oil pan and drain the oil. Catch the oil in the drain pan. After draining the oil install and tighten the drain plug to 18 foot-pound torque.
  • Fill engine with 5W-30 weight oil. The 4.4 V8 takes 8 quarts; the 4.0 V6 takes 6 quarts. Start engine and check for leaks.
  • Recheck level and top up as necessary.
  • Reinstall the under engine shields / skid plates.
Apr 12, 2015 | Land Rover Range Rover Cars & Trucks
How to change a fuel filter on a polo vivo 2010
Engine oil: Drain or extract and replenish; renew oil filter Engine oil: Drain or extract engine oil ? Chapter. Renewing oil filter ? Chapter. Replenishing engine oil ? Chapter. Draining or extracting engine oil Special tools and workshop equipment required t Used oil collection and extraction unit -V.A.G 1782- t Oil spill cloth -VAS 6204/1- Draining or extracting engine oil Carry out the following procedure: > Note
t For engines with standing oil filter the oil filter must be renewed before changing the engine oil. When removing the filter element a valve is opened, the oil in the filter housing automatically flows into crankcase. t If the engine oil is drained and not extracted with an oil extractor, replace drain plug. This prevents leaks. t Observe disposal regulations! - Extract engine oil using used oil collection and extraction unit -V.A.G 1782-. or - Remove oil drain plug. - Let engine oil drain. > Note
t The oil drain plug is fitted with a secure seal, therefore the oil drain plug must always be renewed. t Observe disposal regulations! - Screw in new oil drain plug with seal hand-tight. - Replenish engine oil, specification ? Chapter. Engine oil capacity: "Power unit" ? Power unit; Rep. Gr.17"Lubrication; oil capacities" or ? Maintenance table. Specified torques for oil drain plug: t Petrol and diesel engines 30 Nm > WARNING
t Torque specifications must not be exceeded. t Excess torque can cause leaks in the area of the oil drain plug or even damage. Renewing oil filter Renewing oil filter, 1.4 l and 1.6 l injection engines > Note
t Prevent engine oil from dripping onto components in engine compartment. t Oil new O-rings before installing. t Observe disposal regulations! Renewing oil filter, 1.4 land 1.6 l engine Carry out the following procedure: alt="W00-10211"> - Unscrew cover cap -1- with socket insert 36 mm AF and remove cover with oil filter insert -4- and valve -5-. - Renew O-ring -2- of cover cap and O-ring -3- of valve. - Renew used oil filter element with new filter element. > Note
Observe disposal regulations! - Tighten cover cap -1-. Cover cap torque setting: 25 Nm. Replenishing engine oil Oil specifications ? Chapter Engine oil capacities: "Power unit" ? Power unit; Rep. Gr.17"Lubrication; oil capacities" or ? Maintenance table. General notes > Note
Observe disposal regulations! - After replenishing with oil, wait at least 3 minutes and then check oil level. - Pull out dipstick, wipe with a clean cloth and push dipstick in again to limit stop. - Pull dipstick out again and read oil level. alt="N01-10183"> For dipstick as illustrated: A - Oil must not be replenished. B - Oil may be replenished. It may happen that the oil level afterwards is in the -A- region. C - Oil must be replenished. It is sufficient if the oil level is in the -B- region (hatched area) afterwards. There is a danger of damaging the catalytic converter if the oil level is above the -A- marking. - If oil level is below -C- marking, top-up oil to -A- marking. alt="N01-10255">
Mar 14, 2015 | Volkswagen Polo Cars & Trucks
The oil doesn't drain out of my 2001 Harley Davidson Dyna When I remove the oil plug only a half quart of oil drains out. Dipstick is removed and oil is hot.
Are you sure you're pulling the correct drain plug?
On Harleys with the oil tank under the engine, there are usually two drain plugs, oil and transmission drains.
Also, some have a drain on the bottom of the engine, which only a little residual oil will come out of it.
Finally, when the oil stops draining from wherever you're draining from, does the oil dipstick show that the oil level has dropped?
If not, you got the wrong plug!
Aug 07, 2013 | Harley Davidson FXDL Dyna Low Rider...
Oil change 1994 Cadillac Eldorado
well let me see you have 4.6L engine you need 7.5 quarts of oil with new oil filter.to do the oil change you need large drain pan and oil filter wrench and a metric wrench to remove oil drain plug you need a funnel also.you need first start engine let it run for 5 minutes to warm up thin out the oil so it will flow better.once engine warm up.turn off the engine.open you hood.now safely raise support vechicle on jack stands make sure vechicle parked on solid level ground.place large drain pan under oil pan remove oil drain plug you need a 15m wrench remove drain plug let all old oil drain out until you see slow drip then reinstall oil drain plug dont over tighten drain bolt.then place drain pan under the oil filter then remove oil filter using oil filter wrench or large channel lock pliers.once you remove oil filter wipe oil filter seal surface with clean paper towel.take new oil filter add oil to new filter then install new oil filter hand tight take filter wrench turn oil filter one half more turn dont over tighten will damage oil filter seal.make sure oil pan drain plug is in place. then lower vechicle. remove oil filler cap on the valve cover add new oil to the engine using a funnel to keep from spilling oil all over the valve cover and exhaust manifold.add all 7.5 quarts to oil crank case wait until oil settle down in crank case check oil dip stick oil level should be at the full mark on oil dip stick.dont over fill crank case.once you finished oil level correct crank engine check for oil leaks at oil filter and oil drain plug. if engine running okay you see no oil warning lights you ready wheel and deal.
Nov 20, 2011 | 1994 Cadillac Eldorado
2002 FATBOY, AFTER SITTING A WEEK, CHANGED OIL AND FILTER,VERY LITTLE OIL CAME OUT, ASSUMED ENG. OIL LEVEL WAS LOW, BUT NO OIL LEAKS DETECTED. ADDED 3 QTS , ROAD BIKE ABOUT 20 MILES. NOW ENG. IS LEAKING...
The Oil Capacity is 3.5 qts. (3.3 L) are you sure you pulled the right drain plug, and drained the ENGINE oil? The engine oil drain hex bolt is located on the right side of the motorcycle and is removed/installed horizontally.
Transmission oil drain hex bolt is located on the left side of the motorcycle and is removed/installed vertically.
Jul 25, 2011 | 2002 Harley Davidson FXST Softail Standard
I added oil to my Cadillac and it drained onto the ground
Before adding any more oil, make sure that you have securly replaced and tightened the oil drain plug (which is located on your engine's oil pan, under your car).
The FixYa Team!
Feb 01, 2011 | 1996 Cadillac DeVille
How do i change the oil filter on a 1991 cutlass calais? any special tools?
YOU NEED 4.5 QUARTS OF OIL WITH NEW OIL FILTER.YOU NEED OIL FILTER WRENCH YOU NEED WRENCH TO REMOVE OIL DRAIN PLUG.YOU NEED A DRAIN PAN CATCH OLD OIL.NEED LATEX GLOVES TO KEEP GETTING OIL ON HANDS.OIL DOES CAUSE SKIN CANCER.NOW YOU CRANK CAR UP LET IT IDLE 5 MINUTES TO LOOSEN UP OIL AND SLUDGE.TURN OFF ENGINE.SAFELY RAISE SUPPORT VECHICLE ON LEVEL SOLID GROUND USING JACK STAND.PLACE DRAIN PAN UNDER OIL PAN THEN REMOVE OIL DRAIN PLUG LET OIL DRAIN OUT UNTIL IT STOP DRIPPING. PUT OIL DRAIN PLUG BACK IN OIL PAN. THEN SLIDE DRAIN PAN UNDER OIL FILTER REMOVE OIL FILTER LET OIL DRAIN UNTIL IT STOP DRIPPING.TAKE CLEAN PAPER TOWEL WIPE OIL FILTER SEAL SURFACE MAKE SURE NO DIRT ON SURFACE.TAKE NEW OIL FILTER POUR NEW OIL IN FILTER UNTIL ITS ALMOST AT TOP THEN.RUB CLEAN OIL ON NEW OIL FILTER SEAL.THEN PUT NEW OIL FILTER IN PLACE HAND TIGHTEN IT.POUR 4 QUARTS NEW OIL IN ENGINE CRANK CASE USING A FUNNEL.WHEN DONE.CRANK THE ENGINE CHECK FOR LEAKS AT OIL FILTER AND OIL DRAIN PLUG.IF ALL IS GOOD JOB WELL DONE.
Aug 11, 2010 | 1991 Oldsmobile Cutlass Calais
2000 ES 300: how to change oil?...
drain via sump plug,replace oil filter,fill through oil filler cap.
May 17, 2010 | 2000 Lexus ES 300
Were do you drain the oil on a 1340 evo motor
Evo's drain from the oil tank, not the engine
Apr 20, 2009 | 1996 Daelim VS 125
How do you change the oil filter on a Hyundai Accent 1998/99?
Replace the oil filter after draining the old oil, and" BEFORE "adding new fresh oil, otherwise you'll be dump all that fresh oil, on the ground,while you "TRY to get the new filter installed.
Step 1 Remove drain plug,Drain oil into drain pan
Step 2 Remove oil filter
Step 3 Reinstall drain plug,qnce oil has drained.
Step 4 Fill new filter with oil,lube seal on filter.
Step 5 Install new filter, Add fresh oil to proper level.replace filler cap
Step 6 Run engine check for leaks.
Happy motoring!
May 23, 2008 | 1999 Hyundai Accent
Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract Logo
24 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
