SOURCE: john deere 2305/ the throttle lever goes back to
remove throttle lever assembly and if it is put together with a rivet?
take vise grip pliers and put in its jaws where it is connected or pivots at the rivet and squeeze it tighter at that point as it has worn with use. You will have to put out on it to make a difference
or if it is put together with a bolt ? its obvious
or if the throttle has indentations built in at certain points of travel then be sure the throttle assembly is tight enough to hit those and stay in that position
SOURCE: forward/reverse lever not holding in position on
Some come with a tension bushing underneath on linkage. Check that first
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
SOURCE: INSTALLING THE MOWER DECK ON JOHN DEERE 345
Can't help you completely but I believe the brass colored bar coming from deck towards front should be on top of the black bar that puts the tension on. I had it on the bottom and the both bars ended up under the deck.
SOURCE: John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
