Question about Worx Garden
WORX wg118 electric trimmer won't spin
Engine humming but not spinning
  • 313 Answers
SOURCE: Black & Decker Grass Hog
possible broken plastic part of spindle assy.
Posted on Jun 19, 2008
s_s_m_o_k_i_
  • 162 Answers
SOURCE: Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Posted on Jul 31, 2009
  • 279 Answers
SOURCE: is the battery for the worx 18v string trimmer
All you have to do is check the sizes of the batteries. If they are the same size, by that I mean shape and dimension, there is no reason you cant use them on different equipment. ...Lee
Posted on Sep 14, 2009
SOURCE: Engine runs, but spool with
If the spool doesnt spin check the driveline for damage.
If you just have a broken drive cable you can replace or repair it.
If the drive cable is spinning but the connection to the spool is bad then you might look for a replacement spool.
The problem is that the cost of buying these parts is on par with about 40-50% of the cost of replacing the whole unit.
Good luck and be careful!
Posted on Aug 06, 2010
  • 640 Answers
SOURCE: the engine runs but the
There are a couple points that are due consideration. One is the clutch and the other is the connection between the drive section and the attachment. Sometimes the drive cable end gets rounded instead of the square shape that allows it to engage the driven attachment.
Posted on Sep 11, 2011
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
Dryer motor hums but doesn't spin
Sounds like the motor has gone bad.
May 10, 2015 | Amana Dryers
Kenmore 600 series washer stoped in the fast spin cycle all it will do now is make a stuck humming noise
The humming can be the pump motor, running for a certain time, to make sure all water is out. It should stop in a few minutes. If not, it could be a glitch. If the error keeps coming back, please contact a repair engineer.
Aug 31, 2014 | Kenmore Washing Machines
Stanton t.80 Motor produces hum sound when holding the platter to cue. When platter is released the hum disappears. Also is a slight hum on start up. Have opened the turntable and all connections seem to...
Do you keep the platter at one place --> don't you let the platter spin and keep the record at. one place, you are know f.5;5,g your engine and parts.... buy suzuki slipmats and use the plastic rounds of plastic .... i thought by thud rumble too let your table spin when you hold the the platter, otherwise components get to hot
Aug 03, 2013 | Stanton Audio Players & Recorders
2006 F150 5.4, 4x4, Lariat. Intermittent excessive humming/fan noise from engine compartment
Sounds like the fan clutch bearing is locked up. Running in direct drive will affect MPG drastically. Its a 2006 so its time to replace it. See if the fan blade will spin by hand with the engine off or if excessive wobble is present at the bearing.
Jun 02, 2017 | 2006 Ford F-150 SuperCrew
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
My blower motor will not start. it hums and gets very hot. i can spin the wheel with no resistance gmp075-4
Assuming you are spinning it when the motor is humming, if the motor runs after spinning it it could be the run capacitor (replace) or open/broken start winding in motor(need new motor). Humming should indicate the motor is getting proper voltage. If motor does not try to run by spinning then open run winding in motor (replace motor).
Aug 30, 2009 | Heating & Cooling
Washer wont agitate or spin motor hums i canturn
if the moter hums when working but does not move time for a new moter the torque side of the moter has gone look on ebay or espares
Jul 29, 2009 | Washing Machines
WASHER MAKES A HUMMING NOISE IN SPIN CYCLE BUT DOESN"T SPIN & CLOTHES ARE SOPPING WET.
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Dec 25, 2017 | Washing Machines
Does not spin just hums
sounds like the motor is bad humming usually indicats that it is trying to work but the windings are bad...
Apr 27, 2009 | GE EWA5600GWW Top Load Washer
Garden Logo
116 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
