Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Model253-44392402 refrigerator need manual to show water hook up directions
Need to hook up water
Cannot locate water filter for my kenmore Refridgerator 106-57562792
Yes the filter is only available on some models. This is noted in the manual next to the part description: Part 14 Water Filter (on some models).
The entire set of parts lists (including a replacement grill plate, if you want it) is available from Sears Parts Direct: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-10657562792/0582/0165000?pathTaken=&prst=0&shdMod=10657562792 . The grill plate is part 13 on the cabinet diagram.
I hope this helps.
Sep 04, 2012 | Refrigerators
I have a kenmore refrigerator Model 363.9771612. It has an ice cube maker but that is not hooked up. I keep finding water on the floor of the refrigerator and I cannot figure where the water is coming...
on some models there is a condensation pan...is it still in place?
look up the manual & see if it shows a collection tray?"
usually a hose just above the tray to direct condensate into the pan?
Nov 15, 2010 | Kenmore Blenders
How to install a water line to a Samsung Refrigerator?
I have a slightly different refrigerator but the same problem. It says white line, but the white line is attached to the fridge on both ends and the blue line is not. Also the instructions do not actually look like the refrigerator so that is no help. No probelm installing a filter or the waterline to my water, but now I can't get it into the fridge.
Jan 11, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
LOST MANUAL
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?sid=MMHMxSearsx00019&product.modelNumber=10679852990&product.brandName=KENMORE
This is the link from the Sears Parts website. You will need to register to obtain a copy of the manual but it is free.
Dec 06, 2007 | Kenmore 18.3 cu. ft. Top Freezer...
Water not working at all
yes you need a filter for the water system to work. ther is a check valve built into the filter housing..
Dec 04, 2007 | Maytag MFI2568AE Side by Side French Door...
Refrigerator help
You should only need one water line to feed the water and ice maker with domestic water.
Nov 26, 2007 | Maytag MZD2766GES Side by Side...
How to hook up Ice & Water dispenser on freezer door
The water valve is on the back of the refrigerator. The water line connects directly to that valve. If there is no line available then you will need to run one from a cold water line in the plumbing using a drill type (1/4") saddle valve on that pipe. Hope this helps. If you need more instruction let me know!
Oct 06, 2007 | Refrigerators
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
