Question about Vehicle Parts & Accessories
When I turn the key, it acts like it wants to start but won't
Once started it acts like it wants to die and will of you don't give it gas
  • 20 Answers
Sounds like an engine coolant temp sensor to me. Find the ohms rating for the coolant temp sensor on your car, and test it with a volt meter. The coolant temp sensor gives the temperature of the coolant in your car to the computer to determine how much fuel to put into the motor. If the coolant sensor is bad, the computer in your car thinks its -40 degrees F and thus dumps way to much fuel into the motor causing it to be way to rich and making it very hard to start and stay running.
Posted on Nov 24, 2014
My car turns over but won't start, when started
The year make and model would be handy to know.
You would need to check the fuel system and find out why you don't have fuel to the injectors or carb.
Oct 08, 2012 | Cars & Trucks
Vehicle seems to not be getting enough gas because it chokes up when u accelerate and dies when you put it in gear
it could be the pickup screen in the tank is clogged from dirt in the tank being stirred up when you ran it dry then put gas in you will have to drop the tank to look at it or dirt could have made it to your injectors or throttle body
Oct 04, 2012 | 1995 Chevrolet K1500
Our 1995 Chevrolet Lumina 3.8L died out of gas last night - we put a little over a gallon back into it and it still won't start. Do we need to put more gas into it to start it or is it more likely now...
Running cars low or out of gas is a problem. The fuel pumps are in the tank and the fuel keeps them cool.
My first guess, since it was run out of gas, is the fuel pump is dead.
Listen for the pump to run when you first turn the key ON (not start, just ON to where the dash lights come on).
If you don't hear the pump then get to dropping the tank and changing it.
Oct 07, 2011 | Cars & Trucks
Cranks over but won't start changed fuel pump but still not starting started once drove it 20 miles and now won't start again
I had a 95 Astro that acted in a similar way. Mine was the fuel pump. I wonder if your ground is loose for the pump circuit or if there is a relay dying on you. Does it act differently with a change from hot to cold weather? A loose ground would do that. You could also have a faulty pump. I heard stories of people getting non-GM approved pumps that failed or had to low a PSI to accurately supply the engine with fuel. Is it getting adequate fuel pressure (50-60 PSI). It should be 60 psi but I was told my 50psi was within GM specs. Mine eventually drank the radiator due to a blown head gasket that no one ever properly diagnosed.
Sep 09, 2011 | 1997 Chevrolet Astro
Factory alarm started acting up a few days ago, now car won't start. only hear single click noise. managed to jump started it once
Could be the battery is dead or dieing. When batteries start to go they will cause the security to act up. Plus other things
Aug 08, 2011 | 2006 Hyundai Tiburon
Ran out of gas-truck won't start-replaced fuel
you probably have air in the lines, if you have a carb, spray some quick start into the carb and turn it over, if it starts and then dies when the starting fluid has run out, you probably need a fuel pump, since the running of the car should have blown out any air that was in the line, If your car is fuel injected, loosen the bolt cap at the end of the injector line that supplies the fuel,, and tap the key once,, ( don't start it,, ) just turn the key on and off 3 or 4 times, this should blow fuel out of that loose bolt head, if it does your getting fuel, if not, back to the fuel pump, also you can check this link, http://www.aa1car.com/library/us1296.htm
Jul 24, 2011 | Chevrolet Suburban 1500 Cars & Trucks
I have a 98 contour. It started great and now all of a sudden it won't stay running. When I turn the key it does start but if I don't give it gas immediately it dies.
Hi, if it will not hold an idle, there may be a vacuum leak. Check all the hoses connecting to the intake manifold. It would have to be a pretty big leak to cause the symptom you're having. Please see my tip at http://www.fixya.com/cars/r7427423-fix_poor_idle_high_idle_stalling_fuel . These are generic instructions. If you getstuck or need specific instructions for your car, please get back to me with model, year and engine info.
May 09, 2011 | 1998 Ford Contour
Vehicle Parts & Accessories Logo
74 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
