Question about SunBlade 1500 (A43UAB1-9AB-D512AY) PC Desktop
Uncorrectable data error: Block 5e2b00Is this fixable?
SunBlade 1500, running SunOS Release 5.10
Sunblade 1500 reset CMos
reset the cmos? if i understand correctly all you have to do is remove the battery with in the bios leave it unplugged from any pwer and it should reset
Jun 19, 2014 | SunBlade 1500 (A43UAB1-9AB-D512AY) PC...
If uncorrectable error(e32) disc can be run properly in PC or not
Hello Sanjeev
Disc will not run when there is error, every amount of data will be running and it is needed. Even dust will cause error, so you need to clean the dust and if the disc was scratch you need to find or buy another disc.
Best Regards
Neciforo Llanto
Sep 21, 2013 | Computers & Internet
IDE disk read test block failure
try to run with chkdsk command and if it is fail kindly replace the disk.
Nov 14, 2011 | Dell Dimension 4600 PC Desktop
Dell won't boot up. The following problems isolated by F12: 3600:0123 Battery test failed 0F00:075D IDE device failed: the self test failed to read ... 0F00:0244 Block 1905 74359: uncorrectable data error...
sounds like a complete motherboard failure with a lot of other problems.
if you remove the HDD ( turn the machine over. 2 screws on the right.slide drive out ) and mount it in an external caddy you should be able to use another machine to access the drive and probably get most data off it.
Aug 02, 2010 | Dell Inspiron 6400 Notebook
I WENT FOR EXTENDED TESTING FOR MY DELL VOSTRO SYSTEM.. AND RECEIVEED ERROR CODE: 0F00:0244 MSG:DISK_0 BLOCK 34410367 CANT READ, REPLACE DISK OR REMOVE WHITE PROTECTION.. WHAT DOES THIS MEAN??
Uncorrectable data error code or media is write protected which mean the test found a big problem have a computer repair shop look at it.
Jun 16, 2010 | Dell Vostro A860 Notebook
Dell Laptop Vista repair stuck! My Dell Vostro 1500 does not start. It is Vista Home. So, I am trying to repair it with the installation disk. However, the installation stuck after the "Windows is loading...
leerobin
It does look like you may have a problem with the hard drive on the computer.
In regards to recovering your data if you have access to another computer you can connect the hard drive to it to see if the data is recoverable. Note since you ran the system recovery it may have over written your data. If this is the case then you might check with your local computer store to see if they have a hard drive data recovery program. As long as there is not a physical problem with the drive they may be able to recover the formatted data.
After that I would look at the top of the drive to see who the manufacture of the drive is then download there diag and repair tool for the hard drive. While you have the drive on the computer run a repair scan on the drive. If you just have some bad sectors then the diag program will zero them out and repair the drive. If the drive is indeed bad the program will tell you this as well.
If the drive is bad and your computer is still in warranty then you should be able to get Dell to send you a replacement hard drive. If you are not sure if you are still in warranty let me know the service tag of your computer and I can look it up for you. Also note you will want to have Dell send you your recovery CD if you do not already have it.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 20, 2010 | Computers & Internet
My OS freeze's as soon as i input my password
Hi there.
Sorry but i have to inform you that your hard drive is failing, the error messages that you are getting relate to this fact and is related to the hard drive having unrecoverable bad sectors or immanent hard drive failure.
There is no way you can recover the drive!!
Your only option now would be to buy a new drive for the computer or if the machine is still under warranty take advantage of that and send it in for repair, you will no doubt have to purchase a windows installation disk too.
Good luck and thanks for using FixYa!!
May 24, 2009 | Dell Dimension 9200 PC Desktop
Error code 0244
Hi there.
Error Code 0F00:0244
"Msg Block 5*****4: Uncorrectable data error code or media is write protected"
Sorry to say the hard drive has failed or is corrupt with bad sectors, with these Dell drives there is no way of fixing them.
There maybe a possibility that you can recover your data if it still spins up and you add it to another computer as a slave device.
May 20, 2009 | Dell Computers & Internet
Laptop PC running XP Home Edition will not boot, error code 0F001A40 Msg: Block 43982261 Uncorrectable data error or media is write protected
It sounds like you have a corrupted hard drive you can try to restore to last known good configuration by pressing F8 when you boot up. If that doesn't work find your restore disk and select repair windows first. before installing new(all date will be lost) mysleuth
May 06, 2009 | Computers & Internet
SunBlade 1500 (A43UAB1-9AB-D512AY) PC Desktop Logo
22 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
Tape-Techie
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
