How do I get the door open on neff washing machine?
2 Suggested Answers
  • 228 Answers
SOURCE: Change integrated Neff washing machine door seal
you will need to remove front panel this is quite easy,turn off mains open door and look for steel band spring holding front lip of door seal this needs to be removed it will be tight but will pull off,push door seal into drum so as out of the way, look at bottom of panel you will find 2 or 4 holding screws dependent on age of appliance undo these ,there is one other screw to undo behind the soap drawer take out draw and remove screw it is bottom r/h/side one you can then pull front panel away you need to disconnect door lock plug just pulls out.
remove panel out of the way and you will see another steel band holding back of seal to wash tub remove this and pull of door seal. reverse procedure to fit new one a little washing up liquid may help reassembly fit panel etc run check for leaks.
good luck
Posted on Aug 05, 2009
How do I empty the water to open door
place the drain hose lower than the machine
run it into a bucket or drain hole in the floor
Jun 14, 2016 | Neff Washing Machines
F13 error code
Try unplugging the machine for a few hours to rest the code on the board.
Oct 14, 2013 | Neff W5340X0 Washer
How do you clean mould and slime off rubber door seal on integrated Neff washing machine?
you dont! you will have to replace the seal not an expensive job if you do it your self
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 08, 2013 | Neff Washing Machines
Neff washing machine stops half way through the cycle and the high water level light comes on
possible hose blockage or filter blockage. when half way through the cycle the machine evacuates the water to replace for rince cycle or to start spin cycle if the way is blocked the water cant go out so the machine can not finish the cycle, and usually the door will stay locked so not to flood, when the water is still in the machine. remove and check the drainage hose for kinks and blockage. also remove and check the filter under the machine. (be careful as this will let out all the water so have some towels or bucket ready to catch the water. once the filter is clean replace and restart your machine.
I hope this was useful.
Feb 15, 2013 | Neff W4380X1 Front Load Washer
NEFF WASHING MACHINE
Error code e 10 means no cold fill.
Ensure that the water getting to the machine from the water supplies at the back. Check that the hoses are not bent or kinked and that the water tap is opened.
Try cutting power to the machine for ten minutes to reset the code.
If that does not work, then it is usually a faulty inlet valve stuck on closed on cold water.
Feb 27, 2009 | Neff V4380X0 Front Load Washer / Dryer
DI 'My self' Washing Machine Door Rubber
This video will show you how to change the door seal gasket on your neff washing machine Neff W5340X0
Jan 14, 2009 | Neff W5340X0 Washer
good luck
Dec 22, 2008 | Neff W5340X0 Washer
Error message
Switch machine off at the wall and leave off for 20 secs. Open the door. Switch back on again and close door firmly, giving the door handle an extra hard push. Should be o.k.
Mar 24, 2007 | Neff V4380X0 Front Load Washer / Dryer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
