Question about E-Machines Computers & Internet
I cant figure out were the cables go in my emachine t5246 and i dont have the mannual
Its mostly this black cable and these red/white and blue/white wires that i dont know where they go
  • 243 Answers
SOURCE: MOTHERBOARD WIRING
Instructions should be in the manual found here
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=302
They sound like they are for your from usb posts on case...but thats just a gues :)
Hope that sorts it for you?
Posted on Dec 30, 2007
jack_daniels
  • 304 Answers
SOURCE: Which cables go where???????
RED - YELLOW - GREEN - BLACK -----
1 3 5 7 9
2 4 6 8 10
Posted on May 08, 2008
ziraffa
  • 827 Answers
SOURCE: no power to emachines t6522
The final set of connections are the front panel leads that attach to the motherboard. This includes the LEDs for hard drive activity and power status, the case speaker, and most importantly, the power switch.
eg:
You should consult your motherboard manual to find out where to plug these in. The power one is obviously the most important.
Hope this helps
Chris (ziraffa)
Posted on Jan 17, 2009
asthanarht
  • 258 Answers
SOURCE: how to place indicator led cables to motherboard
hey look close to the nearby processorin motherboard there is 9 pin (depends on motherboard) for power and for reset button... close your eyes to motherboard at that place you will find also the name which are mention in motherboard e.g. power and reset in motherboard just plug red wire in power and and green for reset ( depends on motherboard) you an chk manually ...
Posted on Apr 05, 2009
  • 10 Answers
SOURCE: front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Posted on Jul 29, 2009
I bought a powabyke on ebay and when it arrived I noticed that there was wires unattached beside handlebars where throttle cable joins throttle but the colours don't match the cable coming upwards has...
if its for the key area try red red ,black black, yellow orange, white grey, blue,green , kinda the same on some tailer hookups.
the other colored wires that dont match as well are distributed to the turn signals. if they work as they should after the above mentioned hookup great!.
If not just try switching the orange and blue wires again because one is left one is right side.all the power and grounds are the same,good luck, Gary
Oct 25, 2013 | Cars & Trucks
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
Why cant i get my wii console to work in color
Well it might either be the tv or the av cables that is causing the wii system to be in black grey and white then.
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Mar 06, 2012 | Nintendo Wii Console
A new cable box was connected to my 32" Proscan LCD TV. Now everytime I turn on the television I see the message "HDMI-1 No program information available" I contacted the cable company and...
I know this may be a dumb question but I have to ask because even though the cable company has HD boxes a lot of them still dont have HDMI outputs instead they use the 5 Component cable (red,blue,green,for video and white, red for audio). Not only that most of the cable guys are not the brightest in the world I work in an electronics store for 13 years and cant tell you how many times I went to someone house and it was hooked up wrong. Are you stuck on HDMI-1 or can u chnge the channel by using the tv/video button it may say input as well. Check how its hooked up easy to tell 1 cable HDMI, 5 cables -Component. If it is HDMI check the other hdmi input as most LCD tvs have at least 2. same for component it will say component on screen
Dec 14, 2010 | Proscan Televison & Video
I own a 1986 gemini sedan and i cant figure out the wiring colours?
Hello! Power
Constant +12=Red/White Switched +12=Orange
Ground= Black/Yellow Illumination=Green/Red
Dimmer=Red/Green
Speakers
FR+ Gray
FR- Gray/Green
FL+ Yellow
FL- Blue/yellow
RR+ White
RR- Red/White
RL+ Orange
RL- Black/Orange
Guru...........Saailer
May 20, 2010 | Car Audio & Video
My dvd movies only plays in black and white.
are you using component video cables (red,green,blue) or composite (yellow,red,white)
most of the time if the blue or red cables from the component area seated firmly they cause the picture to be in black and white.
Oct 22, 2009 | Sony Dream System DAVDX155 Theater System
Trying to hook up the dvd player to the tv and I figured out how to get the color back on but the sound is terrible it sounds like its echoing. Can't figure out the blue green red combination for white red...
Your TV probably has several different ways of connecting video. One is component, which uses three cables. They are red, green, and blue (RGB). The video output on your DVD player will match this color scheme.
Another scheme for video is composite (because it combines the red, green, and blue into one cable). Composite video is usually a yellow "socket". It is simpler to connect, but the video quality is noticeably poorer than component (RGB).
Another scheme is S-Video. This is one cable (round and black), but you will see four pins inside the connector (and four holes in the "socket"). This accounts for the three cables in the component scheme with the convenience of having only one cable. The picture quality is almost as good as component as well.
In your case, there may be confusion between composite and component. If you have red, green, and blue sockets on both the DVD and TV, then make sure you use them and connect them color for color.
Now for the sound, this is simpler. Red is the right channel, and white is the left. Make sure you connect red to red and white to white. Then, viola, everything will be right.
I hope this helps.
Aug 24, 2009 | Philips Televison & Video
What cables are what
black is ground red is power with key on yellow is power all the time blue white is amp remote wire you dont use this if you dont have amp.
Sep 23, 2008 | Kenwood KDC-3024 CD Player
2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Jan 15, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
No Sounds when connect XBOX 360 to HD port
you need to run the white & the red to the aud. input
Aug 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Computers & Internet Logo
70 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
