Question about Balboa Instruments Duplex Digital Panel 2 Pump
Dr error with balboa m7 system
I have Balboa spa with M7 system, I just replaced circuit board and heater. I refilled water and powered up spa. It passed priming mode and then showed dr error when spa tried to heat the spa. Pumps run and water flowed from jets to filter.
3 Suggested Answers
SOURCE: I have the Balboa 500Z pump heater kit. Its hooked
I have a 6 month old Balboa 500Z. I have noticed that the filter system tis running all the time 24/7. I have reset the filter cycle to run for 2 hours { F2 }. It still is running all the time. It dose not seem to make a difference what I set the cycle for it just keeps running
Posted on Jul 19, 2011
SOURCE: I have just refilled by
Priming can be done many different ways depending on thetubs design. Some tub manufactures provide bleed valves located on the plumbingjust beyond the pump and heater unions. Some pumps have a bleed valve locatedon the pump. If there are no bleed valves then you will have to release theunion nuts to allow the air to escape.
You can find answers to common spa or bath problems online at http://www.balboadirect.com/support.aspx
Hope that helps.
Posted on Sep 12, 2011
I have a Jacuzzi spa with a Balboa R576 (522205) control box. The control panel constantly shows "OH" (overheating) even when the water temp is 50-100 degrees F. When I reset the system by flipping the...
There are some things to check.
Make sure the vents on your cabinet are not obstructed.
Make sure your filter cycle is not too long
Make sure you are not running high speed for more then 30 mins.
Have you looked through the Balboa error message site. I have attached a link follow your error through and you may find your answer. Diagnostic Messages
Mar 02, 2015 | Balboa BB58048 Jacuzzi R574 R576, 4.0KW,...
Balboa hot tub m7 wont power on at all
Either the spa is incorrectly wired or one of the fuses is blown in the spa pack. Typically this is due to your electrician wiring the spa incorrectly and blowing the fuse on accident.
Aug 06, 2012 | Jacuzzi Balboa R574 System for 1 2 Speed...
I have a Balboa VS500Z . The circuit board burned up where the heater buses are located . I replaced the board and the heater . Know when I start the Spa it primes at low speed for about a minute . Then...
DR code - Inadequate water detected in heater.
HL code - Hi Limit, Spa over heat. In your case the Hi Limit is preventing the element from burning out.
This means there is no water or not enough water flowing through the heater.
Common causes:
Hi Limit sensor failure.
Blocked suction, skimmer.
Are the gate valves all the way open/up?
Pump is not functioning correctly, impeller/wet end failure.
These are the most common, but there are also other causes.
I hope that helps
Feb 20, 2012 | Garden
Spa Heater problems- Balboa VS-501 controls #54356.
Use a high quality external temp probe and make sure the temp sensor in your system is correctly reading the water temp.
If the water is truly 110 then you may need to replace the board completely.
Jun 20, 2017 | Pool & Spa
I have a balboa board #55098 and nothing works. I have disconnected everything and then tried powering up and it only clicks until the breaker trips any suggestions?
As with any troubleshooting over the Internet, this is like giving a haircut over the phone. So, that being said, this problem could be any number of reasons.
Here are some things you should have a spa technician look at (not in any specific order):
  • Power connections
  • Relay
  • Whether the transformer is seated properly
  • Whether there are loose wires
Disconnected all the components and see if it still does the same thing. If not, then one by one, reconnect the components until you isolate the problem. If the problem persists, then you might have a larger problem like a blown circuit board, etc.
Hope that helps!
Jun 17, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
Balboa vs500/501/502 gs500/501/502 I just refilled spa yesterday and now I'm getting error codes HL and dr both indicate low flow issues, The water level was re-filled to where it's always been. Any help...
A lot of times you can get an air lock as the spa fills. All you need to do to fix this is open the drain valve for a few seconds till it runs just water and no air. Or start the pump wile the drain is open. This should fix your problem. Good luck.
Sep 04, 2010 | Balboa Instruments Duplex Digital Panel 2...
Balboa Instruments Duplex Digital Panel 2 Pump Logo
46 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Mister Danger
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
